Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 2006 Jetta GLI MKV install
  1. #11
    Jul 2006
    St. Paul, MN
    Yes,
    One of my primary reasons for the install was listening to audio. I ran Power, Ground and amplifier remote turn on lead to the trunk. Ran speaker and rca cables from the amp in the trunk back up to the dash. I wired the speaker wires into a harness that plugged into the factory wiring, replacing the radio. I hooked the remote turn on lead to a switch and into the harness as well. I also connected rca adapters to the cables to create one connection into my ipod. I just turn on the amp and fire up the ipod for now. I am also testing audio from a tablet PC.
  2. #12
    Jul 2008
    Lockerbie Scotland
    i know youve already worked out the power. but can you not get access to the main inputs to the fuse box like you can with the mk4 versions ( 4 connections, 2 live, 1 ignition, 1 earth that are bolted to the underside of the fusebox )?
  3. #13
    Jul 2006
    St. Paul, MN
    Yes, I can get to that area, but I had no need. I installed an aftermarket amplifier and thus had to run main power from the battery. It is a high current amp and requires it.
    Here is a pic:
  4. #14
    Apr 2009
    Newark, New Jersey, United States
    hey
    how are you powering the thin client?
  5. #15
    Jul 2006
    St. Paul, MN
    Well, since it is a 12v adapter. I would use 12v supply from the battery instead.
  6. #16
    Low Bitrate thorolf15's Avatar
    Feb 2004
    France, Cruseilles
    You could also hack into your powersupply for the PC, I myself have an OPUS and did so Works like a charm.
    Planning: It's not my thing...
    Testing: Not really my thing either...
    Install: Guess around 60% Software takes soooo long....
    My install thread here
    The victim - a golf 4 130tdi 4wd
  7. #17
    Jul 2006
    St. Paul, MN
    Alright any one interested in the parts? Selling pretty much all of it. Sold the car and going a different direction in next car.
  8. #18
    Jun 2010
    wiring the amp
    i know this is an old thread but im in DESPERATE need of help. i cannot find any diagrams or threads on how to wire subs and an amp into this car. all i need to know is what wires i need to connect to to get sound from my radio to my amp and then to my sub. plus where should i run the wires so it looks clean. PLEASE HELP!!!
  9. #19
    Jul 2006
    St. Paul, MN
    ok, hit me up at my email address and I can help you out.
  10. #20
    Nov 2013
    looks good.
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  2. 2001 VW Jetta CarPc Install
    By *Glow* in forum Show off your project
    Last Post: 03-27-2008, 04:00 PM
  3. 94 Jeep Grand Cherokee Install
    By jamiewhittingha in forum Show off your project
    Last Post: 08-02-2006, 02:02 PM
  4. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  5. Replies: 2
    Last Post: 05-21-2004, 12:50 AM
