Results 1 to 10 of 10
Thread: Ford Puma 2001 UK - work log
    Jul 2004
    Essex
    PC is nearly done so i thought id post up a work log
    Used Linitx.com , Itx warehouse , ebuyer and ebay for hardware purchasing
    Current System Spec
    VIA EPIA VB6002G Pentium M main board
    pentium M centrino 1.6ghz 479 pin ( took ages 2 find !! )
    1gb DDR2 Corsair Ram
    80gb SATA 2.5 Harddrive
    m2-atx Power supply
    ZoomPC Enclosure
    coolermaster Centrino socket CPU fan
    USB Wifi card , with external antenna attachment
    USB bluetooth v2 card , running wiicomm drivers
    External Powerd USB hub
    Soundblaster USB audigy 2 External soundcard
    USB OBD2 interface
    GPS USB
    Screen setup
    using a cartft.com 7inch touchscreen
    Custom fibreglassed dash board , still being painted atm .. will be ready in a day or 2
    Audio
    Infinity Front 6.5 speakers
    theloudest.com rear 6x9s
    Theloudest.com 4channel amplifier
    Front End/software
    Windows XP sp2
    Centrafuse XLE
    Wifi Hopper 1.2
    Esitmated Completion Date
    18th July 2007
    Progress Bar / Complete
    Computer has all been built and everything has been setup . just awaiting the screen build to be finished be4 installation .
    Pictures to follow
    Jul 2004
    Essex
    Pictures of screen , click for bigger pics
    Jul 2004
    Essex
    Last Pics
    Jul 2004
    Essex
    Why not to bubble rap screens be4 there dry !!
    Jul 2004
    Essex
    The front End
    The PC Case Connected indoors.
    Stealth FacePlate
    Jul 2004
    Essex
    13/07/07
    Installed all wiring in car , and OBD port has been put in a new location
    The circuit Boards from the touchscreen has been mounted into the dashboard
    centrafuse has had plugins installed .. SYNCFS - for network syncing my music
    and the EMAIL plugin for checkin my gmail
    also installed mobile Impact SNES/sega etc emulator , and it embedded quite good with centrafuse
    just waiting screen build to be finished
    Jul 2004
    Essex
    14/07/07
    Installed Screen build ,
    Pictures to follow...
    Ok screen is installed , a crack is currently on the joint so tht needs 2 be sorted .
    to stick the screen to the build i used some doublesided black sealent which they use for stain glass windows to stick em inside . really strong stuff and tht screen was in tight even before the stuff , so it aint going n e where ... it does need a little tidy up ...
    Jul 2004
    Essex
    15/07/07
    Carpc is drilled in , currently sorting some issues out with the audio ... as tht seems a bit busted ... and i think needs the drivers redoing as it cuts out and makes weird noises ... other thn tht its working quite good
    Jul 2004
    Essex
    16/07/07
    after spending the whole day reformating the blody thing and installing everything agaiN !!! all is working ok now ... not sure if the VGA drivers r going to work , atm im using windows jobbys ..... just needs tidying up 2morrow .. thts about it really
    Jul 2004
    Essex
    01/08/07
    after having majour problems with Vias onboard graphics and my screen , i have decided to install a PCI Nvidia , to do this i need a new case as well so i have orderd the pack-box a4 and a dual pci riser card
  1. mk 5 ford fiesta work log *56k warning*
    By Tone in forum Worklogs
    Last Post: 07-28-2007, 02:21 PM
  2. Replies: 8
    Last Post: 11-22-2005, 05:21 AM
  3. Prison vs Work
    By ACHIEVER in forum Off Topic
    Last Post: 04-15-2005, 02:53 PM
  4. Ford Focus (UK) and Opus
    By stevieg in forum Power Supplies
    Last Post: 07-30-2004, 04:50 AM
  5. Will This work in UK?
    By Adam G in forum LCD/Display
    Last Post: 03-19-2004, 10:26 AM
