Results 21 to 30 of 34
Thread: 2007 Mustang Install
  1. #21
    Constant Bitrate Hessian's Avatar
    May 2007
    Almost there...
    Got everything back in today. Only a few things left.
    Still getting the pop from the subs. Opus 120 should be preventing this??
    There is noise coming from the subs as well that seems to be from the pc.
    The pc mb is on brass standoffs, so should be grounded.
    I've got no noise from the other 4 speakers.
    When I shut down I get the logon screen and then my Opus gives me the 4 blinks which means a sleep error.
    Sounds great with the sub working. The screen has not gone 'no input' yet
  2. #22
    May 2007
    5V Regulator and Sub Noise
    The stock subs on the 2007 Mustang only require 5v to turn on. The 12v from the Opus was making them pop.
    After I installed the regulator the pop was gone.
    I've almost got the noise from the doors subs figured out. It has to do with the placement of the RCA connectors. I can move them back toward the rear of the car and seems to work.
    Still no idea on the sleep with the Opus 120. I removed the low power jumper, but that just shut down the computer about a minute after it went to sleep.
  3. #23
    Constant Bitrate 2 STanGeR's Avatar
    Aug 2005
    Terre Haute, IN
    One of my first problems I ran into with putting the PC into sleep mode was I actually needed a BIOS update to fix. I had to email the manufactured to get the update, but it was worth it. I works like a charm now.
  4. #24
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    looking very good. i love the screen. I was wondering where you picked up your copy of tiny xp? I've been wanting to mess with this for awhile.
    1998 Camaro Worklog Starting over, New setup for 2010
  5. #25
    May 2007
    Tiny XP
    Quote Originally Posted by sporty_drew View Post
    You can search isohunt.com for a Tiny XP torrent. Using Google should produce a few places to download as well.
    I've had some issues (Tiny XP Beast) so test everything thoroughly while the system is still out of the car on the bench.
  6. #26
    May 2007
    Rear Deck Speker Install
    The 2007 Mustang rear deck speakers are flush with the deck. This is different than the 05/06 because the speakers have grills and are easier to swap.
    To swap the speakers in the 07 you will need to do the following:
    • Put the rear seats down.
    • Pull up both door sills (they just pop out)
    • Pull up the molding that is below the quarter windows (requires some effort)
    • Use a panel puller to remove the plastic fasteners that hold the rear deck carpet down.
    Be careful not to scratch the upper area around the quarter windows when removing the lower panels. You might want to tape those areas.
    The rear deck holds 6x8 stock speakers that are basically mids with no highs. I installed two Alpine 6x9s so I had to do some drilling. I also installed my amp upside down between the two speakers using rubber gromets on the feet for insulation. I called Alpine and they said upside down was ok.
    Alpine PDX-4.100 installed upsidedown. Notice the gromets on the feet. The wires need some work, but normally nobody will see those.
    This is the rear of the car during the install. I used cardboard templates to mark the holes I wanted to drill. I used an old cover to place above the holes when I drilled them so I would not hit the window.
  7. #27
    May 2007
    USB/Network/Memory Cards
    I modified the center glove box to hold connections for USB, network and a 3.5" bay device for memory cards. As you can see I didn't spend a lot of time finishing off the fabrication.
  8. #28
    May 2007
    Disable Switch
    I was doing some rewiring and decided to add a switch to disable the PC. Still need to hide those RCA connectors.
  9. #29
    May 2007
    Finished... 1.0
    While I still have an issue with sleeping the PC. I'd say that my install has come to an end. I'll post any issues and future modifications here. I'm also going to create a new post in the finished projects page.
  10. #30
    Mar 2006
    Iowa
    thanks for the info on tiny xp, i never seem to have luck downloading tho (takes soo long)
    You could pm a mod or report your first post of this tread and have them just move this over to show off your project.
  1. VW Golf IV - Mac Mini install
    By Fuse314 in forum Worklogs
    Last Post: 02-24-2008, 05:25 PM
  2. 1987 Mustang GT Convertible MP3 Mustang
    By jzgt in forum Worklogs
    Last Post: 10-26-2007, 09:18 PM
  3. Another 2005 Mustang install
    By 2 STanGeR in forum Worklogs
    Last Post: 12-02-2005, 11:46 PM
  4. windows xp install
    By Moneyfink in forum WinNT Based
    Last Post: 03-09-2005, 01:05 AM
  5. Please help install a Front End
    By Zebelkhan in forum Newbie
    Last Post: 01-31-2005, 06:40 PM
