Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 73
Thread: 2006 civic Si Goin' big, 10.2"lcd/300GB hdd/1Gb ram...
  1. #11
    Variable Bitrate portabuddy's Avatar
    Feb 2006
    mississauga, On.
    I want the best reception so i got a 8db gain antenna and began to think on how to make a internal antenna external... i stole a external gps/gsm antenna from work ment for a volvo truck(aprox. $300) and gutted it, Im going to mount it on my roof later. the gsm works on a 1.1GHz and wifi works on 2GHz so i had to scrap that antenna, and i bought the holox usb gps mouse off ebay, since i couldnt get the one built into the original volvo unit to work that had to go too. there was a bunch of circutry in there that was pretty useless, lol.
    this is a pic of the antenna befor the butchery and durring, originaly i was going to have the gps under the dash and i was going to use the antenna for my tv, but im going to intergrate the tv antennas into the side rear windows in the form of de-fogger strips insted.(going all the way around the window)
    here is a pic of the antennas still put together
    here is a pic of the antenna with the rubber boot taken off, the antenna is junk and the boot i used to make the indoor a outdoor. also note the thickness differance, the original is 2mm thick and the new one is 12mm thick, thats a bit of a differnce, i ended up scooping the excess rubber by drilling it out with progresivly bigger bits since the sidewall was quite thick.
    and here is a nice Pic of the inside with all the useless junk, at this point i decided that the mouse dosn't doing to fit inside eaven with everything removed. so i had a choice modift the antenna housing or tare apart the gps mouse...
    I chose the mouse. HA HA HA FUN!@$#&^
    I went midevil on it can opener stiyle..... OH YA! THATS RIGHT I'M NUTZ
    FYI this is what it looks on the inside
    well I'm all in so lets keep on destroying, i cant use the threads on the old antenna so i need to gently "extract" the new ones, *CRACK*
    http://www.mp3car.com/vbulletin/atta...7_1024x680.jpg
    I drilled the old threads out and drilled through the brass to the exact outside diamiter of the new one.
    and crazy glued it into place
    this hurt me very much, but i had to do it to get it through the nut thing for mounting.
    also on the right you can see the new antenna all done and squezed on. this was VERY HARD since i had to stretch the rubber over the antenna, so i greased it up with some nice syn. axle grease i had laying around, this greased everything so i got some spray adhesive used on carpets sprayed my handa and my brother sprayed hus this have us enough traction to slip it over. this took over an hour
    then i hard plastic epoxied it into place this epoxy dries rock hard and it ensures that this will be water tight eaven though im siliconing EVERYTHING.
    TAAA DAAAA all done and siliconed however i siliconed the top and filled the whole thing(the WiFi antenna) up with silicone too...crazy no?
    BTW the antenna still flexes at the joint, and all of the close-up shots where esp. hard to take as I dont have a macro lese only a 55mm and a 300mm, so i'm holding the assy. in one hand and the camera with the other trying to zoom, focus and all while holding a magnifying glass to get the close up, lol that was fun. i should get pretty good reception now also considering its hooked up to a usb 200mW WiFi device not the normal 35-100mW that most are, He He.
    You can run you can hide but i'll find the "defult", "linksys", "netgear", and "MyWiFiNetwork" of the world, any one who scans for unsecure networks knows exacly what i mean(stupid ppl.)
    Life Dosn't come with a reset button, if it did you might as well turn the game off.
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by portabuddy View Post
    Ir led's are bairly visable, they are workin in a light spectrum that we cannot see, i plan on putting 150 in the front and 50-100 in the back
    The other bad part is that now you will have a hoard of mosquitos following your car and trying to suck its blood! They like the IR too.
    You would be surprised at least around here. I find so many "linksys" broadcasts but they are encrypted! Its like they had the time and know-how to encrypt, but not to change the name? It just gets my hopes up and squashes them!
    Looking good so far btw.
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Feb 2006
    mississauga, On.
    Quote Originally Posted by 2k1Toaster View Post
    this i did not think of, your right the bugs will be drawn to the car... Damm you, Oh well some times sacrifices need to be made in the pursuit of cool..., i was going to put them in the lower air dam of the bumper but now im thinking that the upper windsheild would be better, Any thought?
    thanks, i just got to sanding it a bit with god ol' 40 grit ...
    I was driving around with my laptop and the antenna before i "fixed it design" and useing winC i found a alarmin number of unsicure networks, 3 time that with the small antenna, And even the ones that where secure the passwords where 12345 or user or defult or home?, gowd ppl are dumb, what do you think that no one can use your network but you?, , i will do some more sanding and post later on when i come home from work.
  4. #14
    Jun 2007
    Oxnard, CA
    Ir led's are bairly visable, they are workin in a light spectrum that we cannot see, i plan on putting 150 in the front and 50-100 in the back, I got the strongest ones i could (of course ), the downside to heveing the lights on my car is if cops are useing lidar(lezer radar) the leds give it more acuracy , the plus side is that i can make them pulse useing a varable resistor and a 555timer circut and make them work like a green light device.
    Ever notice that there are little black sensors with little hoods ontop of the lights at intercections?, well those are Ir recivers that catch pulses from firetrucks that change the lights green when one comes through the intersection, Its a $50 fine if your cought with a device that messes with the trafic light...
    kleicl, the problem with the progress is that i need to wait a day or so fot the epoxy to fully harden, if you like i can put up shots of my antenna mod?
    Lucky... its a federal crime and 10,000 fine in the US... (yeah a dirty mirt would make me uuber happy to install in my car)... I could deal with a possible 50 dollar fee... but not 10k =(
    With the IR I just meant that a lot of cameras are able to see IR. (even though the human eye can not). Just be careful at intersections with Caltran cameras (if those are even in CA).
  5. #15
    Feb 2006
    mississauga, On.
    We only have them in the major cities, i work in a rural area and live in a BIG but urban town, no cams like that to speak of, I dodnt realy know what you ment by Caltran? but now i do :P...
    I'm at work now but I'll get some sanding done and take a pic with the screen inthere..., I still have to locate the cd rom...
  6. #16
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    That antenna looks great, I want to try something along those lines, thanks for all the pics.
    1998 Camaro Worklog Starting over, New setup for 2010
  7. #17
    Feb 2006
    mississauga, On.
    if theirs anything that i hate is a work log with no pics ...
    I might just stary on my info screen at the same time as the screen that way i can work on one as the other is drying...
  8. #18
    Mar 2006
    Iowa
    tell me about it
    Where is your info screen going? What will be displayed on it? How big is it?
  9. #19
    Feb 2006
    mississauga, On.
    ok i got a VFD(vacuum Fluorescent Display) from a friend for $20 its a 2 line 16 charicter display
    As it turns out the box was empty???, ok well its a project box now...
    its either going here
    or here...
  10. #20
    Feb 2006
    mississauga, On.
    that trim only cost me $20 and it goes right under the speedo guage in this bend, so it would be right above the steering wheel and beside the digital speedo...
    the screen is going to display song names, times and computer temps when im the gps mode...
  1. Civic SI 07 - NAV Trip Dash Xenarc mounting advice?
    By incudie in forum LCD/Display
    Last Post: 09-25-2007, 05:51 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. Modding 2006 Civic Hybrid Navi - possible?
    By Arathranar in forum General Hardware Discussion
    Last Post: 02-27-2007, 07:44 PM
  4. Software Review: Streeets and Trips 2006
    By Mattkins99 in forum The Review Palace
    Last Post: 11-14-2006, 02:47 PM
  5. 2006 Civic Si keep it stock looking? or outrageous
    By portabuddy in forum Worklogs
    Last Post: 08-05-2006, 11:06 PM
