Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 45
Thread: 2007 Kia Sorento myCarPC project from Brazil
  1. #11
    Constant Bitrate aperali's Avatar
    Aug 2007
    Rio de Janeiro, Brazil
    Idea for my installation
    I'm starting to think how I will install my setup. I'm going to a motorized lcd from a dvd drive unit (as I posted here http://www.mp3car.com/vbulletin/fabr...dvd-drive.html)
    Also I found (down of my nose) the solution for the carpc case... an old desktop cover which fits perffectly into a 2din size (take a look at these photos below).
    Certainly I'll need to cut and make some holes but I don't need to fold or weld anymore.
  2. #12
    Variable Bitrate vladcarpc's Avatar
    Nov 2006
    Sao Paulo, Brazil
    Did you check if the MoBo fits inside that? :-)
    \/ |_ /\ [)
    1995 Civic Sedan EX
    CarPC status: [||||||||||||] 100% - Phase 1 Complete!
    YouTube video - WorkLog
  3. #13
    Aug 2007
    Sure! is an epia mini-itx size and it's smaller than a 2din unit in wide.
    I think will only need to replace my tv/fm card which is taller than a 2din height
  4. #14
    Nov 2006
    Sao Paulo, Brazil
    The same issue I had. Now I am going to buy an USB FM thing... There is a friend going to USA.
    But no more TV (not a prob).
    \/ |_ /\ [)
    1995 Civic Sedan EX
  5. #15
    Aug 2007
    i intended to ask for a hdtv card but unfortunately i couldn't find one which complies with our system here (BR). maybe in Japan we can find one
    my encore tv card cannot be used with such "riser" adapter (L) cause it will touch on memory and others components. Unless I find a flexible one.
  6. #16
    Constant Bitrate will_santana's Avatar
    Mar 2007
    Rio de Janeiro/Brasil
    there's flexible raisers. i've seen it before. but don't know where to find it here in BR. and you can always have a usb tv/fm tunner
    []s
  7. #17
    Nov 2006
    Sao Paulo, Brazil
    Quote Originally Posted by aperali View Post
    There was a discussion about it in CarPC-Brasil forum at Google Groups. Somebody posted this link:
    http://tvgogo.manufacturer.globalsou...V-Receiver.htm
    There are other models (cheaper) too, search.
    \/ |_ /\ [)
    1995 Civic Sedan EX
  8. #18
    Aug 2007
    Thank you! But my mobo has a standard pci slot while most hdtv cards are pci-express :-((
    however, i found an usb one here in Brazil http://produto.mercadolivre.com.br/MLB-65613928-_JM but i'm not sure it will support our isdb-t system though.
    what do you think?
  9. #19
    Nov 2006
    Sao Paulo, Brazil
    The one I posted was not PCI. There are others:
    http://www.amazon.co.jp/GREEN-HOUSE-...6173626&sr=8-1
    Check out the CarPC-Brasil forum in Google Groups, regarding this topic.
    \/ |_ /\ [)
    1995 Civic Sedan EX
  10. #20
    Aug 2007
    Photos from inside of Sorento
    I've used a spoon to open the side panels of dashboard. very easy job!
    and it's different from this one (2003) 2003 Kia Sorento 2.5 CRDI AUT
  1. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 07:32 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
