Results 11 to 20 of 22
Thread: Newbie installing in 93 wrangler - offroad vehicle!
  1. #11
    Sep 2007
    NY
    Okay all the parts are here, actually everything minus the Opus, but that can wait anyway. They came in on Friday, I quickly got to work hooking everything up and downloading the latest drivers. The only thing that gave me some issues is RR kept wanting to reload Iguidance when I clicked on GPS, which caused it to give me an error saying I had no signal, when infact I did but the other instance of Iguidance was using it. Here are some pics... I just noticed I don't have one of the GPS yet, but I will get it and put it up...
    Project Page - 1993 Wrangler Jeeputer
    Progress Meter {**-------} 15% most of the parts are in or have been ordered... Assembly has begun!!!!
  2. #12
    Sep 2007
    NY
    Now I am having huge fabrication issues - basically they are that I can't start because I don't have a solid plan, it keeps changing every 10 minutes.
    Now I don't know if I want to use wood or fiberglass, maybe I just need to suck it up and use fiberglass..
  3. #13
    Sep 2007
    NY
    Okay - so for the few who are reading this thread... the answer I came up with was to scratch the lower dash install and install the lilliput in the soft vinyl covered part of the top of the dash. I ordered the part and it should be here next week sometime. My biggest concern is glare at the moment, plus I read somewhere that the foam shriks after a while when it has been cut.
  4. #14
    Oct 2007
    WA
    I look forward to seeing what you come up with in your Jeep. Keep the posts coming.
  5. #15
    Sep 2007
    NY
    Quote Originally Posted by wplate View Post
    I will - I have the dash coming in the next few days, probably monday or tuesday. Once that comes I will be doing some real fab work. Once that is done I just need to run power to it and I should be all set... hopefully in the next few weeks it will be "done"... Then I move on to the next car, this one is just for learning purposes and fun. I am looking into different rocker switchs now. I still have to learn more about doing the electric, I can't seem to find what fuses to use and what gauge wire to use.
  6. #16
    Sep 2007
    NY
    Dash is in - I am having a little nervs cutting into it, so it has been sitting in the garage all day :-) Tomorrow will be cutting day :-) I measured like 5 times, but couldn't even get myself to mark out where I need to cut. My OPUS came in too, but it was missing some parts, so the guy is looking for them and sending them over now.
  7. #17
    Variable Bitrate 0okami's Avatar
    Feb 2006
    USA
    Quote Originally Posted by underwaterdan View Post
    more pics ^_^
    ~0okami.Digital
  8. #18
    ysk
    ysk is offline
    Oct 2007
    I have a full cage in my YJ so mounting the 8" Lilliput to the spreader was easy, I put an opus behind the glove box to run the Lilliput, a USB hub and to sequence the CF28 under the rear seat
    Ran this for about a year, never any problems with the HD
    Similar setup in my TJ, but I mounted the Lilliput up high and a D210GLY in a Voom case between the overhead spreaders
    Lots of hard wheeling. no problems (yet) with 2.5 inch drives
  9. #19
    May 2008
    final word?
    Hey.... what was the outcome of this project? and post some pics!
    I really want to know how it turned out.
    thanks!
  10. #20
    Feb 2006
    USA
    Quote Originally Posted by washurjosh View Post
    thanks!
    Same here since im buying a jeep and selling my eclipse!
    ~0okami.Digital
  1. Newbie installing Mac Mini et al.
    By kkachurak in forum Newbie
    Last Post: 03-30-2008, 03:07 AM
  2. Installing Logitech Z-560's into my vehicle
    By fatmanmitch in forum Car Audio
    Last Post: 07-16-2006, 06:54 PM
  3. Article: Privacy of vehicle information being debated
    By VanMan69 in forum General MP3Car Discussion
    Last Post: 03-15-2005, 03:59 AM
  4. Replies: 2
    Last Post: 07-10-2004, 08:58 AM
