Results 1 to 10 of 10
Thread: 2000 Dodge Durango - Car PC/New Audio/Complete Dash Fab.
    Oct 2007
    I've finally decided to start my project. I drive a 2000 Dodge Durango SLT and I love it. I've been a lurker on the forums for around a year now and it's always interested me.
    My full customization will include:
    STAGE 1
    • Research/Design/Construct custom dashboard
    • Build/Install Car PC
    • Install 4ch amp and new door speakers
    STAGE 2
    • Build custom sub box for 2 (hopefully 4) 12" Subwoofers
    • Design/Construct new center console to house Car PC
    STAGE 3 (If Possible)
    • Find/Buy Grey/Black interior of 2000-ish durago to replace stock tan
    • Design/Construct Digital HVAC
    For the dash customization, I need to work around the passenger-side airbag, any thoughts on how to do this?
    Wish me luck!
    Oct 2007
    Front Mockup
    Heres a rough mockup of what the dash will look like. I plan to do a MDF/fiberglass build with brushed aluminium accents on both the dash and center console. It's designed similar to the Chrysler 300 and the new GMC Yukon that I've seen
    How should I work with the passenger airbag? I hope it doesn't go off while I'm working!
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    Where are you located?
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
    Oct 2007
    Quote Originally Posted by proph View Post
    Good ol' Michigan
    Oct 2007
    Here's a revised version of the dash mock up. I relocated the air vents to separate the driver and passenger air.
    Oct 2007
    I've decided to revise my order of attacking this project. I'm probably going to do most of the audio work first. Then I'll start the custom fabrication of the new center console before I attempt the dashboard and doors.
    Oct 2007
    socal
    A cheaper way is you can hackoff part on your 1.5 din to make an 7' lcd fit. That what I did with my 2000 durango. good luck
    Aug 2010
    Quote Originally Posted by kevilution View Post
    I am planning a custom project of my own. Did you ever finish your project?
    T...
    Nov 2009
    To help keep your airbags from blowing up in your face, disconnect the negative terminal off your battery. Sure you will have to reprogram the presets on your radio when you are done but its better than getting your head taken off by your airbag
    For those who serve, life has a special flavour the protected will never know.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by nxsanex1 View Post
    T...
    Quote Originally Posted by eightball009 View Post
    Talk about thread revival.
    Anyways here is my Durango. i simply had the radio slot made to a double din and intergrated the screen fully built so it looks like a head unit.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  3. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  4. Replies: 19
    Last Post: 10-27-2005, 12:53 AM
  5. Installing car PC in 1996 Honda Civic
    By PredatorCoder in forum Newbie
    Last Post: 08-18-2005, 08:58 AM
