Results 21 to 30 of 34
Thread: 1993 ford ranger Regular cab
  1. #21
    Jan 2005
    Also I have a new instrument cluster to go in with tach just have to get a few days off in a row so i can have both of them side by side to change the wiring harness. I also picked up a 98 steering wheel with hvac/stereo/cruise to put in but am waiting on my machinist to get done with it he is trying to change the tilt column to match the wheel as i was unable to get a column from a 98 and they changed the end of the shaft sometimg between 90 and 98.
  2. #22
    Jun 2008
    Camden / Australia
    good looking build, i love how clean you've gotten everything to sit so far looking forward to the final product
    1993 Mitsubishi Verada
    My Ride
  3. #23
    Jan 2005
    thanks I like yours as well
  4. #24
    Jan 2005
    here is is all painted and installed I will post another pic after i get the cables ran and the LCD installed
  5. #25
    Dec 2008
    Like the colors I will try and get pics of my truck and kind of the setup i want to do in it photoshopped up.
  6. #26
    Jan 2005
    well here it is mounted with the LCD installed however due to my bad luck it works but without a touchscreen as i broke the dang glass however I can test it fully as I am waiting to see about replacing my m2atx as I must have gotten a bad one
  7. #27
    Dec 2008
    Looks good, how'd you break the touchscreen?
  8. #28
    Jan 2005
    apparently when i molded the bevel i warped it a little it was tight i went to work it in i put to much force on it and heard a nice cracking sound thankfully I didn't hurt the LCD
  9. #29
    Jan 2005
    well I know I havn't updated in awhile as I had to get anew motherboard I had everything in and the board decided to kick the buckets I picked up a board today so I hape to have some updates in the next day or two
  10. #30
    Jan 2005
    well i started hooking everything backup on the work bench and I only have a draw of 4.8amps from the m2-atx
    now I just have to finish configuring all the software again
  1. 2003 Ford Ranger FX4 Install (Lots of pics)
    By tbird2340 in forum Show off your project
    Last Post: 10-12-2009, 11:21 AM
  2. wiring diagram for 1987 ford ranger
    By ydnar1955 in forum Newbie
    Last Post: 09-27-2006, 07:22 AM
  3. Possibly FS: 2003 Ford Ranger FX4 - LOTS OF MODS!
    By tbird2340 in forum Classified Archive
    Last Post: 07-05-2005, 11:59 AM
  4. 1996 Ford Ranger - Suggestions on Sound Setup
    By Mrbmw99 in forum Car Audio
    Last Post: 11-10-2004, 02:47 PM
  5. 1996 Ford Ranger w/M10000 & Xenarc
    By parawing742 in forum Show off your project
    Last Post: 01-30-2004, 07:37 PM
