Results 1 to 10 of 12
Thread: 2007 Ford Fusion
    Newbie arturusfury's Avatar
    Oct 2007
    Columbia, Missouri
    2007 Ford Fusion
    This is my first carPC and my first new car as well. Week or so ago I bought a new 2007 Fusion and so far have loved it, just wished it had navigation and the ability to play DVD's. I had been watching the forums here for ideas long before I actually got my new car and I was mostly waiting until I did get something newer (Past car was a 2000 Focus, didn't look too good for a car PC install) and "better".
    I have all of my parts ordered ... i think, and have been assembling them at home. I snapped a few pictures of the car and everything before I get started, one thing I'm going to be paying major attention to is making sure I can take everything out easily and return the car to a stock look if I ever decide to sell or trade it in.
    Well that was a long time ago, after much heartache and plenty of stops and restarts, here we go again ...
    I scrapped most of my earlier ideas as the 8" screen just wasn't going to work without some custom fabrication which I just wasn't comfortable with yet.
    Mobo: Intel D201GLY Little Valley
    Proc: Onboard 1.33GHz Celeron
    Ram: 1G DDR2 667
    Screen: Lilliput 7" EBY-701 (Premounted Double-Din Kit for Fords)
    HDD: 120GB Western Digital 2.5" 5400RPM
    PSU: M2-ATX HV
    DVD: None as of now
    GPS: BU-353 GlobalSat GPS USB Receiver
    WLAN: EnGenius EUB-362EXT 802.11g
    Case: 4th Gen Mini ITX Case from Mobile Computing Solutions
    This is just a few before pictures of the car:
    2007 Ford Fusion SE (SOLD)
    2010 Mazda 3 Sport 5 door
    Oct 2007
    Columbia, Missouri
    Cleared all my old pictures out as they weren't going to have much to do with the new install, but I'm gonna post more stuff here later
    PC Stuff:
    Coming Soon
    Audio Stuff:
    So I'm going to be getting a 4ch amp sometime, gotta find a decently priced one that still puts out good power. I'm following in the footsteps of fusion fanatic a little by mounting two 6x9's in the rear deck of the fusion. There are spots for them to go, just nothing there. So I'll wire the rest of the factory speakers in series, and the 6x9's in parallel, should give me plenty of sound and I may not even need to install a sub in my trunk.
    Car Radio Accessory Switched 12v+ Wire: Green
    Left Front Speaker Positive Wire (+): White
    Left Front Speaker Negative Wire (-): White/Brown
    Right Front Speaker Positive Wire (+): White/Purple
    Right Front Speaker Negative Wire (-): White/Orange
    Left Rear Speaker Positive Wire (+): Brown/Green
    Left Rear Speaker Negative Wire (-): Brown/Yellow
    Right Rear Speaker Positive Wire (+): Brown/White
    Right Rear Speaker Negative Wire (-): Brown/Blue
    Wiring from Amp -
    + of Amp -> White (Left Front +)
    White/Brown (Left Front -) -> White/Purple (Right Front +)
    White/Orange (Right Front -) -> Brown/Green (Left Rear +)
    Brown/Yellow (Left Rear -) -> Brown/White (Right Rear +)
    Brown/Blue (Right Rear -) -> - of Amp
    Constant Bitrate moboman's Avatar
    Sep 2007
    Cincy, OHIO
    Wow, those new fusions are nice looking cars.
    So, how were you going to mount everything in your trunk? Were you going to put the shuttle right next to your sub box?
    Nice project so far.
    My Worklog
    I'm using my carputer 100%, but I still need to make it easier to use.
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    dude
    i'm subscribing to this thread to follow it.....
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    just a thought- cut a block of your favorite foam to fill the factory opening there, and use your favorite tool to sand/cut/shape it perfectly flush to the factory bezel face, then laminate a sheet or two of real carbon fiber over the whole thing, covering foam, opening, and all. Then just be accurate and careful and retrim all the openings, particularly the one small enough to match your lilliput...
    In fact, if you are paying close attention to the cure of the resin, you can actually cut the opening with a template and a very very sharp x-acto knife when the resin has kicked enough to hold the fibers solid, but not cured so hard it can't be sliced easily. You might experiment with some test pieces (fiberglass, not carbon for economy's sake) before you commit to the pretty one.
    Then you don't have cheesy sticker carbon, and solved your screen issue. It should look OEM+. If you want the high gloss then probably the easiest thing for a beginner to do would be to go find a couple cans of Deft clear lacquer (easily had from Lowes/Home Depot) and just go in light layers until you start to build up a gloss. It can be polished out with light sanding (600-2000) and rubbing compounds.
    Thoughts?
    *edit* actually, if you don't want to do it yourself but like the idea, i'll do it for cost of materials and shipping. Looks like a fun project.
    Aug 2006
    New Ro, NY
    sweet.........looking good so far!!!!
    if i may make a suggestion:
    why not tie in your pc into the AUX of the factory radio? You'll get perfect quality sound....
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
    Sep 2007
    Cincy, OHIO
    because then he still has to have the headunit in his car. That was my plan originally, because I have an extra JVC KDG-230 which has an aux in. Then I got to thinking and thought that I'd rather not have a head unit and just let the computer equalize and power my amps. Also a nice amplifier sounds much better than the factory headunit, as well as being able to have more power.
    Another question would be where to put the factory headunit? He put a monitor in the dash.
    My Worklog
    Aug 2006
    New Ro, NY
    hmm. if the factory system sucks, i agree. but if you're out to save money and extra work:
    - place the unit in aux
    - connect pc
    - enjoy
    assuming of course the speaker and such will work without the head unit. i'm thinking the answer is "NO".....
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
    Aug 2006
    New Ro, NY
    any updates on the project? breakdowns? breakthroughs?
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
    Variable Bitrate rijndael's Avatar
    Apr 2007
    Florida
    Quote Originally Posted by afterdigital View Post
    yeah...anything new? my girls new car is the Fusion, and she wants me to put one in her car. Any news?
    Trouble deciding on car speakers? Clicky Clicky
    My Myspace page (view my pics for carputer worklog...needs updated)
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  3. Newbe - Ford Fusion
    By arup_deep in forum Newbie
    Last Post: 08-12-2007, 06:21 AM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  5. 2006 Ford Fusion Carputer
    By fusionman06 in forum Newbie
    Last Post: 10-21-2005, 01:05 PM
