Big news, the carputer is going to go live this weekend!!!!
As of this moment, the computer is working, and im just installing and configuring software. The front end will be RR.
Here is the progress so far.
I wanted some ports on the front dash so i could connect usb and stereo connectors from inside the car. I thought it would be a great mod to install ports from a computer case. These ports connect directly to headers on the mainboard.
With my tv/radio card, i will be able to listen to fm and watch tv. Plus, it has a recording feature, and i hope to set up the radio with tivo-like capabilities. Hopefully i will be able to pause/record and skip commercials with the right interface.
Here is the computer case so far. I still need to mount a top to the case. The hdd will be mounted below the top and the dvd drive will sit above the case. I still need to cut a slot for the dvd drive, but that is later. I will also mount a 4-port usb hub so that all the usb connections will be utilized.
List of usb connections: Dvd drive, Touchscreen, GPS
List of todo: Paint the bezel, finish the case, cut slot for dvd drive.
Then i can mount and install it. I hope i can interface the pc and car in less than 1 day. It would suck where i have to drive the car without a dash. Im hoping the interfacing goes smoothly.![]()
LinkBack URL
About LinkBacks
