I tweaked the desktop theme, increasing the font. It helps out with Rhythmbox and the touchscreen:
I've been messing around with virtual keyboards. I like matchbox-keyboard and Florence. They both detect when an input box gains focus and automatically pop up. Unfortunately, they require the Accessibility feature to be turned on, which causes this bug on Rhythmbox. So I ended up using xvkbd:
It doesn't come up automatically, so I added the icon on the top panel. The default layout for xvkbd needed to be changed to be more useful with the touchscreen. To get the layout in the screenshot, I added the following to my .Xdefaults:
Code:xvkbd.windowGeometry: 780x280+10+300 xvkbd.compact: true xvkbd.modalKeytop: true xvkbd.*Alt_R.width: 1 xvkbd.*Meta_R.width: 1 xvkbd.*Caps_Lock.width: 45 xvkbd.*Multi_key.width: 1 xvkbd.*Shift_R.width: 75 xvkbd.*Control_L.width: 30 xvkbd.*Alt_L.width: 30 xvkbd.*Meta_L.width: 30 xvkbd.*Focus.internalWidth: 0 xvkbd.*Focus.bitmap: /usr/include/X11/bitmaps/target xvkbd.NormalKeys: \ F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 Delete \n\ Escape 1 2 3 4 5 6 7 8 9 0 - = \\ ` \n\ Tab q w e r t y u i o p [ ] BackSpace \n\ Caps_Lock a s d f g h j k l ; ' Return \n\ Shift_L z x c v b n m , . / Multi_key Shift_R \n\ MainMenu Control_L Alt_L Meta_L space Left Right Up Down Focus \n\ xvkbd.ShiftKeys: \ F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 Delete \n\ Escape ! @ # $ % ^ & * ( ) _ + | ~ \n\ Tab Q W E R T Y U I O P { } BackSpace \n\ Caps_Lock A S D F G H J K L : \" Return \n\ Shift_L Z X C V B N M < > ? Multi_key Shift_R \n\ MainMenu Control_L Alt_L Meta_L space Left Right Up Down Focus \n\ xvkbd.KeyLabels: \ F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 Del \n\ Esc !\n1 @\n2 #\n3 $\n4 %\n5 ^\n6 &\n7 *\n8 (\n9 )\n0 _\n- +\n= |\n\\ ~\n` \n\ Tab Q W E R T Y U I O P {\n[ }\n] Back \n\ Caps A S D F G H J K L :\n; \"\n' Return \n\ Shift Z X C V B N M <\n, >\n. ?\n/ Com\npose Shift \n\ MainMenu Ctrl Alt Meta space left right up down Focus \n\ xvkbd.NormalKeyLabels: \ F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 Del \n\ Esc 1 2 3 4 5 6 7 8 9 0 - = \\ ` \n\ Tab q w e r t y u i o p [ ] Back \n\ Caps a s d f g h j k l ; ' Return \n\ Shift z x c v b n m , . / Comp Shift \n\ MainMenu Ctrl Alt Meta space left right up down Focus \n\ xvkbd.ShiftKeyLabels: \ F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 Del \n\ Esc ! @ # $ % ^ & * ( ) _ + | ~ \n\ Tab Q W E R T Y U I O P { } Back \n\ Caps A S D F G H J K L : \" Return \n\ Shift Z X C V B N M < > ? Comp Shift \n\ MainMenu Ctrl Alt Meta space left right up down Focus \n\
LinkBack URL
About LinkBacks
