Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: 2007 Honda Fit - In Dash
    Sep 2007
    My plan is to install a car PC inside the dash of my 2007 Honda Fit. Here's what I have so far:
    • VIA EPIA-CN10000EG 1GHz Mini-ITX Motherboard
    • 1GB DDR2 533 PC2-4200 Memory
    • D-Link DWL-AG530 Wireless PCI Adapter 802.11 AG 108Mbp
    • GlobalSat BU-353 USB Sirf III GPS Receiver
    • Scosche Dash Kit
    • M2-ATX DC-DC ATX Power Controller
    • AMP9 Amplifier kit 14.5V max, low profile (in the mail)
    What I need:
    • 2.5" SATA Hard Drive
    • 7" Touchscreen
    • Radio tuner
    • Case (will probably custom build)
    I'll be using LinuxICE for the OS and nGhost as the front end. I'm thinking of using Roadnav for GPS navigation. I borrowed a hard drive to get the system up and running for development. Wifi, GPS, and multimedia all seem to be working fine.
    I opened up my dash to make sure there will be enough room to fit everything. It looks promising.
    First I removed the glove compartment to mark and remove the air control cables:
    Pulling the head unit out was not easy. There are seven clips holding the unit in the dash. Following everyone's advice I had to force it out by pulling from behind the AC controls. It felt like I was going to break it, but it eventually popped:
    Here's a closer look:
    With the dash kit in place:
    It looks like there will be enough room. After a few measurements I figured the maximum dimensions to fit a slide in are about 7.5" wide by 4" high by 8.25" deep (from the back to the dash kit). Plus, there's a few inches up top where I should be able to fit the AMP9 and maybe the M2-ATX on a small shelf.
    I hope to make my final purchases and finish the install by the end of the year.
    Oct 2007
    Good Luck!
    I am working on a 07 Accord myself, but I am going to try and install the touchscreen in the CD storage bin under the stock radio, you can see my work log in my sig.
    Sep 2007
    Thanks! It looks like you're well on your way. My amp showed up in the mail yesterday. Time to fire up the soldering iron!
    Here's a mockup of a frontend skin my friend made for me:
    Oct 2007
    Oh that mock up looks real nice I would be interested in testing it with you
    I've given up on the idea of keeping the door on the lower bezel I'll just mount it in there I do not want to take apart the liliput!
    Sep 2007
    I picked up a Lilliput 7" touchscreen (EBY701). It's working well, but I can't get a hold of the BIOS update for my MB (EPIA CN10000EG) to support 800x480...anyone know where I can get it?
    I also ordered the hard drive. I went with a 2.5" Toshiba 60GB SATA (5400 RPM). I should be receiving it tomorrow.
    Here's a shot booting LinuxICE:
    The nGhost frontend:
    The music interface:
    I started wrapping the toriods for the AMP9. The wire I received is 0.6mm, so each core requires 52 turns. One down, seven to go:
    Sep 2007
    Over the Christmas break I went to work on the amplifier. The good news is that I wrapped the remaining toroids. The bad news is that the one I wrapped a few weeks ago walked away. I'm suspecting that my three-year-old found it too shiny to resist. I'm in the process of getting a new one.
    I picked up some sheet metal today and hacked up the case. First I did a little snipping:
    Then I got "creative" with pliers, a hammer, and even a brick:
    It's not pretty, but it should work. For the dimensions, I went with 7.5 x 6.75 x 4. The depth is 6.75, which will just fit the MB and will allow the screen to fit in front with no modifications. The opening will be to the right as I slide it in the dash.
    Newbie Jetta_4_TDI_R's Avatar
    Jan 2008
    Celbridge, Ireland
    Looking good up till now keep it up looking forward to seeing the finished product
    Jan 2008
    Wow. That's a nice frontend skin
    I really like the frontend skin. I'm watching this log intently as I am also interested in embarking on a carputer project this year.
    Keep up the good work.
    John
    Sep 2007
    Quote Originally Posted by johnstof View Post
    Hopefully we'll be seeing more of it soon
    Jan 2008
    California, USA
    I hope you finish your project soon because my project is pretty much exactly the same. I have a 2008 Honda Fit (same as 2007) and I bought the same touchscreen. I want to see how your carputer turns out before I start taking my car apart.
    Keep up the good work!
  1. S-10 Install,In progress,baby steps,first rip apart dash :)
    By pRoFiT in forum Show off your project
    Last Post: 05-17-2007, 02:49 AM
  2. 3rd Time's the Charm??? Mercury Cougar Dash Lilliput
    By antimatter in forum Fabrication
    Last Post: 08-07-2006, 12:21 PM
  3. Honda Jazz (Honda Fit), help!?
    By abitcrazy in forum Newbie
    Last Post: 07-11-2006, 09:51 AM
  4. pocket-size PC...would fit in dash
    By Meatballman in forum General Hardware Discussion
    Last Post: 04-19-2000, 03:33 PM
