Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Golf MKIV - Indash Screen and Computer
  1. #11
    Oct 2007
    Vancouver, BC
    Some more
    Mounted the power supply
    I had to mess up the PS2 connector in order to fit the mini-itx board in the dash, i recommend a nano-itx board for an easier fit ! (FYI, mini-itx board will fit nicely if the LCD stand isn't used)
    Glove box setup ideas:
    Now here how i wire the 12v wire ( the wire is 10 gauges, the fuse in the fuse holder is 20amp)
    I wire an additional 10 gauge wire to the negative pole to act as a PERFECT ground (i can also use this cable next time if i need more power )
    The 3 wires that you will plug to the power supply (positive / negative / ignition wire that will connect to the 75X connector in the photo below)
    I tried to boot the PC in the car using the m2-atx power supply and the newly installed wires but it was a no go. The CPU fan turn a bit every few second while car is off and turning the key in ON position didn't fire up the PC (i check all the connectors twice and made sure the ignition wire was properly plugged on the power supply -> 75x and power supply -> motherboard jumper, any idea guys ?
  2. #12
    Sep 2006
    The intarwebs
    sure your battery is charged enough?
    Planning {[][][][][][][][][][]} 100%
    Funding {[][][][][][][][][][]} 100%
    Construction {[][][][][][][][][][]} 60%
  3. #13
    Nov 2007
    did you check the fuse on the power wire?
  4. #14
    Nov 2006
    start the car?
  5. #15
    Oct 2007
    Vancouver, BC
    Quote Originally Posted by Mylt1 View Post
    no, but if fuse is blown, no power should comes through, no?
    battery should be full
    this seems to be a problem with the PSU by reading this thread
    http://www.mp3car.com/vbulletin/powe...w-seconds.html
    ill contact the reseller for an exchange
  1. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 03:19 PM
  2. FS:7" Screen, Computer, etc.
    By rscultho in forum Classified Archive
    Last Post: 10-27-2006, 02:59 PM
  3. can i hook up a computer to my touch screen indash tv?
    By staysixsixsixki in forum LCD/Display
    Last Post: 03-01-2006, 11:52 PM
  4. Bezel and Screen Holder for Golf MKIV
    By logike30 in forum Newbie
    Last Post: 02-26-2006, 02:55 PM
