Results 1 to 7 of 7
Thread: 1986 Holden VL Calais- Yr 12 DT project
    Newbie HOLDEN4life's Avatar
    Jun 2007
    Sydney Australia
    have been a looker for quite a while here now its time for my turn
    if in wrong section sorry, move if necessary
    alright I'm gonna have a crack at this but before i do anything i need to do a project portfolio for school as I'm doing this for my major project I'm currently up to the Action plan and evaluation this is where i need Your help what i need from this wonderfully forum is to give me negative and positive (mostly ) comments about what I'm doing and steer me in the rite direction
    the carpc it self will consists of ---will update this spot soon ---
    probley run a 7inch touch screen Lilliput
    enclose car PC in boot with sound equipment
    carpc will only run MP3 and DVD's for now probley get gps etc later on (not sure)
    all be run of carpc don't wanna wire up though head deck
    heres the car its going in
    this is my idea
    (sorry bout the crappy photo chop)
    from this
    to this (similar not exact the same ) EDIT CHECK POST 3
    and this is what I'm thinking for boot
    Idea for Carputer in the design process
    My 1986 Holden VL Calais
    Oct 2004
    Sydney, Australia
    hahaha, defenetly wont fit there mate, you even squished the chop to fit. Welcome to the forums, im not much of a VL fan but yours is pretty stock so its ok. Good luck with the install.
    Continued Worklog... Upgrades in progress:
    *15.4" WXGA LED backlight touchscreen upgrade
    *Custom fiberglass dash bezel
    Jun 2007
    Sydney Australia
    did one a bit better
    anyway forget about those pictures what you's think of this quick drawing in illustrator (not to scale )
    Oct 2004
    Sydney, Australia
    the 7inch panel takes up a double din space, then also button space if your keeping them. You would fit a 7" LCD in the black dash area but thats it.
    Jun 2007
    Sydney Australia
    ahhh thats perfect then
    check out the pic of the dash got all that space in front of the manual boot to use for switchs etc
    Maximum Bitrate Jarrod's Avatar
    Jan 2002
    Melb, Australia.
    I used to have a VL and was planning an install for it back before 7" screens were affordable over here. So I have a soft spot for VL's, especially calais turbos
    I suggest taking some measurements of the actual screens you want to use (im sure measurements can be found on ebay/manufacturers sites/this forum) and then measuring the dash. Much easier to plan when you're not just guessing.
    Jarrod - Holden VX S!
    Jun 2007
    Sydney Australia
    whoops thought i added measurements lol
    its
    250mm H
    190mm L
    135mm D
    and thats the black area in the dash
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  2. Holden VL Calais Mounting Suggestions
    By Nitrojunkie in forum General MP3Car Discussion
    Last Post: 01-16-2004, 05:41 PM
  3. Holden VL Commodore -> MP3IAN MkII
    By MP3IAN by Ian Gregory in forum Show off your project
    Last Post: 11-09-2002, 10:46 PM
