Can you tell me which screen you plan to use/using, and if you needed to mod the double din at all.
Hardware:
1 Mac Mini 1.83 GHz Intel Core 2 Duo
1 1GB Memory
1 WD 3.5" 500GB 7200rpm SATA 3.0Gb/s HD
1 CRN-2140 Power Supply
1 MacPac Power Kit
2 I-Rocks Black USB Hubs
1 Internal Bluetooth
1 Internal Wi-fi
1 BU-353 GPS Receiver
4 Rosetta White LED Fans
1 Apple Bluetooth Keyboard
1 Apple Mighty Mouse
Labview Controllers
Software (as of now):
Mac OSX
Labview 8.0
Don't have the car yet but I'm doing the computer set up first so I can install it right after I buy it.
The setup ideas are pretty simple. I'm placing as many things as I can into the glove box while retaining the simple appearances. Front of the glovebox will be face with a white plastic material that looks similar to the plastic Apple uses on all of their desktops. The theme of the car is black&white. Car and interior will be black and all lighting on car will be white. The plastic used on the face of the glovebox will be backlit with white cathodes. I will be ordering a glovebox from a 2008 WRX so I can get to work on that early as well as a spare dash unit so I can mold a screen.
Also, I want to motorize nearly every moving item in the car so I can get some practice with making custom mounts. Rear passenger door handles will be shaved off and door actuator poppers will be installed instead
Motorized projects in car:
Rear door - 12 V DC Linear Servo Motor
Back Seat - 12 V DC Rotary
Passenger Rear Doors - 12 V DC Linear Servo Actuator
Glovebox - 12 V DC Rotary Motor + cable
(Whatever else thought of in the future)
Everything will be controlled by Labview 8.0 in my computer and the external NI controllers.
I'm still in the market looking for a good FrontEnd and GPS software.
The reason for putting this challenge ahead of me is because I'm majoring in Mechanical & Electrical Engineering at Kettering University and I'm looking for an application. Some of my friends from TRW Automotive in Auburn, New York will be assisting me in the designs just to give them some credit. I'll name names once I'm done with designs.
I'll get some pictures up once I get home.
___________________________________
1996 Accord Ex Carputer
Soon to come 2008 WRX 5-door Mac-carputer.
I'm doing an 08 WRX install too, but in the opposite order. (I do have the car, but do not yet have the computer...) I can tell you, the double-DIN slot is nice and big (about 4" x 8") and has a ton of space behind it and even to the sides. I just ordered a Lilliput EBY701 and I'm hoping to mount it behind the car's bezel without modification. (It's over $100 for a replacement bezel... probably because the air vents are built in.)
I'm interested to see the progress on this (these) project(s). Be sure to post back!
Oh, and FordNoMore - if you haven't yet seen it, check in the store for vehicle-specific, and look at the WRX mechronix housing. I would assume it would still work for the '08's.
CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
Actually, maybe you could tell us if the 2007 mount will fit. Here are some pictures from my "exploratory surgery". It looks a little different to me than the pictures in the MP3Car store, but it's hard to tell.
Also, as a tip for '08 bezel removal: Start at the top! It's extremely flush, but I got it by sliding a piece of paper under the corner... then two pieces, then three, then four... Finally a small screwdriver or trim-puller. The top clips pull straight out, but the bottom ones have to be unlatched. I'll post lots more info once I start my own worklog.
Well, it looks as if it should fit. Here's the specs for the bezel - see if your side clips will line up:
http://www.mechatroniks.com/wrx/cad/kit1.pdf
Oh yea, its Mechatroniks, not Mechtronix![]()
Thanks, I hadn't seen the CAD drawings. So, this just bolts in to the regular DIN mounts then? That's cool - I thought it bolted straight to the car, and I didn't see the two offset mounts like there are on my stereo. Hmm... I was going to make my own custom mount (which I may still do for cost savings), but this is giving me second thoughts. Thanks for pointing it out.
So what's the verdict? will the wrx kit fit? I've got the 08 5 door too. I'd like to install a pc in there but i've never done anything with car stereos before.
I know my comps though.
It looks like the kit fits the standard DIN mounting holes, BUT check out the front panel dimensions listed in the PDF referenced above. Says the front is 4.275" x 6.790". I measure a 4" x 8" opening on our stereo. A little over 4" tall, but definitely not 4.275", so it'll take a little modifying and you'll have a big gap on each side.
I'm going custom anyway, though, so I don't plan to order one. Good luck. And enjoy your new ride.![]()
hmm.... interested as well. Planning on an 08 WRX in the next few weeks, have been trying to figure out how i'll transplant my laptop install to this car.
Current Rig
Inspiron 5100 Laptop
*2.2 Ghz CPU
*368 MB Ram
*32meg OnBoard Vid
Carnetix 1900 PSU
BU-353 GPS Antenna
iGuidence Nav Software / Mappoint for POI's
Linksys USB WiFi
D-Link USB Bluetooth 2.0
Xenarc 700IDT
Eclipse CD4000 HU
