Page 5 of 10 FirstFirst 12345678910 LastLast
Results 41 to 50 of 92
Thread: Evo-puter In-dash WIP
  1. #41
    Apr 2008
    Just one simple question, How did you connect the M2-ATX to wall adapter. I have a similar PSU, and got no idea how to hook them together.
  2. #42
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    I bought an adapter on ebay for like 10 bucks. It is basically just a laptop AC adapter, but the cord is cut and the wires inside (12V, GND) have connectors attached at the ends. Then the 12V is spliced into 2 cables so that I can connect and disconnect one of them to simulate ACC (ignition).
    I actually just got a DSX12VD power supply to replace the M2. There is nothing really wrong with the M2, it just wasn't appropriate for my motherboard and I was jumping through hoops to get it to work. I will use the M2 on my second build.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  3. #43
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by mightycrown View Post
    There's another way that I use to power my M2ATX -- and other 12V things -- on wall power. If you have anything with a cigarette plug, chop off the plug and cable, and connect the cable to your M2ATX. Plug the cigarette adapter into this device:
    12V Adapter
    Some time back, I bought one of the Coleman thermoelectric heating/refrigeration units that keeps food hot or cold, depending on which way you run the power. It came with a 120V to 12V adapter with a socket for a standard lighter plug. Very useful, and it'll run a load up to 5A. Here's the way it looks:
    Click on the image to enlarge it.
    Coleman sells the adapter alone for about $40 on their site, but they're available elsewhere for $25. Lower-amperage units are even lower cost.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  4. #44
    Jun 2007
    looks like it's coming together pretty good
  5. #45
    Apr 2008
    Thanks both of you, contribute your ideas. I have a dell GX270, as we know dell always have their special plugs. Anyway goodluck with your project. looks pretty awesome!
  6. #46
    Mar 2007
    Socal
    UPDATE:
    - New case from Bybyte.com is ready. I drilled and tapped all the mounting holes for my MB and PSU.
    - Made a new VGA and USB connector for my touchscreen that is only about 8" long. I also separated the two rather than have that lame Lilli cable.
    - Got a new low-profile right-angle SATA cable because the standard one's big connector was resting against the LCD controller.
    - Got the DSX12VD power supply to replace my M2-ATX. This thing works nice and shutdown and startup are working nicely now.
    - Had to make some new shielding for the VGA cable and ground the shielding due to VGA noise.
    Case is all together and running great.
    TODOs:
    - New mounting bracket so the case won't rattle in the dash.
    - New bezel (to be made from Epoxy stuff by me) for the new enclosure.
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  7. #47
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    Good for you man. I say, reinvent the wheel, and everything else too!
  8. #48
    Mar 2007
    Socal
    Some pics. Criticism welcome.
    This is the new VGA connector for my Lilli:
    I want to do some more cable management but it is not critical...
    New SATA and molex power cables coming soon.
    I don't think I've reinvented stuff so much as customized it to be an efficient space saver.
    Unless you count my front end (not pictured), that's totally reinventing the wheel! Although I don't think any of the other front ends have built in navigation. They all seem to use third party. I wrote my own nav software that is completely integrated using OSM maps.
    Still has a couple bugs, though...
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  9. #49
    Mar 2007
    Socal
    Right angle SATA cable came in the mail today. New power cable adapted to poer my HD Radio (Visteon)
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  10. #50
    ClockWorK's Avatar
    Oct 2003
    Michigan
    I've never heard of OSM Maps. Now that I'm doing a little research, I see that I was looking for something exactly like this about 6 months ago. I even looked into using US Census Bureau maps, because I wanted to write my own mapping software. I just couldn't find free access to all of the maps in a usable format.
    That front end looks really good too.
  1. Help on custom dash for Caddy STS
    By Slaughterhouse in forum Fabrication
    Last Post: 12-14-2006, 07:47 PM
  2. 2000 Honda Civic Dash LCD intigration
    By pcmofo in forum Fabrication
    Last Post: 03-20-2006, 12:09 AM
  3. 2003 Altima Dash Fabrication
    By in4no in forum Fabrication
    Last Post: 02-11-2005, 11:51 AM
  4. Sanding dash, need help!
    By mazda3uzr in forum Fabrication
    Last Post: 12-22-2004, 06:27 PM
  5. In dash or Not in dash that is the question
    By belezeebub in forum Fabrication
    Last Post: 12-10-2004, 06:18 PM
