Slot-Making Update
I got a couple of answers to my "How Do *You* Make Slots?" question in the Fabrication forum. As promised, here they are, with my replies:
Originally Posted by
kibble
I just do what you do but I make the openings a tiny bit smaller than actually needed. Then I get a smooth file and carefully remove material until I get it to the size/shape I want. Haven't come up with a better way to do it without the big tools, yet. :-(
I agree. My standard technique in metalworking is to go a bit oversize, and file to the dimension I want. On holes, I go undersize, like you, and file to the size I want. A set of miniature files make the fine work a lot easier.
Bazza_84
is there no way of getting a punch style tool put ur work in a vise, place the punch where you want it then either press it or the prefered meth of bang it with a hammer
not got to this stage yet, just an idea
The problem with most of those manual techniques is aligning the punch and the die well enough that we don't destroy one or the other when we tighten the vise or whack them with the hammer.
I did search for "sheet metal punch", and I ran into some light duty portable punches, like this $24
hand-held punch from JC Whitney. It looks very similar to
this punch from BrandsOnSale.com. Neither company lists the source, but they appear to be like units from Roper Whitney, which has a webpage
here showing punches and tooling, including slot-forming tooling, plus a low-cost bench-mounting base for the portable punch. This could be a pretty good alternative to hand-forming. Roper Whitney lists the price on the punch as $55, the kit with tooling and a case at $80, and the base at $28. I couldn't find a price on slot tooling, but their price for a 3/16" round punch and die set is $11.
**EDIT:
I modified the text to show that the punches from JC Whitney and BrandsOnSale.com are NOT from Roper Whitney, but are apparently copies. There's no way to know if Roper Whitney's slot tooling will work in the knockoff tools, so it's probably best to just buy the Roper Whitney tool if we buy this to make slots. The slot tools are available from Roper Whitney distributors.**
