Page 17 of 116 FirstFirst ... 78910111213141516171819202122232425262767 ... LastLast
Results 161 to 170 of 1159
Thread: Scion xB '06, in-dash Atom 330, Lilliput 889GL; details, pictures, links. Index: pg 1
  1. #161
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Slot-Making Update #3
    (posted in the "How Do *You* Make Slots?" thread I started in Fabrication)
    Quote Originally Posted by Curiosity View Post
    For metal, I'd try another piece of metal with a straight edge as a guide and clamp it on, cut along the edge with a dremel. Thin aluminum might work as a guide for plastic that's curved, but molding a faceplate in might work better for small things like memory cards, and you can mess it up more.
    Actually, I was referring to slots in sheet metal parts, where I think you're talking about slots in bezels and the like. But you bring up an interesting point: it may be possible to simply build a bezel without worrying about slots, and machine the slots and edges of the openings we need. I hadn't thought of that, and I think I'll try machining edges and slots in my bezel plastic to see if that's a possible production path.
    I suspect the high speed of the Dremel-type tool might simply melt the material. A lower speed, as with a mill, might do well. Because the material is soft, a drill press could probably be used to mill plastic without tearing up the drill press bearings, but I think it would add a lot of side load on bearings not designed for side loads.
    The "Dremel" that I have is actually a Ryobi 18V system. It works well, but isn't mountable like a true Dremel, and there's not a flat surface to run along a guide. An inverted Dremel in a work table might be a good idea. The way those little whizzers throw chips, though, I think I'd like to build a clear shield into the system somehow, or wear some really good goggles.
    I've also wondered if I could run a milling tool in my router -- mounted upside down under a work table -- to make slots. My router operates at a single high rpm; I'd have to bring it down to the proper rpm for plastic or metal milling. Also, I don't know that its bearings -- which handle sawdust just fine -- are set up to handle hot metal fragments. When I was only thinking of sheet metal work, I couldn't easily resolve either issue, so I abandoned the idea. I might have to revive it for machining plastic, if I could control the speed.
    I want a better way to form slots because I want to take less time and less effort, and I want better slot quality and consistency.
    But one of the secondary reasons is that the current method involves lots of metal chips. I was wondering if there's a way to do "instant" slot forming -- like punching -- that only produces a slug, or a few slugs. I end up having to take off my shop shoes every time I walk into the house, because I don't have a housekeeper (except me), and I'd rather work in the shop than run the Roomba or a mop. If I can make less mess, I'll get more done because it'll be easier to clean up after myself.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  2. #162
    Apr 2007
    Atlanta, GA, USA
    Slot-Making Update #4
    (more of the ongoing conversation from the "How Do *You* Make Slots?" thread I started in Fabrication
    Quote Originally Posted by rdholtz View Post
    Quote Originally Posted by kibble View Post
    They actually have some wheels that are made to cut through plastic. They look like the big metal cut-off wheels. I use them myself and they work pretty well, but you have to make sure to not stay in one area too long or it will start melting the plastic.
    I'd bought a kit of Dremel tools, and there's a mini-sawblade in there. But I was thinking of something more akin to a milling head, where we could simply machine a slot in the face of a plastic bezel. That would save a huge amount of finishing time. I believe the primary issue will be matching tool speed to the material; the softer the material, the slower we'll want to run the tool. Controlling the tool speed is probably easier in a 110V machine than a battery-powered one like mine, so I may have to invest in another Dremel-type tool (for research purposes, of course).
    Unfortunately, I'm going to have to delay experimenting with plastic machining, because I'm leaving in the morning for an unexpected week or more on the road.
    The good news is that today I got pictures of the punch and its results, and I'll get them posted as soon as I can write it up. I use GMail and Google Docs, so everything travels with me. Shouldn't be more than a day or so . . .
    Having a variable speed rotary tool doesn't compare to a fixed speed one. Get yourself one, you'll be glad you did!
    The Ryobi seemed like a great compromise when I found it. I've had excellent service from all my Ryobi tools. But this rotary tool is struggling to find its place. I think you've highlighted a major weakness in its lack of variable speed, and it may force me to get a Dremel-branded tool.
    There are a couple of other reason to get the Dremel brand. At Home Depot, I saw the #220-01 WorkStation mount for Dremel tools that looks really slick. There's also the Dremel #231 Shaper/Router Table, which might be a nifty slotting device.
    There may be a Dremel in my future.
  3. #163
    Apr 2007
    Atlanta, GA, USA
    Slot-Making Update #5
    (more from the "How Do *You* Make Slots?" thread I started in Fabrication)
    Post some pics after you try it out! I'm curious to know how it works out for you.
    Punch Testing
    I've been playing with the Deep Throat Metal Hand Punch from Harbor Freight. It appears to be a knockoff of the Roper Whitney No. XX seen on this page. If the tooling for the Roper Whitney model fits this tool -- and pictures suggest that it might, then this tool may be able to punch slots. So far, though, I've only punched round holes.
    I'm glad I bought the base; it makes it easier to use, but it needs to be mounted to a board; without it, the tool just tips over onto its nose. I attached the tool to the base, and the base to a piece of 5/8" plywood 5" x 8" with some 1" screws and fender washers. I didn't do any finishing to the base board other than file the edges to knock off the splinters. Here's how it looks mounted:
    Click images to enlarge.
    For size reference, the slot on the depth gauge is 3" long.
    The manual assures us that everything we need is included, but there's a 2.5mm Allen wrench needed to tighten the set screws; it's not in the box, nor is it on the parts list. If you go to Harbor Freight to get this, buy a set of metric Allen wrenches at the same time.
    I installed the 3/16" die set. I tried the punch on scraps of the types of steel I've been using for parts -- some .022" galvanized steel, an old computer case (.028" steel powder-coated on both sides), and some .031" stainless steel. The punch went through all of them. The force required depended on the material. The painted steel was easiest, probably because of the paint acting as a lubricant. The galvanized was almost as easy. The stainless steel was tougher, and I don't think I'll want to use this punch on that material. The stainless steel may have dulled the punch in a single use, because holes were just a little tougher after that. I confess that the instructions say "mild steel", and stainless isn't mild steel. Any damage done to the die set is clearly my fault for pushing it beyond its specified use. But that's just what research does.
    There's a locator point on the tip of the punch, so I can locate holes precisely; once the punch is positioned, I just a push on the lever arm, and I have a hole. "Push" means "apply some pretty healthy pressure".
    Here's a picture of the resulting holes in the test pieces:
    The material on the left is .031" stainless steel; in the center is .028" powder-coated steel; on the right is .022" galvanized steel
    I also tried punching 1/8" polyethylene, and it did just fine. The hole was smooth and very clean.
    The dies come grease-coated and packed in clear wrap, which makes me suspect they need corrosion protection in the humidity of south Florida. I made a small container for them in my tool chest and I'll keep a grease rag over them so the atmosphere in the box is oily air.
    The punch takes more initial setup than just slipping a drill bit into the drill press. But if I'm using a standard size hole -- I generally use 3/16" -- then I can just leave the punch set up with the 3/16" die set in it. It can sit on a lower shelf, ready to pull into action whenever I need holes.
    I like the cleanup; there isn't any. I guess when I've punched enough holes, the slugs will start to fall out of the bottom of the die, but that's still almost no mess. I'll brush a little dab of grease on the punch and the die when I'm finished each time to keep them lubricated and rust-free.
    If I just use it to make the holes at the end of slots, it's an improvement over drilling. The resulting holes are very clean and smooth-edged, and don't need any filing until final cleanup of the parts.
    I made a quickie bracket for a temporary system I was building, and needed holes in a piece of bent sheet metal. I marked the holes with a center punch, stuck the metal in the punch a couple times, and BAM!, BAM!, there were holes, perfect holes, right where I needed them, with no finishing required. I've never made holes so quickly and easily in my life. Oh, I like this tool.
    The verdict so far? While this is a handy tool for surprisingly low cost -- especially on sale -- it isn't the total answer to making slots. With the standard tooling, I'll still have to use the cutoff tool to complete the slots. The punch makes the process easier, but it doesn't produce instant slots, so I'm not ready to call it the "solution".
    If it can accept the Roper Whitney tooling and punch slots, it could be the answer I wanted. I'll research that this week.
    Even without that capability, it's a keeper.
  4. #164
    Apr 2007
    Atlanta, GA, USA
    Slot-Making Update #6
    Hmmm I like the fact that it's not messy like drilling stuff. I may get one myself! Another thing I don't like about drilling is that the holes are sometimes not really 100% round because of the way the drill bit bites into the material.
    I've punched enough holes with it that the slugs are falling out of the bottom, now. They just drop onto the workbench. When I'm done with the punch, I put it away and sweep the slugs into the metal scraps bin. I wish all my tools were as neat and easy to clean up after.
    Hurry, if you're going to get one on sale -- it ends July 22, I believe. But, even at its full $37 price, this is a really good tool, terrific for quick holes. And, now that I'm used to it, changing the punch only takes about a minute.
    I still have to check on getting the Roper Whitney slot punch and die to see if they fit.
  5. #165
    Apr 2007
    Atlanta, GA, USA
    Slot-Making Update #7
    Quote Originally Posted by golfguy View Post
    If you can use plastic, a router would be the way to go. Simply clamp a straight edge to your piece and plunge a router bit in to make the slot. You might even be able to do it with metal if you found the right bit.
    For plastic, a router would be good, but mine is a single-speed router. I'd need to control the speed so the tool doesn't melt the plastic; just the friction between the spinning tool and the material would cause melting, so the tool couldn't stop until it got to the end of the cut. That makes a variable-speed Dremel-type tool seem pretty attractive.
    I guess a mill could do both the plunge and the slotting in steel, but it would take some experimentation with material that thin. I'd also guess it would demand pretty low plunge and travel speeds to keep from bending the sheet metal.
  6. #166
    Apr 2007
    Atlanta, GA, USA
    Slot-Making Update #8
    (the latest entry from the "How Do *You* Make Slots?" thread I started in Fabrication)
    What About The Nibbler?
    I'd been wondering if there isn't a way to make my air nibbler function as a slotting device. Using it hand-held doesn't give me much more accuracy than the cutoff wheel. I thought maybe mounting it in a frame and providing a deck to slide the parts on -- similar to what we have with a drill press or a table-mounted router -- would be good. Since I have a universal table like that, I thought I'd see what it would take to make it work with the nibbler mounted to the bottom of it. But then I remembered two things:
    Attack Chips
    The downside to the nibbler -- in addition to the high noise level -- is the nasty little crescent-shaped chips. I can't use the nibbler unless I'm wearing boots in the shop, because those chips are like little curved double-ended daggers. They stick to everything like cockle burrs, and they're easy to track into the house on the bottom of my shoes. Despite brushing my clothes off and taking extra time to clean my boot-bottoms, I've found a few in the carpet with my bare feet, and it was definitely exciting. The nibbler is a tool that I almost think should be used out on the lawn, so the little chips will just sink down and add iron to the soil instead of adding daggers to the carpet. If I flip it upside down and mount it under a work table, I suspect it means I'd be getting a faceful of those chips. That would be a deal-breaker.
    Big Hole
    The other downside: the entry hole has to be large enough to get the tool through, and that entry hole is wider than the slot I want. That's another deal-breaker.
    So never mind the nibbler . . . I'll focus on the punch.
  7. #167
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    you could get a magnetic metal sweeper for the metal chips, but you're not going with the nibbler anyway...
    I really think that a slot punch would be the way to go, but I just can't find one online. I thought I saw one on Harbor Freight, but it's not where I thought, and searching brought up 1000 results.
    I think if it's a low run project, you might search for waterjet cutters nearby and see how much they would charge.
    A search on google maps using keywords: "waterjet loc: Palm Beach Gardens, FL" came up with 73 results.
    The place near me charges a minimum $60 per job, but if you're buying milling attachments and hand press punches for a little less, you might as well just cough it up and have it come out exactly perfect. Your cutter might have a lower minimum. Usual tolerances are as low as .01 inches. I'd say have them slot it and cut it, then you can bend it (some shops will bend for a couple extra bucks.)
    I'm totally into DIY, but there are some things that are just not worth the effort.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  8. #168
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by monkeyracer View Post
    I found a terrific punch at Harbor Freight, but it's only for round holes. The punch -- at list price -- is $35 with the stand. I reviewed it in post #163. Pictures, links to it, and results are there.
    I really thought it was going to be the answer to this slotting thing, once I got a slotting punch and die set for it. Then I called Roper Whitney to ask about prices. Hoo, boy! The only stock slotting punch and die set is 1/4" x 7/16", and it's $140.40. They custom make anything else for a few dollars more; the slotting punch and die set I'd want, 3/16" x 1/2", is $147.80. I just wouldn't use it enough to justify that expense for the low-volume stuff I do.
    I'll keep on using the punch for round holes. It makes sheet metal work soooo much easier. But when it comes to slots, I'll use the punch to form the end holes and keep on using the cutoff tool to cut out the metal between them. As much as I like the idea of instant slots, I'm just not willing to pay that price for them.
    I'm into DIY, too. I like to do the tinkering. For most of what I do, I'm experimenting with sizes and shapes right up to the last part I produce, and my car is a drivable prototype; every modification is a one-of-a-kind or two-of-a-kind thing.
    Once I've solved the problem, I want to move on to the next challenge, not make a bunch more of what I just did. Taking the time to get the designs into a CAD program and get them produced on a waterjet is simply too production-oriented for me. I'd just as soon turn it over to a production shop and go on tinkering. I've had some requests for duplicates of my parts, so I'll keep that waterjet process in mind.
  9. #169
    May 2007
    Lakehood, CO
    The waterjet guys near me will take pretty much anything resembling schematics and CAD it. So, you could bring in a bar napkin with drunken scribbles and they will make it into what you need.
    I think if you brought the piece in, and showed them what slots you wanted, and where (measurements you already need) they should be able to cut them for you. The cut-off tool has been working, but isn't as precise as the waterjet. It's up to you to decide if it's worth the price for the precision.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  10. #170
    Apr 2007
    Atlanta, GA, USA
    I like the waterjet idea, but I don't think I'd go for it just to get some slots. Making the slots still only takes a few minutes of my time, and, by leaving a bit of metal to file off, I get acceptable precision. The trip to the waterjet shop would still take longer than that, and I'd still have to clean up the results of their work. I think the waterjet idea is slickest for low-volume production work -- the kind of thing blk02si could use in producing batches of his 2DIN all-in-one unit, or the kind of thing I'd need if I made a batch of xB head unit supports.
    On the other hand, a similar process, CNC milling, would produce clean parts that need very little filing. That's what blk02si uses. Waterjetting sort of blasts its way through the part like a liquid saw, where milling leaves a very clean edge. I think I'd want to visit both kinds of operation to see which produces the best product for the money.
    n either case, I'd need to give the production shop a clear drawing to get good results. Your line about "a bar napkin with drunken scribbles" put a grin on my face. I used to take some pretty rough stuff out to the model shop to see if the machinists thought we could make something functional out of a design I'd thought up. I believe in good drawings, so today I would probably make the drawings and build a sample product using only those drawings to see if I left anything off. Unusable parts -- resulting from a screwup in the drawings -- cost the same amount as good parts from good drawings. The computer term "GIGO" (garbage in, garbage out) holds true in lots of areas.
    The bulk of my time is in designing, prototyping, redesigning, re-prototyping, etc., until I have something that fits well, looks good, and holds rock solid. Once I get a part I like, I make thin cardboard templates of the final designs (without the bends), and use them to trace the blanks. I also mark the hole centers in the cardboard, and use a spring-loaded centerpunch to mark the holes on the parts right through the templates. Then it's just a matter of cutting out the shapes, punching the holes, cutting the slots, and doing some finish filing. Off to the bender, and I'm ready to install.
    When I get right down to it, I like doing this stuff. Very few things are real drudgery (and the punch has eliminated some of them), so I don't want to let go of the processes unless I'm doing a production run. And that isn't likely unless a bunch of xB owners start if they can buy my parts.
  1. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  2. My 2006 Scion xB (portable) Carputer setup! w/pics!
    By breaker021 in forum Show off your project
    Last Post: 01-05-2007, 10:34 AM
  3. Replies: 10
    Last Post: 08-04-2006, 04:39 PM
  4. Acura RL - CARPC Installation
    By clean customs in forum Show off your project
    Last Post: 09-12-2005, 11:33 PM
  5. CarPC Installation Blogs
    By itrends in forum Show off your project
    Last Post: 03-22-2005, 02:50 PM
