Bezel Modifications:
I split the second side of the donor bezel and began laying out the bezel changes. The final dimensions -- well, today's final dimensions -- are that the top will extend 3" further from the dash, be 1" wider, and be 1-3/4" higher. There will be no change at the bottom.
The new bezel will rise above the dash now, but not so it intrudes on visibility or the sight line to the indicators on top of the dash. it looks that increase will allow me to install the monitor intact, without removing the case. It also means that I won't have to drastically change the position of the climate controls. I'll have to make some adapters to move them out about an inch or more, but that should be pretty easy, and the cables and actuator lines will still reach.
I'll spread the base and face portions apart when I build up the new bezel, adding material in between them. Here's the left side of the bezel showing the cut line, and the same part held approximately in its new shape by a 3" cardboard spacer at the top:
Click images to enlarge.
The base portion will remain intact and sit against the dash as it did originally. I'll weld material in between the base and the face to fill the gap. I'll also have to change the angle at which they meet, since the face is a bit wider -- 1/2" on each side at the top of the bezel, tapering down to no change at the bottom of the split.
To move the top of the bezel up, I had to cut the vent outlets off and raise them, and I'll have to fill that gap, too.
In addition to the bezel face, the ducts to the vent outlets, which are part of the bezel, will need approximately 3" extensions. As I set the cut-up parts in the dash, I realized that the extensions would need radical S-shapes to make the connection, and that's both inefficient and noise-producing. Then I had the idea to try reversing the vents, and that will work much better. I can swap the outlets and rotate them 180 degrees; then the airflow path will be relatively straight and will still function just as the originals do. It'll take more bezel finishing work, but the end result will be worth it. Here are pictures of that same side of the bezel with original vent outlet and the opposite side outlet. You can see that the airflow will take a straighter path.
In the lower photos, I've cut off 1" of the back of the duct; that's the part you see in the upper photos that has a foam ring around it where it seals against the dash. I'll use that cut-off part as the base to build the duct extension on.
Now I'll use acetone to strip the paint off the parts. All this shifting around of pieces means I'll have to tack-weld some spacers in while the parts are in the dash, to be sure I have the correct alignment. Then I'll pull the tack-welded assemblies out of the car and fabricate cardboard inserts to fill the gaps in the bezel. I'll use those templates to cut plastic pieces in the proper shapes and tack weld all the plastic pieces in place. There will be a lot of parts to juggle until I get it all tack welded.
I'll do finish welding in the shop where there's less chance of damaging some part of the vehicle with a misplaced hot welder. Actually, I'll do some finish welding in the shop, go back to the car for a fit check, weld some more, do a fit check, and so on. I want an OEM-quality fit, so there will be lots and lots of in-car fit checks as I go along.
Once I have the bezel face ready, I'll build the duct extensions. The final step will be to weld the bezel mounts back into the bezel so it stays in the dash all by itself (I've already cut off and set aside the ones I have to move).
Then I can face the challenge of making the bezel smooth and ready for paint. That's when I'll go back and re-read all the stuff on finishing from MP3Car members like Turbocad6 and Nexson.
LinkBack URL
About LinkBacks
