Mount Up!, Part 2
Back in post #319, I talked about building the rest of Josh's touchscreen mount. Josh decided to drive down with me from Atlanta and help finish it, so we drove both Scion xBs south 600 miles on New Year's Eve. Then we spent the first two days of 2009 finishing the mount, getting black texture paint on it, and installing the system. We have a great time working together -- no matter what we work on, we have fun. And this project was really fun.
Two considerations in the design of this LCD panel mount were (1) minimizing the intrusion on the passenger space, and (2) supporting its weight. The screen is simply huge -- it's an Elo 17-inch touchscreen -- and it's quite heavy; the only plastic on it is the frame that supports the touchscreen.
The display covers the entire center section of the dash, including the
head unit and the climate controls, so we had to devise a way to let it move for easy access to those controls.
We originally considered mounting it to the dash and lifting it up to use the controls, but there were a couple of problems. Lifting a panel that heavy would be awkward while driving, and finding solid mounting points was nearly impossible in a dash that's mostly plastic. While the dash is very
sound as normally used, it isn't designed to support the extra weight of this big monitor.
I noodled the design for a week, and came to the conclusion that a floor mount was the best bet. I pulled back the carpeting in my car and investigated all the mounting points I could find. I settled on three -- two on the right side and one on the left.
For materials, I chose 1-1/4-inch square LCS (low-carbon steel) tubing with 1/8-inch walls, mostly because it was already in the shop. It fits the design criteria nicely: strong enough to handle the stresses, and small enough to be relatively unobtrusive. Is it heavy? Sure. We do our best not to underbuild; better to make it heavy and strong than to make it light and weak.
To the 1-1/4-inch square LCS tubing, we added parts for the front bracket made from 1-1/4-inch LCS angle iron -- also 1/8 inch thick -- plus 1/8-inch LCS plate for the front bracket and the panel mounting plate.
Aluminum would have been lighter, but we didn't have any handy. If I ever build another one of these, that's probably the way I'd go, but the hinge and the panel plate would still be steel, so it would save only a few pounds at most.
The system pivots right at the bottom of the screen with a friction hinge system, so the driver can swing it down, make adjustments to the head unit or climate controls, and swing it back up. It will stay in place wherever it's placed. The hinge is a standard extra-heavy duty door hinge; we removed the pin and drilled it out slightly to accept a threaded rod. Those who have repaired bikes would recognize the new hinge pin: it was once a bicycle axle -- with nuts and lock nuts -- that just happened to be perfect for this application. The nuts and lock nuts let us adjust the hinge tension as necessary.
Pictures are on the way as soon as I get them off the camera.
