Page 38 of 116 FirstFirst ... 28293031323334353637383940414243444546474888 ... LastLast
Results 371 to 380 of 1159
Thread: Scion xB '06, in-dash Atom 330, Lilliput 889GL; details, pictures, links. Index: pg 1
  1. #371
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Centrafuse Notes
    Nav System
    The first time I tried to use Centrafuse Navigation, it simply didn't work. Josh had the same experience when he upgraded to the new version of Centrafuse. But his started working, later on, and he surmised it just needed time to find satellites and get rolling. So I just left mine on for a while, and pretty soon I had functioning navigation, too. Boy, that would be good information to put in the Centrafuse manual: "It may take some time for the system to locate satellites and get an initial fix on your position. Please be patient."
    But there may be one other thing -- make sure the GPS and all the other devices you plan to use with Centrafuse get plugged in and configured when you boot. The Centrafuse manual says everything should be attached when we start the initial configuration. But that's apparently necessary every time we run Centrafuse -- we need to have everything attached, and then boot up. It took me two lessons to learn that. Here was the second:
    Music System
    I had started Centrafuse, planning to rip music, but I realized my DVD system wasn't plugged in to the USB port. Oops. I plugged it in. Centrafuse couldn't see it. I restarted Centrafuse, and it still couldn't see it. Finally, I rebooted with the DVD system plugged in, and Centrafuse could see it and was ripping music. Okay, I think I finally have this in my memory now: plug everything in; then boot.
    Not long after I started ripping, the system crashed hard. But the problem wasn't Centrafuse. I was running a USB DVD reader, USB external hard drive, USB GPS antenna, USB mouse, USB keyboard, and USB Sprint Card. I suspect the system ran out of USB juice trying to use all those devices at the same time, with only some of them on a powered hub. Once I recovered from the crash, I added power to the other USB hub, rebooted, and things ran better and smoother.
    Centrafuse is great at ripping CDs and DVDs, so now I have part of my music collection available while I'm on the road. So far, I have about 4.4GB of music, but it's going to take some long trips to get through just that much -- it's days of music.
    TagScanner, FreeRIP, MediaMonkey
    One of the things I like about Centrafuse is that it rips in lossless WMA format, and reads a variety of other formats. Whenever possible, I'll be ripping through Centrafuse, because I like the way it handles tags and I prefer the lossless WMA format over the lossy MP3 format.
    Alongside the Centrafuse WMAs, I'm adding other music I've picked up over the years, mostly as MP3s. But I find the tags on some of that music aren't as well done as the tags produced by Centrafuse. After looking around the web, I found Tagscanner, a program that lets me edit song titles and other tag information so I get a consistent display in Centrafuse.
    I also found FreeRIP, a program that rips whatever I want and lets me determine what the tag contains. I can also use it to convert among formats. I have a few CDs that Centrafuse can see but won't rip, and FreeRIP ouputs in a variety of formats, including WMA and FLAC (also a lossless format).
    Another program to consider is MediaMonkey, which was included in CNet's recent list of Must-Have Utilities for PCs. I'm just getting started with it.
    By the way, Centrafuse doesn't seem to mind if we use other software for ripping. After I add non-Centrafuse-ripped material to the Music folder, I tell Centrafuse to Rebuild the Library (Tools -> Library -> Rebuild). It doesn't take long.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  2. #372
    Apr 2007
    Atlanta, GA, USA
    Radar Detector vs. Mirror
    We run radar detectors in both our Scion xBs, and locating them has been an ongoing discussion. Right now, they're both low on the windshield in the center, using the standard Escort suction-cup mounts. The ideal place for the unit is centered in the windshield, both horizontally and vertically, because that lets the secondary rear-looking sensor see clearly out the rear window.
    I still thought I'd rather have mine up above the mirror. I don't want it very visible, if that's possible. The real motivation here is security: even with the fold-out sunblock in the windshield, I leave the suction cups and the small mounting bracket on the windshield. That's a clue to thieves that there's something inside worth stealing. Getting rid of the suction cups helps me present a very uninteresting appearance to the lowlifes of the world.
    There are two problems with mounting the detector above the mirror:
    1. The detector may be so high it doesn't have a clear sensor path out the back window.
    2. The windshield has a coating in the area above the mirror -- a sunblock -- that affects the performance of the detector. The sunblock isn't just an overlay on the windshield; it's pits in the glass with black paint in them. There's no way to scrape the sunblock off and make an optically-clear area.
    I figured one way around this would be to move the rear-view mirror lower, but it's on an arm that bolts to the ceiling. I needed a mirror with a longer arm, or I had to get a completely different mirror and mount it on the glass, as it is in many vehicles. The latter course seemed to be the way to go. I was passing by my friendly local U-Pull-It automotive boneyard, so I stopped in. I found two nice, clean windshield-mount mirrors that would fit; in case we could make this work, I bought them both -- one for each car. Boneyard price: $2.50 each. The kits to re-glue them to the windshield are a few dollars at auto parts stores, and usually have enough adhesive for two attachments, so the price per car installed was going to get up to maybe $4. Cheap, if we decided do it.
    I removed the OEM mirror; it's held on by two Phillips-head screws under a clip-on panel. After holding the detector and the windshield-mount mirror in different positions, I just couldn't find a way to give the detector a clear view out the rear window while it's on top of the mirror. If I got the detector low enough, the mirror was too low.
    Having set the detector in all sorts of locations and found none that I like, I think I'll abandon the windshield-mount mirror.
    I see four options:
    1. Build a dash-mounted support for the detector.
    2. Attach the detector to the existing mirror mount so it rides just below the mirror. I'd have to devise a method to attach it.
    3. Mount the detector to the windshield using a standard mirror mount arm, rather than the suction cups. When the sunblock is up, I'd hope that it would simply look from the outside like a mirror mount. I'd have to devise a method to attach the detector to the mirror mount.
    4. Leave the detector on the suction cups. That's the easy temporary solution, but it's the one I like least.
    Any suggestions?
  3. #373
    Nov 2004
    St Louis
    Quote Originally Posted by rdholtz View Post
    I see four options:
    Any suggestions?
    There is a fifth option (if not more): get/make a remote radar detector set.
    I've done this a couple times. A long time ago, I had a remote Bell detector stashed in my grille and it worked quite well. A few years ago, I dismantled a V1 and put the front in a sealed box in the grill and the rear in my third brake light with the remote display stealthed inside my instrument panel (I'll never do that again, but there is a commercial alternative).
    My current install is actually a V1 in the garage remote slot above my mirror - comes complete with power, a decent front view, an excellent rear view, and completely hidden from outside the car.
    Another consideration might be a radar detector mirror or this or install yours in the rear of the vehicle with an adequate view out front.
  4. #374
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by GizmoQ View Post
    Hmmmm -- I like this remote installation idea; the unit in the link is Valentine-specific, and we run Escort & Bel (they're from the same company), so we'd have to make our own. This $299 kit appears to be a weatherproof box with weatherproof cabling, plus a remote display. We have two older Escort units from which we might be able to cannibalize the displays (the units only bring $50 as trade-ins at Escort, and sell on eBay for about twice that). This has some potential.
    A long time ago, I had a remote Bell detector stashed in my grille and it worked quite well. A few years ago, I dismantled a V1 and put the front in a sealed box in the grill and the rear in my third brake light with the remote display stealthed inside my instrument panel (I'll never do that again . . .
    I'm wondering what convinced you that was a route you'd never travel again: too much hassle, too expensive, not functional enough, eventual failure . . . ?
    . . . but there is a commercial alternative).
    I liked the sound of the commercial alternative, at first, but then I looked at the price. Sticker shock: $2960 is way, way too spendy for me -- that's six times the list price of our detectors.
    The mirror looks interesting, but I'm wondering -- if they can pipe the display into their mirror, that means it can probably be piped elsewhere -- perhaps right onto the computer screen. I'd like it if the detector sounded off, but didn't light up, and the readout came across the computer screen.
    The other site looks like Chinese knockoffs, and I know nothing about their reputations or effectiveness. Josh has invested a lot of time reading detector reviews, and I've read quite a few myself. We'd hate to switch to lesser-rated products. What I'm really after is a better way to install and use what we have.
    Your suggestions about other locations brought up a thought: I wondered if we could do a roof mount and have it be as functional as a grille mount; although it would mean we'd still lose rear-looking capability, it would be even higher than a windshield-mounted unit, so it would be effective for a greater distance. I had thought for a while that I'd add the side rails for a roof rack because that would let me add an external mount for the GPS without attracting a lot of attention to its existence. I thought perhaps the other rail location be a good place to put a radar detector.
    I suspected the primary issue with the external location is protection from weather -- primarily heat and moisture -- and the other problem to resolve would be concealing the detector's presence somehow -- perhaps by customizing the front mounts of the rails to allow them to hold the devices. But the cars' low stance, while it's an advantage in some ways, would be a disadvantage here: the lowlifes could stand there and carefully inspect the roof rack without touching anything, then tear into it after some planning. That's counter to making the car look uninteresting.
    I was in research mode, so I went to a few sites that test detectors, and at RadarTest.com found an article saying that high on the vehicle isn't necessarily better, because the lasers used in a lot of places are relatively narrow beams; if aimed at the front license plate, or at the grill, the beam may not be wide enough when it reaches the car to hit the roof-mounted detector, so we'd get no warning. It appears that radar & laser detectors are best mounted in the grille or windshield to keep them in the path of laser beams. I scrapped the roof-mount idea.
    Now we're talkin' -- lowlifes can't even see it. That's what I was after when I was working on getting it above the mirror. Do you have any pictures of that installation? What kind of vehicle is it?
  5. #375
    Mar 2007
    Bucharest, Romania
    I see four options:
    Any suggestions?
    Well, I have a suggestion for you.
    This is what I did: I made a custom bracket so that my detector would sit right above the mirror. I previously did some tests and it seemed that it did its job great in there (worked also for the 360 degrees detection - back).
    After I had a stone in the windshield, the people from the repair shop changed it with another one which had the mirror mount about 2-3 cm upper than the original one. It was too late to be changed again.
    So, I took out the bracket I made, it barely fitted above the mirror towards the end of the windscreen. The solution was to fix the radar detector on the upper side of the mirror using double sided tape. So, now it's about a half of year and no problem at all. Works fine to me that way.
    I also have the dark strip along the upper edge of the windshield and still it works fine. (The only problem is that it probably froze at about -10 degrees Celsius about two weeks ago and it sounds like it's at the minimum volume level although it's at its max.)
    I may add a picture tomorrow with my install!
    Good luck!
    Later Edit:
    Those are the pics with my detector in place:
    And the bracket I made, useless for the moment...
  6. #376
    Nov 2004
    St Louis
    I have an engineering degree, worked in electronics design for a while, taught Radar Range Equation and tactics to AF Electronic Warfare Officers, so thought I could dismantle and rewire this little inexpensive (by Air Force standards) detector. Desoldering, unshielding shielding, calculating antenna tuning, overcoming line/power losses, maintaining beam geometry, wiring and rewiring, creating weatherproof casings, reintegrating to the remote display, and on and on and on. I made the mistake of telling some of my scientists about what I was going to do and they helped me turn a V1 into an equivalent to the best the AF had at the time. Have you ever tried building something by committee.
    That's primarily the laser jammers raising the cost. I couldn't find any info there about the detectors - I assume there are two remote displays (one for the front and one for the rear) which is pretty weak planning on their part.
    Check out V1VD on the forums. Only one done that I know of is the Valentine 1. Maybe if you ask the Cheetah folks real nice they'll share how they pulled info from the Bel and others.
    Agreed, but it was the only one I could find. In the mid '80s there were almost a dozen that clipped on the mirror, even Bel had one (I almost bought it instead of the stealth remote), but lately they've been abandoned - probably due to poor 360 degree visibility.
    Cadillac Eldorado ESC. Pictures aren't the greatest, but there is a hump in the headliner area just above the mirror. This area is for the garage remote, moonroof controls, and a retractable pocket for sunglasses. The slot for the garage remote is deep enough for the V1 but had to be widened for the display to be visible to the driver and to reach the controls. I have another of these with the slot closed that I used for a while with a remote display but that display was distracting and I never found a place for it that I liked. At eye level I can just see the top arrow; the volume control know is within easy reach; and the tones are quite audible from this location. Works for me.
  7. #377
    Apr 2007
    Atlanta, GA, USA
    Have you ever tried building something by committee?
    That got a laugh. Yes, I've been in on designing by committee. It can be painful and miserable, even as the committee chair, because there are conflicting agendas and conflicting ideas; only rarely is there real cohesion and collaboration. My favorite line about design-by-committee is that "a camel is a horse designed by a committee".
    One of the reasons I love to work with Josh is that we stay collaborative, no matter how tired we get. Sometimes Dion, Ed and Fritz get in the mix, too. They're bright, interesting, capable guys with widely varying backgrounds, so it's a terrific group that has fun with ideas and tools.
    If I were the Cheetah folks, I don't think I'd be letting that information out, but it might be worth a few phone calls to see if I can find out what it does, and if it's something we could engineer around. I know Valentine has remote displays, and a few Bel models have them, but the Escort/Bel units we run don't have remote display capability built in. Drat.
    And our xBs don't have a cubbyhole like your ESC. Drat again.
    P.S. The FighterStick looks good there. I'll bet you put your body through some interesting contortions to frame and snap that picture.
    Quote Originally Posted by catalinux View Post
    Good luck!
    Thanks for your input, and thanks for the pictures. I ran an earlier unit on top of the mirror in my pickup truck, and it worked well there. Good job on the bracket.
    After more research, I'm thinking I might build a dash-mounted bracket or support that places the detector relatively low, more in front of the driver. I'm less concerned with it getting a clear rear view than with keeping the display so it's easily seen by me and not by other drivers. I'm aware that most law enforcement officers don't much care for "fuzzbusters", so, in the event a police car is following me, I prefer not to prejudice them against me.
    There's a good location on the left side of my dash near the pillar, and that's my current preference. Like most preferences, it's always subject to change if I get new information.
    One thing I'm not very up-to-speed about is what makes for a good "view" for the detector's rear sensor. I've noticed that, even when the detector is sitting down on the passenger seat, nowhere near the windshield, it still picks up signals. Is it just picking up "bounce"? Can it sense through seats and headrests? Can it sense through my body? What are the signal strength losses when the signal travels through more than glass? What degrades the signal most/least?
    Time to go to the Interwebs to get additional education on detector operation. I'll balance what I learn there with other concerns such as stealth and security, and then I'll determine the location I actually use.
    I'll report back . . .
  8. #378
    Jan 2006
    Just to update you all on my car PC status: I picked up my motherboard today. I know mini-ITX motherboards are small, but seriously, this was the first time I actually held one, and it's mine! It's an Intel D945GCLF2 ... so small ... so new ... and so going to be the brain of my car PC
    Next, I'll be getting my LCD (most probably Lilliput 629), PSU (M2-ATX), and a 4-channel amplifier.
    I'll probably start my own worklog soon.
  9. #379
    Dec 2008
    Chicago
    As far as radar detectors go, Rocky Mountain Radar has a remote unit for about $600 and you can get one from a gray dealer for about half that. I have one and I ran it in my Impala SS until I sold the car. Kind of a pain to install compared to just sticking a suction cup up to the glass, but a total breeze compared to the fabricating you've done so far. The unit itself worked great and I know 2 people, 1 for over 25 years, who say the scrambler works.
  10. #380
    Nov 2004
    St Louis
    You never know till you try. Several of us got great data from SILABS when we found out about their USB FM radio, they recognized us as a part of their market share and let some of us beta test. I also have been a beta tester for several commercial apps, just by asking.
    As far as the joysticks go, the CH Products FighterStick is in the Mustang, the one pictured above is the Saitek X-52. The picture was easily taken from the back seat, probably the only reason I ever sit back there.
    Quote Originally Posted by vanndaddy View Post
    That's the one I was trying to remember, good find!
  1. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  2. My 2006 Scion xB (portable) Carputer setup! w/pics!
    By breaker021 in forum Show off your project
    Last Post: 01-05-2007, 10:34 AM
  3. Replies: 10
    Last Post: 08-04-2006, 04:39 PM
  4. Acura RL - CARPC Installation
    By clean customs in forum Show off your project
    Last Post: 09-12-2005, 11:33 PM
  5. CarPC Installation Blogs
    By itrends in forum Show off your project
    Last Post: 03-22-2005, 02:50 PM
