Extra Lighting
While I noodle ways to install an overhead console, I should mention one other thing. On my trip to the U-Pick-It automobile boneyard, I was able to get the overhead light panel from a Lexus for $2.50, with the
wiring connector and about a foot of wire. That should go nicely in the overhead of the Scion to supplement the relatively dim
lights in the cabin. The unit also has separate switched reading lights.
The color of the Lexus part is close, but there's more of a yellow tint in it. I'll sand it very lightly, and then some Krylon Fusion plastic paint -- probably Satin Pewter Gray (2439) -- should make the color work.
With or without the console, I'll draw
power for the unit from the existing overhead light. If I don't find or build an overhead console, there's no system for mounting just the light it in the Scion's overhead, so I'll probably have to make a mounting bracket for it and attach that with Velcro or adhesive to the car's roof. Either way, I'll have to run a ground line to the other light, because it appears that this unit was grounded to the vehicle where it bolted into the steel roof structure.
If this works as well as I hope, I may go back and try to find another overhead light for the very rear of the cabin. Loading and unloading that area at night is an exercise in eyestrain, and more light would help.
