Try to insert something with more mass inside the thin tube, it needs to make good contact with the tube's wall and cool the inside of the tube, while you weld on the outside. A metal or PVC tube of the proper diameter will help. When you're finished, get the metal pipe out.
LinkBack URL
About LinkBacks
The white area surrounding the boot screen is the part that will be covered by the bezel.
