I'm not convinced additional holes would add anything to the unit, and they might even detract. I considered using perforated material for the chassis, but I think I want to direct the airflow more than the open material would allow. As it is now, air will be pulled in the open end and exhausted out the top by the fan. On the way along that route, some will cool the GPU and CPU (there's another fan on the GPU), and I'm expecting some of that air in motion will help move heat from the monitor. The bottom sides of the mainboard and PSU will be open to airflow as well, and that will help keep them cool, too.
I'll know a lot more about how successful this is once I build the unit. If it works as expected, I'll simply call it a victory and move on to
software tweaking. If it doesn't work as expected, I'll scratch my head and figure out what to try next.
Those "what next?" things would probably include replacing either or both of the fans with higher-volume units, but I'll start with these lower-output units for three reasons: (1) they're what I have, (2) I'm betting they'll be just fine for my low-heat-output system, and (3) I want to keep the fan noise down.
You guys are ganging up on me, eh? Well, you do have me wondering, and after thinking about what you say, I've reconsidered. I can change the single top fan into two top fans wired to the same plug.
I'll make that design change. Thanks to both of you for getting me to think about it some more.
