Page 56 of 116 FirstFirst ... 6464748495051525354555657585960616263646566106 ... LastLast
Results 551 to 560 of 1159
Thread: Scion xB '06, in-dash Atom 330, Lilliput 889GL; details, pictures, links. Index: pg 1
  1. #551
    Jun 2008
    Any chance I could get you to give me precise measurements of your 889GL (both outer dimensions of the face and dimensions of just the visible screen edges)?
    I'm trying to find the best fit for my Fusion, and almost all of the Lilliput displays seem to be just a bit too wide, so looking at using an 8" and hiding the buttons + bezel behind the dash bezel.
  2. #552
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by TuxToaster View Post
    Sure, I can do that:
    Overall width of case: 8-1/8 in.
    Overall height of case: 5-11/16 in.
    Depth of case: 1-1/4 in.
    Visible screen width: 7 in.
    Visible screen height: 3-15/16 in.
    Top bezel width: 1/2 in.
    Bottom bezel width: 1-1/4 in.
    Side bezel width: 9/16 in. each side
    The tops of the buttons are 9/16 in. below the bottom of the screen, and the buttons are 7/16 in. high.
    If there are other dimensions you need, I'll get them for you (as long as I can get them without uncasing it).
    If this Lilliput fits your car, I'd bet you'll like it.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  3. #553
    Jun 2008
    Awesome, thanks for the detailed measurements!
    Looks like the 8" is just slightly too big though, the only way I could make it fit would be to put it in upside down, and even then I don't think there's enough of a gap at the bottom to put it behind the panel.
    I went ahead and ordered the 7" EBY701 instead, as I know it will fit (with some minor filing on one side), I was just curious if the 8" may have been an easier install.
  4. #554
    Apr 2007
    Atlanta, GA, USA
    I'm glad I could help with the information. The 889GL is sitting on the desk next to me, patiently waiting for me to get into the garage and start building its new home. That should begin this weekend. We have some sorting to do in the garage, and I'm putting up a 12-foot x 16-inch wire shelf to store things on. Then it's off to the bandsaw we go.
    Good luck on your build with the EBY701. Put lots of pictures in your worklog, please . . .
  5. #555
    Apr 2007
    Atlanta, GA, USA
    Another Delay of Game
    I had the best of intentions yesterday: start cutting and forming metal for the chassis. Before doing that, I needed to clear some stuff from the garage and get it into storage in the attic. I decided to assemble a plastic shelf I'd moved up here, and, when reaching for the last shelf, slipped off the floor panel in the attic and stuck my leg clear through the kitchen ceiling.
    My granddaughter was in the kitchen sitting at the island, so it all took place right above her, and Josh was just off to the left. They heard a thud, saw the ceiling pieces and insulation come crunching into the sink, and looked up to see my leg sticking through the ceiling. I never said a word. Josh said there was this eerie silence, and then my leg went back up out of the hole.
    All told, I feel pretty lucky; I only went through with one leg, instead of straddling a beam and getting crushed equipment, and I hardly gave any significant amount of blood -- it's mostly stripey redness. I scraped up the skin on the outer part of my leg, skinned up my wrist, and am otherwise none the worse for wear.
    My granddaughter brought me a washcloth and sprayed the scrapes with Bactine right away. She was a real trouper.
    So, Instead of cleaning out more of the garage and stashing stuff in the attic, I spent a while patching up the ceiling. We had all the things we needed -- tools, drywall, drywall screws, drywall tape, and drywall compound. Never even had to go to the hardware store.
    I cut the hole to a nice, clean rectangle running between the joists, screwed in a replacement panel, put drywall mesh over the joints, and got the first layer of mud on it.
    The ceiling looks a little rough this morning, but it'll look better after some wet sanding and another coat of drywall mud. It should be ready for paint by Wednesday. We were going to paint the whole ceiling, anyway; this just moved that job up on the schedule.
    Now, this afternoon, I can get back working on the chassis.
  6. #556
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by rdholtz View Post
    Sorry about the mishap, but you gotta kind of look at it and laugh. Maybe your grandchildren were raised different but if I would have seen a leg dangling over the kitchen sink, I would have been on the floor laughing, I would have then of course helped you as your grand daughter did. Remember though, I'm kind of twisted in the head (don't woory i'm the only one in my family like that). I don't know anything about construction, but I have always wondered why they don't lay the insulation then put ply wood over it so you can actually walk on it?
    Anyways hope you get alot done today. Im waiting on my hinges so I can start my dash top screens. To bad I may have to rip all the wiring out for the dual pc per person idea
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  7. #557
    Vendor - Qube colin's Avatar
    Dec 2006
    Quote Originally Posted by HiJackZX1 View Post
    1) Cost - a lot of people don't plan on using their attics for storage
    2) Heat - the contractor in my house said something about moisture being locked in? I guess that's not a huge issue because lots of people put flooring in their attics!
    3) Trusses - they're designed to hold the roof and not too much more. Adding a few sheets of plywood will actually cause the roof to start sagging in a few cases. Most people just put the plywood along the edges so that the corners can take some of the weight load off of the main beams.
    Sorry, I had to
    Anyway, just started following this thread and wow it's informative! Hoping for an update this afternoon when all is said and done!
  8. #558
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    Sorry, couldn't help but LOL then wince at the thought of "crushed equipment"... OUCH!
    My install has slowed to a crawl. I'll jump back on it in a few weeks. Have fun with the chassis!
    Project λ^2 (Lambda Squared or Lambda II)
    [??????????] Install ???%
    Defecation hit the oscillation
    I have no clue what's going on anymore!!!
    Coming soon: freeflashstuff.net
    If I have time, I'll update it. College is a pain in my arse.
  9. #559
    Apr 2007
    Atlanta, GA, USA
    First Part Cut for the Chassis
    It was a big day here. After a full day of working and playing around the house -- including two sessions of ceiling patch touch-ups -- I finally got things rolling on the chassis. This evening I cut the first part out -- one of the sides -- and finished all the filing to get it smooth and ouch-free.
    I took it out to the car right away for a fit check, and that little pup works just fine.
    As Tidder says, "Pics?" Well, right now, there's not much to see -- one blank, with no holes. I'll get pictures when I have a few more parts and get some holes punched in them.
  10. #560
    Dec 2006
    Pics?
    Just playin, but good stuff, can't wait to see it.
  1. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  2. My 2006 Scion xB (portable) Carputer setup! w/pics!
    By breaker021 in forum Show off your project
    Last Post: 01-05-2007, 10:34 AM
  3. Replies: 10
    Last Post: 08-04-2006, 04:39 PM
  4. Acura RL - CARPC Installation
    By clean customs in forum Show off your project
    Last Post: 09-12-2005, 11:33 PM
  5. CarPC Installation Blogs
    By itrends in forum Show off your project
    Last Post: 03-22-2005, 02:50 PM
