Metalworking Tools, Part 8
There are some handy accessories you can get to make metalworking really interesting:
"Pop" Rivet Tool
Pop rivets are formally known as "blind" rivets, because they require access from only one side of the work, whereas regular rivets require access to both sides. The name "pop" probably comes from the noise they make when they're installed.
I've had a pop rivet tool for a long time; I bought it a couple of decades ago for putting together the aluminum gutters on my house. Now it's coming in handy for metalworking.
But somehow I'm just not a big fan of pop rivets. They have good aspects: the tools are inexpensive, the rivets are inexpensive, they have good shear strength (when they're stressed perpendicular to the axis of the fastener), and the installed rivets look nice and clean from the front. But they have some aspects I don't like: they have low axial strength (when they're being pulled apart parallel to their axis), the backs of the installed rivets are ugly, and they're a bear to drill out if I decide to change something -- and that's pretty often in development projects. I use pop rivets sometimes, but I think they're only okay.
Rivet Nut Tool
Because I was dissatisfied with pop rivets, I decided to explore rivet nuts. I bought a 45 Piece Threaded Insert Riveter Kit for $16.99 so I could try them out. It includes the tool (similar to the one shown), three mandrels, 10 rivet nuts in each of four sizes, and a pouch. I liked the way the system worked, and so I bought a whole box of rivet nuts to go with it for $9.99. All I add to make joints is machine screws.
I like rivet nuts for fastening because they're easy to install, and because the resulting joints can be easily disassembled any time.
The rivet tool and the rivet nut tool look a lot alike. In fact, Harbor Freight sells a
3-in1 tool that will handle pop rivets, rivet nuts and anchor rivets for $12.99.
Punch and Die Set
Drilling holes leaves rough edges, and sometimes I get holes that aren't perfectly round. I got frustrated cleaning up the holes I drilled, and so I got interested in punching. I looked all over the net for a decent punch at a reasonable price, but most of the tools were hundreds of dollars by the time I bought a few punch and die sets.
Then I found the Harbor Freight Deep Throat Metal Hand Punch Set on sale for $19.99 (regularly $24.99), and grabbed it.
I went back and got the Mounting Base for it on sale at $4.99 (regularly $9.99).
(The pictures are from the Harbor Freight website, and they're obviously not to the same scale.)
I use this tool whenever I can, because it makes nice, clean holes that require no cleanup. The holes are always round, and they're always right where I want them. At $25 for the whole system, it would be cheap enough to buy two and have the punching capability of a small production shop.
Small Hand Punch and Die Set
I needed smaller holes to go with the rivet nuts, but those sizes weren't included with the Deep Throat Punch Set. I had to find punch and die sets to fit it, or I was going to have to drill the holes. Then I discovered Harbor Freight's smaller model, a Hand Punch Set for $19.99. It came with all the smaller size punch and die sets I needed, plus a case. It's my latest tool acquisition, and it does exactly what I need. It's relatively light weight, and the punch and die sets change pretty quickly. If I were doing a lot of punching, I might buy two of these and leave them set up in different punch sizes.
Northern Tool sells an apparently equivalent tool for $21.99.
Between the large and small punches, I can make right-size holes in almost any sheet metal part. The only limitation is the distance between the holes and any adjacent panel; there has to be room for the head to get in. In the large punch, that's 1/2 inch (13mm); in the smaller punch, it's 3/8 inch (9.4mm).
