Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: 2000 Impala - (This is getting to be expensive
  1. #21
    Jun 2009
    London, United Kingdom
    Wow, this is starting to go a little close to a Pimp My Ride application form? lol
    To start with clear all the crap out of the car, I could barely see trim and carpet from your photos! Seriously, a clean car is much easier to work on!
    Once you've done that, plan everything on paper before you go cutting things up or messing around with bondo/fibreglass etc!
    Then get advice on those plans from people in the industry or others that have already done installs.
    Get everything ready and waiting before you start.
  2. #22
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by TheGuv View Post
    I agree. I dont see how you can do any mods with the car being so messy. I dont even see how you can drive it like that. Even with my car having 90% of its interior removed and tons of supplies in my car, its all organized and placed neatly in my car.
    In defense, maybe he works better in messy situations?
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  3. #23
    Low Bitrate titanicmusic14's Avatar
    Jan 2008
    Pennsylvania
    huh
    You guys are looking at the old pics. my car is pretty clean.
    yup
    Quote Originally Posted by HiJackZX1 View Post
  4. #24
    Jan 2008
    Pennsylvania
    Made a ton of progress
    I made so much progress. I have a line run all the way to the battery. I have some of my wires ready but it leads me to one point. I have something that looks like its grounded to my chasis. Could i piggy back my ground off of this or should I just make my own grounding point?
    "You know what I mean? But at the end of the day, it is what it is." - The most articulate thing someone could say.
  5. #25
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by titanicmusic14 View Post
    . . . I have something that looks like its grounded to my chasis. Could i piggy back my ground off of this or should I just make my own grounding point?
    If you're referring to the ground in the first picture, that looks to be a body panel ground. You might use that, but I suspect you'd be better off with a ground to the frame or other more substantial part, like the engine or a bumper mount.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  6. #26
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    I feel you on all the setbacks that modding can bring about but I was LMAO at
    your problems because they sounded just like something that would happen to me.
    "A rose by any other name is still a flower"
  7. #27
    Jun 2006
    Mobile, AL
    Hey Titan check out my self made grounding point on my "Show off thread" Here. I get a good ground. Before I hacked and sanded though I OHM tested it with the battery for good ground capabilities.
    Hey I see you got the wires through the hole also!
  8. #28
    Jan 2008
    Pennsylvania
    Testing Time
    That grounding point that I used worked out just fine. I have everything set up in a test manner but inside the car. It runs good. I have a few minor issues. I used an extension cord soldered into the 4 pin connector to give the lilliput clean power. However it has unrelated issues.
    The cat5 turned out to be a bad implementation for my reset switch and power LED lights. Now I'm going to use 22 gauge power wire since I have it laying around.
    My amp, when I press pause on the music and the car is off. I can hear a little noise and its even worse if I turn the level up.
    My second major issue is my screen problems during hibernation my xp symbols is up too high. When I have my elite skin on its too high and so is windows. SO i used the settings on my monitor to try to correct it but that only works on the desktop and not the other things. I tried playing with the display settings in ride/road runner but that doesnt work. Its the widescreen eby701.
    I stepped on my mobo and now the battery is broken off so I have to see guino's irritating reminder to update. Then shortly after my GPS updates the time.
    But other than the cat5 problem and the screen its all testing well and I will be putting it together fully and mounting tomorrow for my trip. Its good to have GPS it lets you know how much time you gain when you speed.
  9. #29
    Jul 2007
    Miami
    Im curious about the cat5 issues..... Alot of my install revolves around it because of the high wire count. There is a line going to each seat, which will have a PC selection switch, a power switch, and stereo audio all going through it. The driver side has 2 cat5 runs since I have 2 computers to control from there.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  2. Replies: 0
    Last Post: 03-05-2007, 01:01 PM
  3. Installing Windows 2000 Pro on a 1GB Microdrive
    By JeremyM in forum WinNT Based
    Last Post: 05-07-2005, 09:56 PM
  4. speed up win 2000 boot time
    By more mods in forum Software & Software Development
    Last Post: 06-09-2003, 11:05 AM
