Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 1996 300zx TT - Carputer w/ sound system upgrade
  1. #11
    Low Bitrate sedtc's Avatar
    Jul 2006
    tally-ho, fl
    are you using the onboard audio from your mb? that might explain the noise issues you are experiencing. you will benefit from using a separate soundcard or an external DAC, check over in the car audio FAQ for more info. looks like you'll be using some pretty good audio equipment, upgrading the audio out from the carpc ensures that you are sending the cleanest signal. those ground loop isolators are a diagnostic tool and may adversely affect the fidelity of your sound system, although ymmv.
  2. #12
    Jan 2008
    Los Angeles
    I gave up trying to run cables on the passenger side.
    Under the steering column was a nice open area clear to the firewall. There was a Nissan plate covering a 2" option hole through the fire wall. I removed this plate and use this as my cable pass through.
  3. #13
    Jan 2008
    Los Angeles
    @ sedtc -
    Yes, Phase I is using the onboard sound. I had a feeling it was the cause of the lingering noise. Looks like it will need to be a USB sound card for the solution.
    Anybody hear of a USB powered sound card that has balanced audio?
  4. #14
    Dec 2007
    ohio
    lose the tail light vinyls IMO, strut that 300z rear proudly
  5. #15
    Jan 2008
    Los Angeles
    No Decal, custom paint.
    Although I have been thinking of JDM rear lenses lately.
  6. #16
    Dec 2007
    ohio
    yes, get the 99 tails, a much better body upgrade. I went through courtesy nissan of texas to get mine. They were a lil cheaper than other places. Sorry, its just saddening to see someone cover such a distinguishing feature up with circles.
  7. #17
    Newbie dencker's Avatar
    Jun 2008
    Aalborg, Denmark
    #1
    Sry for OT, but how did you make that "phase" diagram? Is it just Photoshop, or did you use some application designed for making such stuff?
    Looking forward to picking up a '99 Ford Focus and stuffing a CarPC into it! I'm going for the OEM look. If anyone has tips or are willing to help me, please feel free to contact me!
  8. #18
    Jan 2008
    Los Angeles
    I used BSS Audio HiQnet London Architect.
    It is a pro DSP design software for configuring and controlling BSS Audio Soundweb DSP's
    I have a 1st generation Soundweb installed now. I hope to upgrade to a Soundweb London because it is Ethernet control instead of serial and may be easier to mod/replace the power supply to run on 12VDC.
  9. #19
    Apr 2008
    Quote Originally Posted by z_lust View Post
    The 7" Lilliput actually fits perfect in the visor. It only added 1/2" to the depth. The tension spring on the visor is even strong enough to hold the visor folded up during driving. The viewing is awesome, screen glare is not an issue. The biggest pain is sewing the new vinyl cover which I am taking on next weekend. I already have my patterns cut.
    I will get the pictures of the visor mock up posted today for you to review.My only long term concern would be thermal issues and venting. But I don't operate my Z for long periods of time, I work from home now and only take her out once every week or two.
    I got the whole rig running last night!
    My only issue is noise when connecting the PC to the digital mixer. If I disconnect the feed from the pc, the noise goes away, if I monitor the pc w/ headphones it is quiet. If I run my head unit through the digital mixer it is clean. I have added chassis grounds to all components (pc, mixer, inverter) with only minor improvement.
    I going to try isolators between the PC and mixer, that should do the trick.
    Please post of pic of the lilliput in the visor!! I was wanting to do the same thing in my grand national.
  10. #20
    Jan 2008
    Los Angeles
    I uploaded some new pictures.
    I promise to get some of the visor up soon. It will be heading out to the upholstery shop soon for it's final skin. That will probably be the last detail of this project.
    I installed the new DSP (Soundweb London BLU-16) and fired up the system for some rough tuning.
    OMG!
    on first pass I had the subs up to the point it felt like someone punching me in the kidneys. This system should sound amazing after I tune it. As it is it is not too bad flat with some nice crossover filters.
    I did notice that the stiffening capacitor will be needed. I'll install it next weekend.
    I had to compromise and use a passive crossover on the front channels instead of using the DSP as an active crossover. I simply did not have the real estate for more amplifiers.
    Absolutely no grounding issues with the new system.
    Next project will be controlling the PC with VNC over WiFi using my Ipod Touch.
  1. Carputer System for sale!
    By 94 Cobra R in forum Classified Archive
    Last Post: 10-12-2006, 07:29 PM
  2. Paper carputer system, how's it look?
    By badfish25 in forum Newbie
    Last Post: 07-27-2005, 08:07 PM
  3. FS: Complete bmw e46 carputer system
    By RiXst3r in forum Classified Archive
    Last Post: 07-19-2005, 09:28 PM
  4. sound system wiring advice and componant choices for a newbie
    By dbzeag in forum General Hardware Discussion
    Last Post: 08-27-2004, 07:44 AM
  5. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
