Results 1 to 9 of 9
Thread: 1997 Chevy Tahoe TruckPuter
    Nov 2007
    Cool 1997 Chevy Tahoe TruckPuter
    Greetings,
    this is my 3rd project, but the first one i am going to try to keep a blog on.
    so far what i've done:
    ripped out factory radio, and replaced it with a Pioneer Premier, installed my lilliput.
    the computer is currently mounted inside of a Hoffman 12x10x4electrical enclosure(any industrial electricial supply store should have these little jems)
    i am planning on replacing the factory CD player(unhooked) with a slot load DVD player and using a USB adapter, tie it in to the computer.
    i have a GPS mouse installed.
    i do not currently have the audio tied in.
    (btw, anyone have any great ideas for cleaning carpet, previous owner(employer), liked to toss gears and things in the back and passenger side, and have gotten grease/oil stains on the carpet)
    here are some pics
    The extra holes are from where i had the HDD mounted, i did not take into consideration the height of the video card(i thought it would clear, it is a half height card)
    the white mess on the screen, is a drop of super glue, from a previous install, i've not tried anything to remove it yet. I've been considering using nail polish remover and a q-tip
    more work is planed on wiring, and if i had the forethought, another 1/2" would have been nice on the back of the MB so i could get the connectors on/off with out removing the MB.
    I need to replace my DSATX power supply, i bought it in '05, and it no longer functions, not sure if i will get another DSATX or if i will try a different DC-DC power supply,
    so for now i am using an inverter.
    1997 Chevy Tahoe
    Planning 30%
    Installation 15%
    Overall Progress 12%
    worklog
    Nov 2007
    * reserved *
    1997 Chevy Tahoe
    Planning 30%
    Installation 15%
    worklog
    Nov 2007
    * also reserved *
    1997 Chevy Tahoe
    Planning 30%
    Installation 15%
    worklog
    Nov 2007
    Ok, today i hooked up my GPS mouse, and installed the scripts to auto-start the GPS crap in streets & trips.
    i've still not tied in the audio, i'm hoping to find my power adapter for my SB Audigy so i don't have to use onboard sound, and to allow me a shorter cable length from the audigy to the head unit
    1997 Chevy Tahoe
    Planning 30%
    Installation 15%
    worklog
    Newbie Slammed's Avatar
    Apr 2006
    Great thread good luck I will use you as a model for my 99 tahoe
    side note dude clean that seat up man thats nasty
    Nov 2007
    thanks!
    i'm trying to find a decent(and cheap) detailer to clean all the leather and carpets on the inside.
    i may end up sending to to be re-upholstered, i dunno yet
    1997 Chevy Tahoe
    Planning 30%
    Installation 15%
    worklog
    Apr 2006
    get an old towel and some simple green it will restore it all to almost new then just treat the leather after
    Quote Originally Posted by fischb22 View Post
    thanks!
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    thanks!
    It may be easiest to just pull the carpeting out to clean it. Then you can replace the pad under it, which is likely soaked with oil. Cleaning the carpet and replacing the pad will help get rid of the machine shop aroma.
    Pulling the carpet lets you find all the hidden crud that snuck in, and it's a great opportunity to run wires any way you want.
    If the carpet is too far gone, you could send the truck out for recarpeting, but you might want to consider buying a ready-formed carpet from one of the aftermarket houses; some specialize in Chevy/GMC. They aren't hard to install.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Nov 2007
    Quote Originally Posted by rdholtz View Post
    i have been thinking about ordering replacement molded carpet, but what a PITA, i really don't want to have to pull all the trim, and seats and mess out.
    I'll give the simple green & towel a go, and see what happens. if it does not lift the stains, then i'll look more into replacing the carpet.
    anyone have any suggestions on cleaning the leather?
    1997 Chevy Tahoe
    Planning 30%
    Installation 15%
    worklog
  1. 2002 Chevy Tahoe + P0174
    By xgalaz in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-22-2007, 02:50 AM
  2. Chevy Tahoe - Rear AC/Heat control unit
    By asong31 in forum General MP3Car Discussion
    Last Post: 10-07-2007, 03:13 AM
  3. 1997 Chevy Siverado TruckPuter
    By HarleyTeKk in forum Show off your project
    Last Post: 08-30-2007, 02:01 PM
  4. Enable DVD While Moving on Chevy Tahoe...
    By ukchris in forum Car Audio
    Last Post: 10-24-2006, 04:40 PM
  5. Unlock Chevy Tahoe Touch Screen OEM GPS
    By gderamel in forum GPS
    Last Post: 09-12-2005, 09:20 AM
