Thanks! That is what I was thinking as well. I don't use the changer. Did you create a custom enclosure for the pc components or where you able to find a case that would fit in that spot?
Well you're gonna have to remove your 6-disc changer if you wanna mount in in that area. I mounted mine to the right of it at first, but then i decided to remove the changer since i wasn't using it and made more room.
My carpc worklog
Damn, that's one sweet setup.
I was just looking around to see if anyone had done a GS with a carputer and
your's definitely takes the cake.
Now i gotta start my project and post up here!
I got a 99 GS4.
You've given me some great ideas and thanx for listing all the parts you
used.
I'm sure you don't need them but i got some manuals for 99 GS300
if you ever need them, in pdf format. Technical stuff.
I'm out!
Hi ar15guy, I am just starting my 99 GS project as well. I would definately like to take a look at those PDF technical manuals if possible.
Thanks!
hey great install, i was hoping to do something similar. Where did you get your bezel?
