rebuilding the mounting bracket for the screen... ran into some mounting issues that would be easier if i was dealing with a flat surface to mount instead of a rounded edge and then making it contoured to the center console after the screen has been successfully mounted.
Ill be trimming the top portion of it to accomodate the oem INFO buttons however, i will be painting the info buttons and the hvac controls to match that of the screen bezel so it will look more uniform, i might even try and find some psudo leather to surface it to match the rest of the interior, dunno yet will have to see what i can find available.
the issues with the glovebox carpc case was that with my other mod, i was able to use a 90 degree monitor port due to the lack of space between the side and the far left side of the glove box space:
the right side of the dashboard of the glovebox has far more room for cables etc, so im taking the whole car pc apart, and reconfiguring it so that the ports are all on the right side instead of the left side, good thing is that the polycarbonate i used is easily drilled and reconfigured, bad thing is that now since i have a limited supply of this stuff, the case is now full of holes and screw mounts that are no longer used... its slowly becoming swiss cheeze .. but once i get everything situated and operational, ive found a relatively cheap distro for the poly sheets (266 for a 3/8"x4'x8' and 180 for 1/4"x4'x8') so once i get the actual rig configured, ill remake it but with less hack and chop
LinkBack URL
About LinkBacks
leave it to cadillac to dummy proof a car
