Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
Thread: 1999 Nissan Silvia Mac mini Install
  1. #31
    Apr 2008
    Australia
    Hello Mr Melago,
    First of all, thanks for the comments. And secondy, I am having a bit of trouble with the OBD. I have a Consult interface that works with nissan data scan perfectly, but I want to be able to use it with Centrafuse. I also picked up a ELM327 unit, but the problem is that it has a standard 16 pin OBDII connector, but the Nissan has the 14 pin Consult connector. I tried to find what pins have the OBD data on the Consult port, but no luck there.
    Has anyone got an ELM327 working on a Nissan?
    EDIT: I think the reason why I cannot find any info on this is quite simply because my car does not have OBDII, but rather only Nissan's own propriety Consult. If someone can prove me wrong, please do!
  2. #32
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    You could be right. Consult could be different to standard OBDII.
    I have sent you some more info in a pm.
  3. #33
    Apr 2008
    Australia
    Well it looks like I'm going to have to make a Consult plugin for Centrafuse, and I now have a useless ELM327. Thanks a lot Nissan.
  4. #34
    Aug 2002
    Dilmahay,
    I have a diagram of the consult cable. pm me your email address and I will send it to you. It may help you sort out if you can use the ELM327 or not.
  1. 04 Jeep Liberty Mac Mini Install
    By RedGoat149 in forum Show off your project
    Last Post: 04-18-2008, 10:31 PM
  2. help with 1900, mac mini install. (dfw local)
    By aaronle06 in forum MacCar
    Last Post: 08-07-2007, 09:19 PM
  3. Mac mini install ideas?
    By fpena in forum MacCar
    Last Post: 06-15-2007, 11:41 AM
  4. Installing Mac Mini in My 05 Alti SER
    By Vitulla in forum Newbie
    Last Post: 05-24-2007, 12:55 AM
  5. Mac Mini in a Mazda Protege
    By zapwizard in forum Show off your project
    Last Post: 08-07-2006, 09:18 AM
