Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: 2004 Toyota MR2 TTR Spyder
  1. #21
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    Added pics of the working carputer LCD in the car, will get pics of the final resting place of the carputer soon.
    Fox Mulder
    2004 Toyota MR2
    Modified Intel Xeon E5450 3Ghz Quad Core 2GB RAM 160GB SSD M4ATX Xenarc 700TSV TS Toslink Audio BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
  2. #22
    Constant Bitrate kolton5543's Avatar
    Apr 2011
    Safford Arizona
    Could you maybe post some pictures of the carputer installed. And maybe some pictures of like the storgae compartments. Also I am curious if there is any room behind the dash for anything. If you have ever taken the dash apart and know if a small computer or anything would fit there or not. I have been all over this car since it has been released in 2000 and I'm seriously considering saving for one when I get a job and installing a carputer into. I have done a lot of resarch on the interior and everything to see what would fit where. I would prefer an indash installation and move the HVAC controlls where the stereo is and install a screen where the HVAC controlls currently are. Thanks. I'd appreciate it.
  3. #23
    As it is, you would be hard pressed to place a computer behind the dash. However if you remove the stereo, relocate the HVAC controls there would be just enough space to fit a very small form factor coputer like a mini-itx board and 2.5" hdd with pico power supply. But not alot of room. There was another mr2 build where the owner removed the guts of the headunit and placed a mini-itx board into the headunit case.
    Here are some more pics that might be of use. I replaced the clock with a 16x2 character lcd as well.
    Fox Mulder
    2004 Toyota MR2
  4. #24
    Apr 2011
    Safford Arizona
    Thanks man. I really appreciate it.
  1. Finally, 2004 Toyota MatrixPC is ready for primetime
    By MatrixPC in forum Show off your project
    Last Post: 11-28-2009, 05:50 PM
  2. 2004 Toyota Corolla S Project!
    By PaulDePimp in forum Show off your project
    Last Post: 04-13-2007, 07:31 PM
  3. Toyota MR2 JDM 1998, OBD-II???
    By mr2mac in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-18-2007, 03:54 PM
  4. 2004 Toyota Prado
    By craigt in forum Show off your project
    Last Post: 10-02-2005, 02:16 AM
