Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 2004 Toyota MR2 TTR Spyder
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    Here's some pics of the car:
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
    Some pics of fixing a broken liliput that has been sitting in my room for a while, making an mdf case for the carputer and showing how the m4 atx sits in my case (attached to a hinged lid). Now if only if the M4 ATX would actually work.....
    Fox Mulder
    2004 Toyota MR2
    You can see the LCD Shroud in the first 2 pics, the other pics you can see my dodgy hacksaw skills in cutting out holes for the fans and the painted case.
    Fox Mulder
    2004 Toyota MR2
    Trial Run of Destinator 7:
    I'm dissecting a broken bluetooth speakerphone system I got for free from work. I've added in a 1 watt audio amp to boost the signal to send back to the carputer's line in input, and an RC circuit to make it automatically turn on.
    Here's it all being fit into the same original case
    Finished Product (minus 5v power cord)
    I'm placing my GPS reciever in the screen housing as well. Here you can see the auto on modification to the lilliput, the addition of a fan and the extension of the existing IR sensor.
    I extended the wires to that USB socket on the left as the housing doesn't fit if I plug the usb connector for video in there.
    This is how the circuit boards are stacked on top of each other, using some pcb spacers I had lying around.
    Installation of the Screen:
    All the tools lol
    This is behind the dashboard where all the cables come out from the screen housing
    Finished installation pics:
    Some pics from outside the car
    Time to lay some cables, taking apart the interior of the car:
    This stuff (looks like the power antenna relay) will be underneath my carputer.
    The yaw sensor and transmission computer, not much room to spare down there!
    Running Power and Ground wires
    Taking apart the middle console to run vga,usb and sound wires up to the front dash.
    Some Pics of the computer in operation:
    Fox Mulder
    2004 Toyota MR2
    Low Bitrate pdegameplayer's Avatar
    Jul 2007
    Harrisonville, Missouri
    nice but im a bit confused do you have 2 motors in your car i have never seen a car like that before and thought at first that the engine was in the trunk and now i'm not sure....
    Jul 2007
    It's an MR2. The motors are in the rear on MR2s.
    I've got one as well.
    Hey fox, thanks for the nav pod dimensions. I did get them.
    Jul 2007
    Quote Originally Posted by 02mr2 View Post
    thanks that sums up a bit of confusion..
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Actually it looks like its a mid engine car.... so all the liquid containers are in the front? Looks like all the relays are too. What is the large hatch in the front, the battery? Wow the MR2 is a funky car.... I mean its similar to a Porsche, but Porsche has a trunk in the front. Doesnt look like the MR2 has one at all.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Jul 2007
    Quote Originally Posted by HiJackZX1 View Post
    The hatch you see is kind of a trunk.
    The spare tire is in there. There's room for a backpack too, but not much else.
    From the factory they have two storage bins behind the seats. You could fit 1.5 duffle bags in the bins, but where the hell do you find .5 of a duffle bag?
    I got rid of my bins and stuck two 12" Alpines in a fiberglass box there.
    I can deal without the storage space.
    Jul 2007
    now i understand...
  1. Finally, 2004 Toyota MatrixPC is ready for primetime
    By MatrixPC in forum Show off your project
    Last Post: 11-28-2009, 05:50 PM
  2. 2004 Toyota Corolla S Project!
    By PaulDePimp in forum Show off your project
    Last Post: 04-13-2007, 07:31 PM
  3. Toyota MR2 JDM 1998, OBD-II???
    By mr2mac in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-18-2007, 03:54 PM
  4. 2004 Toyota Prado
    By craigt in forum Show off your project
    Last Post: 10-02-2005, 02:16 AM
