+ Reply to Thread
Results 1 to 10 of 19
Thread: 2004 VY Holden Commodore Full Install (AU)
    Constant Bitrate soyfish's Avatar
    Mar 2008
    Canberra, Australia
    Hi All, this is the work log for my 2004 Holden Commodore. It's an Australian car and my first car pc. The idea is to put one of the stage 3 mp3car.com carputers under the passenger seat, and a small amp (4x35wrms) under the drivers seat. This will then be hooked up to 2 jaycar 6.5" splits in the front, and jaycar 6" speakers in the rear doors. All doors will be sound deadened.
    I'm planning on putting a Xenarc 8" screen in the dash where the original double din head unit was. This will require some fabrication.
    The Car -
    Parts List:
    - Xenarc 800tsv 8" touchscreen
    - Stage 3 carputer
    - Jaycar 6.5" splits in front and rear doors
    - 4X50wrms Jaycar response amp
    - A Bulk pack of Dynamat.
    - Audiopipe 8 gauge wiring kit
    - Audiopipe battery terminals
    Haven't got any decent pics of the dash, will get some ASAP. Here is the initial wiring diagram for how I want to set it out. I would appreciate your comments / experience as I'm sure I've left things out.
    Currently I'm not real sure on if the power wiring for the amp and PC is as good as it could be. The benefit with the way it is now is that it keeps audio and signal cables away from the power lines, however it does mean more wiring. Again, suggestions much appreciated
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    What state you located in? I think there is someone else on here with a carputer in a VY..
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
    Mar 2008
    Canberra, Australia
    Quote Originally Posted by Fox_Mulder View Post
    I'm in the ACT, I think you might be refering to the guy with the VY Calais, and the slick 8 inch screen in the dash. He goes by VYCalais on streetcommodore.com, and has been helping me out so far :P
    Ah that sounds right, if you plan on powering your screen with your computer's power supply, you might want to wire in a relay controlled by ACC. Otherwise your screen is going to be on when your computer is on, and say you get out of the car and your M2 isn't set to turn off straight away your screen will remain on. A screen that is on inside a vacant vehicle might be a theft magnet.
    edit: I'm in Melbourne
    Fox Mulder
    2004 Toyota MR2
    Mar 2008
    Canberra, Australia
    So you mean when it is on stand by etc? I have a wire from the ACC or IGN on the diagram from the old head unit to the power supply (could be a bit hard to see), if i set windows to hibernate when the "power button" is tripped by the power supply, and also set it to turn off the monitor, would that do it?
    When the computer enters standby, the 12v line is powered down so your screen will turn off. I believe on the M2 you can get it to get windows to enter standby within 5 secs of you taking out the key (as you said by simulating a button press), so you should be fine there.
    But if your computer fails to enter standby after the "button press" the screen will be on, regardless of whether the key is in the ignition or not. Untill your M2 cuts it off - Which could be anywhere from 1 min to Never depending on the setting of your M2.
    Fox Mulder
    2004 Toyota MR2
    Mar 2008
    Canberra, Australia
    Thanks Fox, that all makes sense. I'll have to do some testing with a test rig and a normal computer power supply to mimic a car when I get the PC (has been shipped).
    I've been reading this thread, and I'm wondering if the fuses he has before the power supply are needed, what do you reckon?
    With the setup in that post you would be wise to place a fuse near the power supply this is why:
    Little text base schematic here:
    Battery -> Fuse 1 (125a) -> Cable ->
    -> Fuse 2 (25a) -> M2
    -> Fuse 3 (50a) -> Amp 1
    -> Fuse 4 (50a) -> Amp 2
    Fuse 1 is designed to blow if the cable is shorted agains the chasis etc, but it has to allow for 25a for the m2 and 50a for amp 1 and 50a for amp 2 (25+50+50 = 125). So thats why there is a 125a fuse there.
    Now fuse 2 on the M2 is designed to blow in case something shorts out inside the M2, now if you were to remove Fuse 2, and something shorted inside your M2 125a would have to surge through your M2 before the the fuse would blow. By that time your M2 will be utterly destroyed . So Fuse 2 Is designed to protect the M2. It's the same for Fuses 3 & 4.
    HOWEVER:
    I have wired my setup this way
    Batt -> Fuse 1 (25a) -> Cable -> M4
    As I'm only running 1 device off the cable, and dont plan on running anymore I only have to use one fuse. The fuse protects both the cable and the m4, as i's amperage rating is within spec for both of em (cable can take up to 30a m4 can take up to 25a).
    I hope this makes sense lol
    Fox Mulder
    2004 Toyota MR2
    Mar 2008
    Canberra, Australia
    Hey Mate, yeah that make sense! I bought an 8 gauge wiring kit off ebay a little while back, and want to utilise that as much as I can, but I'm thinking 8ga probably aint enough to power the PC and the Amp, not to mention that getting fused distro blocks for 8ga in and out is not really possible. So here is what I'm thinking.
    Batt -> Fuse1 (75 or 80a) 4ga cable -> distro block - Fuse2 (50a) 8ga Cable -> Amp
    - Fuse3 (25a) Cable ?ga -> M2
    So bascily the same as what you suggested, but I'm just running the little amp (which I think draws a max of 50a as it has two 25a blade fuses on it), and the M2(25a) = total of 75 - 80.
    Fuse 1 protects the full load and wiring, fuse2, which will be in the distro, will protect the amp, and fuse3 the PC.
    You reckon that would do it?
    Oh yeah, and I ordered my Xenarc today! I was a bit ****ed off, they where on sale a while ago on mp3car for $US250 and I saw it when I was at work on friday and thought "cool, ill order one tomorrow when I can read all the terms etc and do it properly". Come Saturday I go to order and they are all sold out! Long story short, I had to pay $US359 for one of 12voltpc.com. Hope all goes alright :S
    Mar 2008
    Canberra, Australia
    Here is the latest revision of the wiring Diagram. Also, has anyone ever taken apart a VoomPC 2 case? I got one of the pre-made stage 3 ones from mp3car, and want to get into it so I can run power to my screen, but am a little hesitant to pull it apart. I had a dig tonight, but it all seems tightly packed in there, and I don't want to break anything!
+ Reply to Thread
  1. Holden VY Commodore Install
    By Milo in forum Show off your project
    Last Post: 03-31-2008, 07:25 AM
  2. 2004 Seat Leon - Costum install
    By guvi in forum Show off your project
    Last Post: 01-17-2008, 05:05 PM
  3. Acura TL 2004 touchscreen install
    By moahdib in forum Fabrication
    Last Post: 10-22-2006, 11:00 AM
  4. need tips for 2004 accord sedan install
    By keghead in forum General MP3Car Discussion
    Last Post: 07-07-2006, 05:48 PM
  5. Holden VS Commodore Carputer Finished
    By XtremeX in forum Show off your project
    Last Post: 12-22-2005, 05:19 PM
