Well I installed my SSD and it was a f#c&ing nightmare. If I ever have to do this again i'll die. First I installed the OS then had to call Microsoft to validate the thing. I then started to update the OS, but it was working all clunky. My PC wouldn't download the South Bridge Drivers. I said screw it and redid the OS again, but this time I installed anything that had to do with the MoBo. All its on board drivers installed and working. The PC still had some lag, so I took the advice from Salmizar from the CF forums and turned off page files in the OS. Now it works flawlessly. I started to slowly install all the devices, got HD Radio, XM, AMP_CTRL and OBD2. Basically all the serial devices. Tomorrow I will slowly install the USB devices, starting with the USB Relay that didn't work before on my Car PC. Once all the devices are installed I'm going to make a Image of the OS, so in the future, I can easily restore. I tried Shadow Protect but it wouldn't work. I'm going to try to find my Ghost CD.
Here are pix of the plastic plate that holds the HDD, and SSD over the PC. It actually helps to reflect air down into the PC. Even at max, the HDD, SSD cannot even get warm.
LinkBack URL
About LinkBacks
! The UK post is **** as well they lost my Lilliput monitor and the tracking number just happened not to link to anything, and apparantly the recipt they gave me is only proof of posting it doesnt cover them lossing it! I was soo ****ed off, thats £120 down the drain
