Page 25 of 83 FirstFirst ... 15161718192021222324252627282930313233343575 ... LastLast
Results 241 to 250 of 824
Thread: 2003 Durango SLT / Project HiJackZX1 / 56K= D@mn this $h!+ is gonna load slow!
  1. #241
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by SwiftDeath View Post
    I still don't understand why you can't just connect the touchscreens to a usb hub connected to your computer and assign them virtually. Maybe I missed something that your attempting to do? If you wanted to, you could put an automatic or manual usb switch between the touchscreen and the hub so it switches to a different connection.
    The problem with assigning them virtually is that say for example your in shared mode, it will work fine, but when you switch to single mode, the touchscreen will still continue to control only the host PC. Now thankfully NComputing has excellent customer support, these people really know their $h!+. We literally had almost an hour long conversation. One thing that was brought up is that their statement about only supporting flash drives, is the safe statement. Alot of their customers have got lots of different devices to work. He would not tell me how though, lol. He also mentioned that the USB port is not powered, this means if I use a wireless keyboard, I have to make sure it is powered via a USB hub. What I may do is actually buy a 15W PSU for each terminal. This would allow me to power the L230 Terminals and a 4 port USB hub. If this method works, it means I can simply use a USB KVM switch. He also told me about a 30 day trial and that I should buy a unit, see if my devices work, and if they do, I'm good to go. I may take them up on that offer.
    In all what I am trying to do is have each user be able to control 2 sides of the PC, their single PC experience and a combined user experience. Basically the L230 cant handle high multimedia stuff. It can only handle basic stuff. So say they want to watch SatTV they switch over to combined mode to control the channels and what not. Then if they want to browse the internet or go on a messenger, they just switch over to single mode.
    On a side note, my hinges have been sent out from Esela USA Corp. I will be able to work on my screens soon.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  2. #242
    Low Bitrate SwiftDeath's Avatar
    Apr 2009
    Chicago, IL
    Ah good I was worried that it was in some way my fault that you were having such trouble, but in reality it's because you want so much fre@kin' control and options.
    My hat was off to you when I first read your worklog. It's somewhere in the basement now......
    Edit: I was also worried for my own skin because the way I mentioned was how I was planning to do it, but I think it should work fine for me.
    -SwiftDeath
  3. #243
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by HiJackZX1 View Post
    Ive decided to strip my car later today and start wiring the Cat5 cable. and other electrical cables. Thankfully I had a box of 1000ft of it, I just need someone to attach the connectors on the end. The stereo wire will also be run through the top, to avoid any EMI.
    You could do your own connectors. The Cat5/Cat5e tool is available at Radio Shack (about $40), but here's a link to the AntOnline page where the crimper and tester kit shown below is $38.13, including shipping. That's a good deal. Add 50 connectors for $9.
    Putting the ends on is not at all difficult. It takes some care, but you have lots of ends to put on, so you'll still come out ahead.
    There are two systems for wiring Cat5 cables, called "A" and "B", and you can use either one, as long as you use it on both ends of the cable; "B" is the one most commonly used. If you use "A" on one end and "B" on the other, you get a crossover cable.
    Here's a link to information on putting the ends on, and here's another. With a little practice, you'll zoom through the job, you won't have to pay anyone, and you'll have the tool and tester to keep.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  4. #244
    Jul 2007
    Miami
    LMFAO, no its cool the way you explained it. From my work log though, you should have got that I like to complicate everything, LMFAO. The Ncomputing guy thought I made it complicated too.....
    Quote Originally Posted by rdholtz View Post
    I have the crimper, but not the meter to test if I did it right. Maybe its because im not patient.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  5. #245
    Apr 2007
    Atlanta, GA, USA
    Get the tester. You'll really appreciate it the first time you screw up a cable and the tester tells you; without it, you could chase the problem for a long time.
  6. #246
    Jul 2007
    Miami
    i agree, im going to go ahead and get it. Im also going to redo the factory harness and basically remove it. I need the space for all the new cables. My biggest challenge is running the VGA cables...... Any suggestions on that? I dont want to have to drill huge holes in the frame and door to run them.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  7. #247
    Apr 2007
    Atlanta, GA, USA
    The tiny VGA plug on the side of the Lilliput tells me there are smaller cable ends you could use. Maybe those ends are available at Mouser or some comparable place; it's possible that using them would let you run smaller adapters, and therefore drill smaller holes.
    But there's an alternative: in the electrical department, you can find a clamping adapter that holds Romex as it goes through the side of a wiring box. They're available for several hole and cable sizes. That would be one way to cover the holes you make using regular VGA cables.
    You could also cover the holes with a cover plate held on with screws. It would make a much cleaner installation than the Romex adapter. You could attach the covers with sheet metal screws, but, if you put rivet nuts in the door panel, you could use machine screws so there would be no pointy end on the fasteners.
  8. #248
    Jul 2007
    Miami
    You lost me... lol.... The Lilliput is not problem because you can unscrew it and then reattach once in the hole. I also have to run extension cables for the KVM switch. I think if I cut the end off, like the part with screw holders, it will fit easily.
    I got the hinges and connected them, they are awesome. Just hate what I had to pay for them.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  9. #249
    Apr 2007
    Atlanta, GA, USA
    I was suggesting you might be able to (1) adapt the VGA to a smaller plug like the Lilliput or (2) use the full-size VGA plugs, but cover the holes for them pretty nicely.
  10. #250
    Jul 2007
    Miami
    LMAO, I thought that was what you said.
    I am now trying to figure out how to make the sides and what not for the top screens. I think it will be easier then I thought. I guess it took me having the hinges to image what I need to do. I now have to get Nexson to see my vision and make it a reality.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. Project 2003 Dodge Dakota
    By Eternalodyssey in forum Worklogs
    Last Post: 10-29-2009, 09:35 PM
  2. 2003 Mazda 6 project
    By Brunation in forum Show off your project
    Last Post: 06-15-2009, 09:51 AM
  3. Mitsubishi Outlander 2003 Project
    By angelito46 in forum Newbie
    Last Post: 05-23-2007, 09:05 AM
  4. New 2003 Saturn L200 In-Dash Project
    By snoslicer8 in forum Newbie
    Last Post: 08-20-2006, 11:06 PM
  5. New carputer project started - 350z (56k beware)
    By StutterinJ in forum Fabrication
    Last Post: 05-22-2005, 08:45 AM
