Page 33 of 83 FirstFirst ... 232425262728293031323334353637383940414243 ... LastLast
Results 321 to 330 of 824
Thread: 2003 Durango SLT / Project HiJackZX1 / 56K= D@mn this $h!+ is gonna load slow!
  1. #321
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    Quote Originally Posted by HiJackZX1 View Post
    I ran out of VGA and USB extensions, so I ordered more from BuyExtras.com, they are awesome, $3.45 for USB extensions, thats cheap, with $.99 shipping. The VGA was $12.95, but Office Max sells them for $12.99 so I bought 3 from there.
    Also might want to check Monoprice.com too for cables. 15' USB Extension for $1.53, shipping is based on weight so grab a couple for the cheap.
    Is the 99cent shipping a flat rate?
  2. #322
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by jpinkerton View Post
    Yea, its free shipping in the USA, with $.99 handling fee.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  3. #323
    Jul 2007
    Miami
    OK, after pulling my hair out on how to get a USB port to each door, I decided to just do it the easy way and have all the ports added to the center console. I am also going to have all power and PC selection buttons in there also. This of course means a total redesign of the console again!!!!!!!!!!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  4. #324
    Variable Bitrate vincenttor's Avatar
    Nov 2008
    why not buy some usb cable and then put then from the hub to the doors ?
    i use for my wifi antenna a 10m cable + a 5m with a amplifier between it to boost the signal works perfect
    or is that not what u mean
  5. #325
    Jul 2007
    Miami
    Quote Originally Posted by vincenttor View Post
    The problem is its six different computers. So PC1 has to extend to Door1, PC2 to Door2, and so on. Anything over 10 feet has signal lose. The front door is about 20 feet, rear door about 13 feet. If I have the USB come to the console, thats 7 feet for all USB cables. I did reconsider the power, PC selection, and audio port. Instead of also having it in the console, I am going to put those in the doors. I will run everything via CAT5 cable. A CAT5 cable has 8 wires inside, so 2 for power, 2 for pc selection, 4 for stereo sound. I dont have distance issues with those components. I started to run all the ethernet cable, so thats all mostly done, still have to run from ethernet switch to Main PC. I also have to make a port on the console so I dont have to take the console out all the time to get to the second ethernet port on the Main PC. Problem is because I am adding 8 ports to the front of the second console, the whole thing as to be redesigned, also have to add the DVD Rom, and card reader. The 2 USB ports for the rear will go at the rear of the second center console. I hope this will work out. I am going to build this with SketchUp though.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  6. #326
    Jul 2007
    Miami
    OK, went to RadioShack and picked up some small push buttons. They will be incorporated into the armrests. They didnt have enough, so I oredered the rest from Parts-Express.com. I also ordered 6 stereo headphone jacks also. This will be a easy mod because all I have to do is drill holes and screw them in. The buttons will be a challenge because I dont want the metal part showing. So I may mount it in a way so that only a small part of the top of the button sticks out, but enough so that when it is pushed, it does its job. Red is for power, and black is for PC selection. For the main PC, red is for power and black is for reset. The personal PCs will use EWF and HORM, so restart isnt needed, just power on and off.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  7. #327
    Jul 2007
    Miami
    Arm Rest Controls.
    I started on the door controls for the personal PCs and headphone jack. Have a few issues with the prototype, so need ideas on how to fill in the holes that I made to big.
    I did take out the driver side and the control that it uses is massive. I cannot fit really any controls into it. I have decided to delete my hot key idea for CF and pray I can fit the power and pc selection and headphone jack some how. The camera system will use the arrow keys which use to control the mirrors.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  8. #328
    Mar 2008
    With your USB issues, have you thought about usb Ethernet USB extenders, basically, usb female one end, usb male the other end and up to 50ft inbetween with no signal loss
  9. #329
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    I started on the door controls for the personal PCs and headphone jack. Have a few issues with the prototype, so need ideas on how to fill in the holes that I mad to big.
    The easiest way would probably be to determine what the material is, and use a hardening plastic filler that adheres to it. Then re-drill to the proper size.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  10. #330
    Jul 2007
    Miami
    Quote Originally Posted by WraithJ View Post
    My USB issues are all fixed, I have to run them to the center console because I dont have room on the armrests. Although it looks like they do on the top, under it has a $h!+ load of electronics.
    Quote Originally Posted by rdholtz View Post
    yea its plastic, can I get palstic filler at home depot?
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. Project 2003 Dodge Dakota
    By Eternalodyssey in forum Worklogs
    Last Post: 10-29-2009, 09:35 PM
  2. 2003 Mazda 6 project
    By Brunation in forum Show off your project
    Last Post: 06-15-2009, 09:51 AM
  3. Mitsubishi Outlander 2003 Project
    By angelito46 in forum Newbie
    Last Post: 05-23-2007, 09:05 AM
  4. New 2003 Saturn L200 In-Dash Project
    By snoslicer8 in forum Newbie
    Last Post: 08-20-2006, 11:06 PM
  5. New carputer project started - 350z (56k beware)
    By StutterinJ in forum Fabrication
    Last Post: 05-22-2005, 08:45 AM
