Results 1 to 5 of 5
Thread: '02 Toyota celica TS
    Constant Bitrate John_Duh's Avatar
    Feb 2005
    Belgium
    The history
    I used to own a Celica TS, with carputer install as can be read in my old worklog thread : '05 Celica TS
    And then this happened
    The future:
    I bought a second celica TS, a gray one this time around, 'cause i couldn't find a black one.
    The plan:
    I want a pico system with a fixed screen install.
    So far I got my pico system assembled, but I'm having some trouble installing windows since it doesn't have a CD drive (and i'm refusing to add a cd drive just for installation purposes)
    Suggestions welcome ... I now arrived at the point where i'm going to take the HD and plug it in my other computer to format and copy the install-files. Then use bartPE to boot and start the install from an external USB-drive.
    Needed
    Usb Wifi adapter with external antenna (do powered external antennas exist ?)
    USB storage array (got a couple of spare HD's which could be used)
    '02 Toyota Celica TS
    Carputer progress : [#######---]
    Currently working on : software ...
    Parts : IBM thinkpad X60 wired up in the booth (T7200 - 1.5Gb Ram - 320GB HD)
    Parts needed: USB wifi dongle (with external antenna)
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Sorry about getting your black baby punched to the boneyard. The gray looks good, though . . .
    I'm not hands-on familiar with the ARTiGO PicoITX kit, but I've been reading about it.
    First idea: it has both SATA and IDE connectors. Could you use a SATA hard drive and add an IDE CD player during setup? It would probably require a 2.5"-to-3.5" adapter, and you'd have to get a SATA cable.
    Second idea: I believe the board has a 2.5" IDE interface. (1) Can it support two drives on that interface? (2) Can you select the boot source in BIOS?
    If the answer to both of those questions is "yes", then two inexpensive 2.5"-to-3.5" adapters might do the trick. If you use one of the 2.5"-to-3.5" adapters to attach a standard IDE cable, then use one connection for the other 2.5"-to-3.5" adapter with a 2.5" IDE hard drive (as master), and the second connection for a standard IDE CD player (as slave).
    Set the BIOS to boot from HD first and CD second, and it will boot from the CD because it won't see a formatted HD. You'd be in business.
    I hope one of these works for you . . .
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Feb 2005
    Belgium
    Quote Originally Posted by rdholtz View Post
    Damn ... it's been ages since i've been here. Back on track though.
    In the end I just coughed up the money and bought an external USB CD-drive. Came in handy as well since my trusted laptop (Thinkpad X60) also doesn't have a CD.
    All was well until one day i was fiddling with the pico-itx and a plume of smoke rose from the mobo. Don't exactly know what went wrong, but it went wrong big time and that's the end of the pico-itx story.
    The new plan
    Go with a laptop based install.
    I've been playing with this idea for some time, but it had one major downside : sound quality of my thinkpad SUCKS big time.
    While i was thinking about this audio quality thingy, I got myself a nice pioneer head unit with Bluetooth and used my phone (HTC Polaris) as music player. Works as a charm, and got me thinking. If that phone can get a good quality audio signal to the had unit, than my lappy should be able to do the same. And guess what, the crappy sound is really due to the hardware audio card. When i hook it up through BT i get decent sound. (i'm sure audiophiles will still think it's crappy, but for my ears it's more than good enough)
    Next problem, my music collection is rather extensive and won't go on the standard HD, so an upgrade is in order. I bought myself a nice 320Gb hd, which spins at 7200 rpm. So getting some speed update as well. The downside is that cloning the HD didn't work (tried almost all software and none worked)
    So spent another couple of hours setting up my lappy again with the new HD.
    Anyway, the last couple of days i got it all together and installed
    Ultrabase X6 - installed in the booth
    Thinkpad X60 - set up with separate Carputer account and the necessary music and software
    700IDT - installed in dash (duh) and wired to the base in the booth
    Future plans
    - get GPS navigation going (preferably fast since i'm leaving on a snowboard trip soon :-p)
    - use second video capabilities of the screen. (backup camera)
    oh and i know this thread needs pictures
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by John_Duh View Post
    The downside is that cloning the HD didn't work (tried almost all software and none worked). So spent another couple of hours setting up my lappy again with the new HD.
    What likely happened is that, while your PicoITX was a Via chip, the laptop is probably Intel or AMD. It's nearly impossible to clone drives from a board based on one manufacturer's processor to a board based on another's processor. I'm told it can be done in theory, but I've never known anyone who actually did it.
    Low Bitrate thatslife's Avatar
    Mar 2007
    Miami,FL
    A little late but it sucks to what happen to your first celi. I hope nothing happens to mine I'm just starting on it
    Quick question what do you mean the laptop is in the booth? Ive been thinking where to permenantly put my laptop and all I can think of is under the trunk cover or in the trunk itself on the left side right now it'll be under my seat
  1. 2000 Toyota Celica GTS
    By CelicaGTS in forum Worklogs
    Last Post: 05-25-2008, 02:01 AM
  2. Help with a '94 toyota celica.
    By woosey in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-30-2007, 11:35 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. Toyota Celica 2000-> GT/GTS and LCD
    By Goose in forum LCD/Display
    Last Post: 12-24-2005, 11:34 AM
  5. Toyota Celica GT4
    By beck in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-29-2005, 12:48 PM
