First, I decided to install the PC under the back seat. There's plenty of room back there in the Ridgeline, and I was only using it for an extra diaper bag and umbrella. The seats split unevenly to flip up, so I put the PC under the smaller split, which is (conveniently) not where the baby seat is installed but is (inconveniently) on the passenger side of the car.
To use the PC back there, I needed power. I used 8ga Streetwire cable (came in a kit with a fuse), attached the fuse assembly to the plastic box that the battery sits in, and ran the cable through a rubber grommet in the firewall. This was easier than I expected: a small "X" incision made with an Xacto knife was enough to just push the wire through. The picture shows where it enters the car - the vertical black bar is the gas pedal. This is an easy spot to find in the engine compartment; I just pushed a coat hanger wire through the "X" and it was obvious where to push the wire.
The next three photos show the wire run coming under the carpet on the driver's side and down the side of the car under the kick panels. I had to remove the driver's seatbelt to get the panel off between the front and back doors. Once the panels were off, it was an easy run. The power lead then runs at the base of the back seat and comes up into the plastic underseat pocket - and into the PC.
LinkBack URL
About LinkBacks
