Page 10 of 11 FirstFirst 1234567891011 LastLast
Results 91 to 100 of 102
Thread: 2000 MX5/Miata EEEPC CarPC (Photos)
  1. #91
    Sep 2008
    North East Pennsylvania
    I guess I'll find out this weekend, hopefully I won't have the same problem. Thanks for the info!
  2. #92
    Constant Bitrate lacning74's Avatar
    Apr 2008
    Power switch relay
    I just connected a regular Bosch auto relay to my power switch after I realized that if I press and hold down the power button of my eee pc, it has no problems starting up and staying on. I read others have just jammed their buttons mechanically in their battery-less old laptops so that it turns on when it receives AC power.
    I connected the leads from my laptop's power switch contacts to pins 30 and 87 of the relay. I had soldered a headphone jack for this.
    Then I connected 86 to an ignition-switched fuse line and 85 to ground.
    Not as elegant as a momentary switch, but it's cheap, compact, and works!
  3. #93
    Sep 2008
    Thanks again. I'll let you know how I make out this weekend... I may have some questions for you if my solution doesn't work!
  4. #94
    May 2008
    Australia
    i guess it worked?
    i've got two weeks off work from Wednesday, so I'll be working on this a bunch more, hopefully should get some pics.
    MX-5 Carputer Progress:
    (Check ibfragalot's Worklog)
    Purchase [****_] 95%
    Design [*****] 100%
    Install [*****] 95%
  5. #95
    May 2008
    Australia
    BIG UP to Centrafuse. I just drove interstate, 550kms or 350 miles using CF and its navigation. it performed perfectly. very pleased.
    Design [*****] 100%
    Install [*****] 95%
  6. #96
    Low Bitrate elricfate's Avatar
    Jan 2007
    Columbus, Ohio
    Okay. I GOT to know how this is turning out.
    Other than you using an Eee 900 (instead of a 700 with eeectl or a 1000), I have the same ideas.
  7. #97
    Constant Bitrate bluehcc's Avatar
    Jun 2004
    Queens, NY
    I am also running EEE PC in my Camry. I hacked the power button in my EEE 900A. The power button is connected to a momentary relay. When I turn on the engine, relay will make a short to turn on the pc. EEE PC will go into standby mode 1 minute after shut the car engine. It take no time for eee pc to return to gps/music mode when you turn on the engine the next morning. I do have a problem, may be you can help me. I press the power button but the eee pc wont turn on if the lid is closed. If I open the lid half way through, I can turn it on with power button or a short. In this case, I have to leave the eee pc half way open in my glove box. Any idea workaround??
    2006 Camry
    Compaq Laptop
    Holux GPS Iguidance 3.0
    7" Xenarc Touch Screen
    Carnetix 1900 Power Supplied, Wireless b/g
  8. #98
    Newbie braidy's Avatar
    Feb 2006
    Quote Originally Posted by bluehcc View Post
    Take the magnet for the screen switch out of the screen surround.
    1994 ED Ford Falcon GLi Classic
    Hardware: Acer Travelmate 3200, Car Charger, Lilliput 7"
    Software: Roadrunner (Simplistique), WinXP Pro, ShutControl
    Progress: [|||||||| ] (100% - For Now)
  9. #99
    Jun 2004
    Queens, NY
    Did you meant pull the lcd screen apart and then take out the magnet?
    2006 Camry
    Compaq Laptop
  10. #100
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Take the LCD bezel apart. Check this page for information on its location.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  1. muting head unit audio when carPC outputs audio
    By augieman in forum General Hardware Discussion
    Last Post: 04-18-2006, 08:35 PM
  2. For Sale: CarPC EZ v.2.5d
    By stevent76 in forum Classified Archive
    Last Post: 12-23-2005, 09:55 PM
  3. CarPC Gets BLACKOUT! when monitor is connected!
    By Sympotonic in forum General Hardware Discussion
    Last Post: 12-08-2005, 04:30 PM
  4. speed up win 2000 boot time
    By more mods in forum Software & Software Development
    Last Post: 06-09-2003, 12:05 PM
