Results 21 to 30 of 34
Thread: 1998 Ford Explorer Project
  1. #21
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    It will take longer to dry than fiberglass, but in the end it will be one piece chemically, rather than two or three different pieces glued together if that makes any sense.
    You might also want to get a small squirt bottle (think ketchup and mustard bottle but a little smaller.) to make it easy to apply. Maybe practice with a piece you cut off to see how it all acts.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  2. #22
    Jun 2008
    can I smooth this abs cement with sand paper
  3. #23
    May 2007
    Lakehood, CO
    yup, check out my worklog to see what I am doing with that stuff.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  4. #24
    May 2007
    Lakehood, CO
    see:
    that's after a short sanding session...
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  5. #25
    Jun 2008
    Alright I added the ABS cement on and now im letting it dry before I sand it and then add some more coats. While I wait I modded my radio kit so that my HDD Media Player sits in the pocket din beneath the head unit. Im thinkin of closing the sides so it will look more flushed. Ill fill that up later
  6. #26
    May 2007
    Lakehood, CO
    once it dries (couple hours) you'll be able to take normal sand paper to it. make sure it's nice and hard, because uncured ABS will gum up the sand paper and you'll have to do it over.
    I like to start with 120 grit, then go to 220 then 600. You'll need to paint it because it turns grey when you sand it. Krylon fusion works well and actually bonds to the plastic, plus they have a texture paint to make it look like it came that way, oh and it's chip and scratch resistant too:
    First layer of ABS cement:
    After first sanding run:
    After sanding, before texture:
    After texture:
    Here's the posts with good shots of my old bezel to show the process:
    1997 Ford Taurus LX Install, follow along kiddies...
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  7. #27
    Jun 2008
    word thanks for the help man. your a great help.
  8. #28
    May 2007
    Lakehood, CO
    glad to help and spread the word about the ABS cement, this stuff is great, it is cheap (under $10 for more than most would need) and easy to use (apply, let dry, sand, apply more to low spots, dry, sand, done.) and is the same kind of plastic as most screen bezels and a lot of dash pieces. Way better than FG and/or bondo, etc that will just end up (possibly) cracking down the road a few months or years later.
    You work fast, but this stuff has to be close to cured before you take the paper to it. I'd say overnight would be safe, but at least 5-6 hours if you just can't wait. The rule of thumb I've used is this:
    1/16th" thick - 4 hours
    add 1-2 hours (depending on ambient conditions) per 1/16th" after that.
    So if you have 1/4" thickness, I'd say it would take 8 hours or so to dry.
    In the posts linked above, it was about 8 hours for the first layer and the subsequent layers were thinner, so only about 5 hours each time.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  9. #29
    Jun 2008
    Aight so I sanded then filled sum holes then sanded and then sanded some more. Jeez, its so time consuming and I still dont think its perfect yet. Ill put sum pics up tommorow. Ive been super busy. Also I decided to do away with my original HDD Media Player and I bought a more expensive one. This one I can take my Maxtor Hard Drive out of its case and install it in the media player. So now I dont have to power the media player and the hard drive seperately, I can just combine the two.
    Question for Monkey: Do I need to use primer with that paint you recomended
  10. #30
    Jun 2008
    As you can see I still need to sand more but its coming along nicely and the HDD Media Player i ordered looks much better that the cheaper I bought already.
  1. 1998 Ford Explorer The Boom Boom Truck
    By fikedemon12 in forum Show off your project
    Last Post: 06-20-2008, 04:33 PM
  2. 06 Ford Explorer Nav Radio (TV MOD) How to???
    By roveer in forum General Hardware Discussion
    Last Post: 08-17-2006, 04:35 PM
  3. MACH stereo in Ford Explorer
    By seven10split in forum General Hardware Discussion
    Last Post: 07-11-2005, 03:59 AM
  4. 1998 VW GTI VR6 Project
    By Stavros in forum Show off your project
    Last Post: 01-27-2003, 12:16 PM
