Results 1 to 10 of 19
Thread: 2007 Ford Mustang
    Oct 2007
    2007 Ford Mustang
    Been around the boards for a number of months now reading and learning about the science of Carputers. I think nows a perfect time to start my worklog. I hope to make a valuable contribution and learn from any mistakes along the way. Without further ado here goes...
    Ok so first off here is a list of hardware i've bought so far to begin with.
    Mac Mini $300
    Logitech® diNovo Min $100
    MacPac $29
    Carnetix p2140 $135
    Lilliput 8" $239
    HippoHi-fi Bloat 24-bit USB DAC $187
    I'm no engineer although i am pretty handy, so here's what i have in mind. I want my install to look as close to factory as possible, so i've picked the center console to install the Mac Mini in, but it wont be an ez feat to accomplish since i will be trying something i havent quite seen on the boards yet. This is my center console, so what i want to do is cut open a small section in the back in order to slide the Mini in. So in essence the front of the Mini will be facing the backseat and the cables and wiring will be inside the center glovebox. I'm going to have to hack up the center console a lot, but i'm willing to do it. The only thing is that i haven't decided on how to do this. I pretty much have any tool i could likely use for the job and my own workshop, so i just need ideas. Since, i'm starting tomorrow can anyone offer some ideas???
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Take some pictures of the disassembled console, give some measurements, and we'll have a better idea what you're facing.
    Tomorrow may be the "official" beginning, but don't be in a hurry to hack away. Planning and measuring and pondering still count, and they can save you lots of grief later.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Oct 2007
    I'm thinking of constructing one of these Mini holders as a frame to install in the center console. It could be done using 4mm wood sheets as the material. A frame would be much better than simply cutting a hole to slide the Mini. So this would double as a harness and frame.
    P.S. will take measurements tomorrow, thanks for the heads-up.
    Vendor - Qube colin's Avatar
    Dec 2006
    Why do you have to hack it up? I wanted to put my computer in the center console as well but mine's HUGE. Your computer is small, it could most likely fit right in if you simply removed the inner plastic piece (assuming it's the same as an '01). Run the cables along the floor under the center section and there wont be a problem. Don't try to get anything in the trunk though, the carpet on the center beam in the rear seats is SKIN TIGHT, you'll have no fun ripping that up.
    Oct 2007
    Colin you bring up an interesting point. After evaluating both options i think the Mini could fit in the cubby box with few modifications. Originally i chose to hack up the console in order to avoid the inconvenience of taking out the Mini everytime i wanted to insert a CD in the optical drive. By cutting open hole in the back of the console i would have avoided this, but at the expense of the factory look of the console. Take a look at this picture...
    Currently the Mini can't fit inside completely without hacking up some of the black paneling. I'm a little concerned about overheating, as it can get pretty hot inside my car in the summer imagine in there, maybe i will have to add an exhaust fan.
    Secondly, I want to integrate the Lilliput housing case to my radio bezel, but ran into some minor problems. Since im using the 8" lilliput the back side of the Faceplate has some protrusions sticking out. Check out pictures..
    I want to go from this...
    To this...
    But ran into this...
    I'm thinking i should use a Dremel tool to hack off those limbs in the back and use epoxy to attach the casing. Of course i want it to look flush so i will have to take additional steps, if anyone cares to chime in some ideas feel free.
    Oct 2007
    How long is it suppose to take to have a post approved?
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    until a mod approves it. It could take 5mins, it could take a day
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    Those little tabs on the sides should come off pretty easy with a set of wire cutters. But in removing those, are you going to lose any stability putting it back in?
    As far as epoxy is concerned, look at the sticky here about fabricating the piece to look oem. There are some great products and techniques discussed there. I personally use ABS cement since both pieces on my dash are ABS. Check out my worklog to see what I'm talking about.
    If you go either route, it would only take a small amount to get the job done. I'd tape the front of the bezel (with screen removed of course) and apply either the epoxy (dries pretty quick) or the ABS cement (takes a little longer) along the back edges. This will make sure it's solid. Then once that side is dry, remove the tape and apply a small amount in the gaps between the dash piece and bezel, allow it to dry and sand down to a nice smooth shape. You'll have to be pretty careful around the button area, the cement is the same chemical as the bezel, so any cement that gets in contact with it will start to bond with it pretty quick. It would be a good idea to tape off that area when you work on that part.
    Good luck, keep us posted with your progress.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    Feb 2008
    i dont think you can get the whole lilliput case in the dash without a lot of hacking, those are alignment pins so that the faceplate will line up properly i know you have the screen already but if you check out a thread in by blk02si he put a comp in his 06 stang and you might get some ideas how to mount the screen
    Oct 2007
    8" lilliput bezel for double din
    Ok so i finally got the bezel for my 8" lilliput integrated into my stock double din faceplate, thanks monkey for the thread.
    Before going under the knife...
    Me taking measurements...
    The job is halfway done...
    I consider this the fun part. The dynatron box is the 2 part epoxy i used to attach the screen bezel with my stock double din faceplate. This process is pretty straightforward, just follow the mixing instructions in the box and apply. Add several layers, depending on how much you want to build it up.
    Make sure you tape off the buttons so you wont get this stuff on them. By the way this stuff reeks and dries very quick.
    Next set of pictures will include the sanding, painting, and finished product. By the way will be using 36 grit to rough sand, should it be wet or dry? Will follow up with 100 grit, then 400grit or 600grit. I've never worked with this material, so any tips are welcomed.
    If you notice on the pictures you will see that i cut very high up on the faceplate. The three openings are for the hazard lights, cigarette lighter and a dummy button. The only button i really want to reattach is the hazard lights, so that means i need to either close off the other two or find a constructive use for them, any ideas?
  1. 2007 Ford F150 Truckputer
    By Jinxed in forum Worklogs
    Last Post: 06-23-2009, 07:46 PM
  2. 2005 Ford Mustang V6 Prem. CarPC Project
    By mdlesk in forum Show off your project
    Last Post: 10-17-2007, 10:46 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. Replies: 3
    Last Post: 10-16-2006, 03:00 PM
  5. 2003 Ford Mustang GT
    By tj!2k4 in forum Worklogs
    Last Post: 03-05-2005, 03:42 PM
