Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 77
Thread: 2005 Ford F150 MAGNUS Truckputer - project and pics
  1. #31
    Constant Bitrate Kalenth's Avatar
    Aug 2006
    DFW
    Quote Originally Posted by blk02si View Post
    Lookin Good Kalenth!
    Just read through your recent updates, sorry to hear about the m10000.
    I've been really checking into ITX boards and they are getting very cheap and very powerful!
    I do like laptop idea, and the rest of your work on the f150, keep the pics, and the cool drawings, coming!
    -Joe
    Thanks man! It's nice now that everything is coming together and going in.
    I ended up putting 2 controls in the truck for the power issue. To the left of the steering column, I put a temp switch to power on the LT, and a toggle switch to control the master power source. The 12v line that it controls is always hot... so with a master toggle, I can keep the system on when I am running quick errands, etc... and shut it all down when not in use.
  2. #32
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by Kalenth View Post
    That's one of the things that differentiates American vehicles from their Japanese competition: most American cars seem to have power circuits (cigarette lighter ports) that are always live, where most of the Japanese cars I've seen -- including Toyotas and Scions -- have them switched with the ignition. While the switched circuits are good defense against dead batteries for most car owners, carPC jocks are "power users", and we like to have choices.
    We get to make choices available by modifying the wiring or adding circuits. I'll be adding carPC circuits in the Scion, one to power the PC itself (12V) and the rest for the accessories (5V), all running through the M2-ATX 12V-12V power supply. Then I'll add switches similar to what you've done.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  3. #33
    Aug 2006
    DFW
    Word! I finished getting all the wiring done, but I'll have to wait till tomorrow to install and document. We left the camera at the sisters house during thanksgiving.
    I keep thinking about powering everything through my M2... simply because I need to power an external USB dock that is 5v... I had been looking at making a resistor or something that would bring down the natural voltage, but I hadn't even thought that the m2X would do that for me...
    I think for now I'll stick with the vehicle 12v line, and add accessories as needed.
  4. #34
    Apr 2007
    Atlanta, GA, USA
    Yeah, that's what I planned originally, but I decided the wiser route for me is to use the power regulation capability of the M2-ATX. It provides very clean, stable power, and I hate to leave things to chance. I'm running through an inverter right now, taking 12V power, converting it to 110V, and plugging the EeePC power supply in there to convert it back to 12V. Although it seems to make that inefficient round trip with the voltage, I don't have a 12V adapter for the EeePC. And I know the inverter does some conditioning, so it's fine until I get back home and can install the M2-ATX. I'll install the accessory wiring -- for the USB hubs -- at the same time.
  5. #35
    Aug 2006
    DFW
    I think I found a solution other than the M2, or wiring in my own resistors, to get the 5v thing resolved... a USB 12v charger from radio shack. I can just take the guts out of it and BAM, instant 12v to 5v adapter.
  6. #36
    Aug 2006
    thats a really good idea
  7. #37
    Aug 2006
    DFW
    Well, it by no means is an original one... but as long as the information gets shared to others, the boards have done their job.
    BTW, I found a sweet background image for the truck... it just seems to fit well.
  8. #38
    Aug 2006
    DFW
    Installed, working on power issues
    I got the system installed and hooked up today. Everything is working as it tested inside, however, I have some power bugs to work out.
    I installed 2 switches by the steering wheel... one was my phone cable mod meant to be a temporary switch to power on the system. Fairly straitforward.
    The second was a "master switch"... the f-150 dc stays hot even when the truck is off... since I was tapping into a 12v rail that would remain hot, I wanted to use a master switch to either provide complete power for the system, or cut power to everything and prevent leaching while the truck is off.
    I ended up using a 3 prong power switch with an LED that illuminated red when on... I tested it and got it working inside, got all the wiring secured, and installed it today... I had issues after it was installed though. It seemed that when I plugged the dc adapter on the other end, whether the switch was on or off, power would still be going to the accessories.... the light also went out on the switch... so I am thinking that I may have burned something up when I sautered the wires on.
    Tomorrow I am going to get another switch, and some larger guage wire and run through this process again. I know there are other solutions to the power issue... but I sold my M2 and I now have a mount hole in my dash that needs to be filled.
    Test drive went well, the icons are big and easy to use, the iGuidance5 works well, all other programs work as needed, and it is very viewable and easy to use. I do want to find a way to make the system icons larger (minimize, max, close) and some of the menu buttons... but it is otherwise working well.
  9. #39
    Aug 2006
    DFW
    Laptop drawer mount
    I think I am going to nix the drawer idea... I could get it working with some more work, but I honestly think, for simplicities sake, that I will just solid mount the tray and dock to the interior. I can get a small keyboard/mouse to use, and the laptop will still be removable... so I think it will still work out. For the most part, I don't see a rider using the laptop while the vehicle is in motion, so I think in the long run this is the better call. Plus, with wires not being moved in and out, there is less chance of interference or a cable getting disconnected.
  10. #40
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    you can use this application to turn on your laptop automatically
    but instead of using 12v at 87 and 30 you just plug in the pins from your power extension switch
    and at 86 use ACC so that it engages the relay when you tunr the key to ACC
    as for shutting the laptop down, someone here wrote a program specifically for laptops that can detect when the power adapter is unplugged and it shuts down the laptop, just do a search for it i don't remember what it's called though
  1. 2005 Ford Mustang V6 Prem. CarPC Project
    By mdlesk in forum Show off your project
    Last Post: 10-17-2007, 10:46 PM
  2. How can I use a laptop as a carpc?
    By turbocad6 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-11-2007, 01:55 AM
  3. 2005 Infiniti G35 Pentium M CarPC
    By Caelric in forum Worklogs
    Last Post: 11-24-2006, 01:16 PM
  4. 2005 Mercury Mariner - First CarPC install
    By MileHighCFI in forum Worklogs
    Last Post: 10-10-2006, 09:21 PM
  5. Lekan's Ford Escape 2005 - CarPC
    By LekanB in forum Show off your project
    Last Post: 03-07-2006, 04:26 PM
