Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 56
Thread: 2007 Hyundai Accent
  1. #21
    May 2008
    Quote Originally Posted by Roadmaster11 View Post
    I have a 2008 Accent and am in the process of installing a carpc. I have an 8 inch screen that i will be molding into the dash. My plan is to loose the Ac vents and make a fiberglass mold of the entire dash radio bezel and then mold the screen into it.
    Just make sure that the hazard light button is still connected, somehow. Without it, you could lose your brake lights.
  2. #22
    Dec 2007
    I'm going to move the hazards and the defrost switch to the glove box or the tray under the HVAC controls. I don't need a clock i have a watch.
  3. #23
    May 2008
    Case is bent. Do not underestimate the tensile strength of aluminum. My brake was barely up to the task. Might have been better with some bigger clamps.
    I also bent a middle shelf but made a minor screw-up. I measured 7" for the inside dimensions but since it fits inside the case, I should have measured for outside dimensions. I'll trim another piece and do that up soon.
    Next is drilling holes and tapping them.
  4. #24
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Well remember the Car PC has a clock on the screen when its on also......
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  5. #25
    Jul 2007
    Miami
    Quote Originally Posted by Sicarius View Post
    So this is going to be a whole slide in unit? I am watching this thread, my little bro has the same car and i am trying to get him to do one. Once yours is done I can prove its doable to the Accent.
    I wish I could have went this route, my case is about 5 pounds. In its defense though, it has to withstand the weight of 2 adult humans.
    Post lots of pictures!
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  6. #26
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Yep, that's pretty heavy aluminum for that little brake. You must have been right up against the limit of its abilities -- if not beyond them. You might have considered a little lighter metal and some extra flanges for strength.
    I bet you developed more arm power during that bending, too.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  7. #27
    May 2008
    Still alive but not much time to work on things.
    Tried a dry fit. It goes in OK but still needs the notch cut out as shown on the cardboard model.
    I also installed the standoffs for the motherboard but they need to be moved a little to give me more cable room.
  8. #28
    Tainted Love Cris's Avatar
    Romania
    Any updates?
  9. #29
    May 2008
    Quote Originally Posted by Cris View Post
    Any updates?
    Work is progressing but slowly.
    I have gotten my GPS. A Wintec G-Rays I here
    GMPC looks like it accepts the 10Hz update rate but I haven't had it on the road yet to see how smoothly it works.
    All the power cables, distribution block, speaker wire, active USB extender, etc, etc, have been ordered and are en-route. That should be the last of what I need to get this sucker installed for a test ride.
  10. #30
    Apr 2009
    Finally got 800x480 to work with a registry hack but the screen still thinks it's at 800x600 so the image is squashed.
    I guess I'm staying at 800x600 for now.
    Hi,
    I have the same screen with the same problem. My MCS computer can deliver 480x800 but then the screen is all white. Powerstrip didn't help.
    Can you highlight what you did to get this resolution (DTD, registry)?
    Thanks.
  1. 2007 Hyundai Sonata Aux Input (noob question)
    By Scott_Tenorman in forum Car Audio
    Last Post: 11-17-2007, 12:41 PM
  2. Hyundai Accent 2000 - CarPC
    By kasperuza in forum Show off your project
    Last Post: 09-02-2007, 04:23 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
