Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: R56 MINI Cooper MacMini Project
    Jul 2008
    Surprise! AZ
    OK I'm starting my project and hopefully I will be done and operational by the end of today after a little shut-eye.
    Here are a couple pics of where thing may or may not go. My BIG question is in Arizona in 15 degree heat do I need to have the AC cooling themac down?
    I'm sure it would help the mac run better if it were cooler butHow much cooler. I have 2 options. The place I would really like to put the mac is in the top glove box. The problem with it is you can see all the metal in that area and there would be none or little cold air running in there.
    Option 2 would be to mount it on the roof of the lower glove box. See the little square in the back with the circle. That is an A/C duct going into the glove box. Who know why MINI decided to do that but it's cool anyway.
    So what do you guys think?
    Top glove box for better stash, cleaner look and easier install. (less travel for cords.
    Or Bottom Box Nice looking install, A/C duct right on the Mac vent but I loose my glove box space and running cords would be more work.
    Both upper and lower
    Upper box
    Lower
    Screen where is will be mounted
    Mac in upper box
    Low Bitrate chrislamb's Avatar
    Nov 2007
    Warwick, UK
    Go upper glovebox and redirect the cold air from the aircon with flexible ducting.
    Nice install btw.
    R56's rock.
    MINI COOPER S PRO
    Jul 2008
    Surprise! AZ
    OK project phase 1 is complete.
    Phase 1 consists of Monitor, Mac Mini, power supply and running music and video for a trip I'm leaving for on Tuesday.
    Phase 2 will consist of Cameras in the front and rear of the car and Maybe a GPS.
    Did this whole thing is one day with some help of a good friend. 2 minds are always better then one I always say.
    There are still a few issues I need to work out. Maybe you guys can help me with that.
    First issue is the mac version of p2140 software is very limited. In order for me to even do a firmware update I had to install and run the software and firmware on my XP machine. After getting the firmware updated it works but the Mac software does not give me any options to change settings like going into sleep mode instead of shutting down. Am I missing something?
    So now I have everything bolted down in the mini I have to change the p2140 setting through a laptop running Xp. :\
    Other than that everything runs great. I have to go through my music and recognize them. The Boombox frontend is working nicely but Have not tested the net on it yet. It's also very hard to go through the music list with out a key pad of some type for searching. SO I'm going to narrow down my collection in to playlist to help make it easier to find the music. I have close to 40 gigs of music so that will take awhile. For now it's fine though.
    Anyway here are some pictures of the install.
    It's all together and working properly but still a mess. We started working on this a 10 am and got it working and ready to put the MINI back together at around 8:00 Pm
    Glove box is all tidied up now. Plus I found a really nice wireless mouse.
    This is the PS3 Thumbpad by Gameshark. Works great for simple typing and searching. Has no alt or control option so that all need to be done through a full size key board.
    And a shot of the place I store it.
    Car is all back together now. so this is what you see.
    Unless someone tells you or you know about it this is where I hid the Mac Mini. MINI designed this hidden box to fit a cd changer for some reason. Do people still use those?
    Low Bitrate vtecfelon23's Avatar
    Dec 2007
    Baltimore
    I have had some reallllly big problems with my mac over heating. any issues? Very happy to see a cooper project.
    also, what do you think of the ps3 keyboard?
    Jul 2008
    Surprise! AZ
    Quote Originally Posted by vtecfelon23 View Post
    So far no but I have yet to take it on a long trip. I did make sure that the A/c in the glove box put some of the air into the upper box. If it does over heat then I will rought the A/C duct right under the Mac.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Thread moved to worklogs section.
    Want to:
    Constant Bitrate lacning74's Avatar
    Apr 2008
    Thanks a lot for posting this. There goes my savings.
    I'm thinking of doing the same set-up with the Mac Mini in the secret compartment expect with the in-dash Zenarc 700idt screen using this single-din kit from Garbino that will cost $464 to import from Japan. I relocates the A/C controls and toggle switches down to fit a slot below the OEM headunit. It sucks that the OEM headunit is integrated to the speedometer display.
    Jul 2008
    Surprise! AZ
    Quote Originally Posted by lacning74 View Post
    That's look realy cool. I was looking at an option like that when I first started but I like the way they put the whole center together on these new MINIs and didn't want to break that up. Post a link to your build when you get it all done.
    The secret storage is a great place for the Mac Mini. Since I cut a big slit in the back of the glove box for all the wire to the power supply, HD and USB hub it allows for the glove box A/C to cool of the Mac just right. Of couse you should probably keep the A/C on all year around. at least here in AZ I do.
    My only problem at this pont is find the right Front end. Still struggling with that. BoomBox is good but in my opinion not up to par with my limited programing skills.
    I like AMP. But it's very buggy. I'm waiting for a new XP disk to come in the mail and I may just switch the whole thing over the PC.
    Apr 2008
    Quote Originally Posted by MACR56S View Post
    I came to my senses and realized $500 is too much just to fabricate a single-din. I just ordered a Lilliput 629 and will mount it like yours or possible in front of the AC controls as other mini owners have done. I'm going to use my old Mac powerbook G4 PPC for now. It's unfortunately too slow to run windows so I will deal with the limited MAC stuff out there. Either way, the MAC interface with spaces and the dock seems carpc friendly.
    In a year hopefully there will be cheaper ways to fabricate my Lilliput into the center console.
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    If you're going to mount the screen externally, have you considered getting one of the new 8.9-inch netbooks like this or this and adding a touchscreen to it? For little more than the cost of the Lilliput, you get the whole laptop; add the touch panel for under $100, and you're good to go. If those netbooks don't have the features you want, there are lots of others with additional options available. If they're too big, there are 7-inch screen units available.
    Benefits include built-in keyboard and mouse, built-in Bluetooth and WiFi, almost no cables to run, etc. They provide a lot of bang for the buck in a pretty compact package.
    I know they're not Macs, but . . .
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  1. 1984 Austin Mini Carputer Project
    By bobjimwilly in forum Worklogs
    Last Post: 11-12-2007, 08:07 AM
  2. Overheating your Mac Mini - No problem!
    By Bugbyte in forum MacCar
    Last Post: 12-08-2006, 10:46 PM
  3. Replies: 18
    Last Post: 07-26-2006, 10:50 AM
  4. MINI Cooper Cabrio, Mac Mini
    By FireAnt in forum Show off your project
    Last Post: 05-02-2005, 11:44 AM
  5. our latest mac mini based project
    By dusty in forum MacCar
    Last Post: 03-12-2005, 12:13 PM
