Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 52
Thread: 2008 Sky In-Dash Install.
  1. #11
    Low Bitrate JackB's Avatar
    Aug 2006
    Kirkland, Washington, United States
    This is the sketchup of my case. My brother-in-law thinks he can get this done for me at his work. If not, I'll probably get blk02si to cut and bend it up for me.
  2. #12
    Aug 2006
    Tomorrow starts my vacation. I've got no more workdays until next year! Yay!
    I am ordering through blk02si. His work has impressed me all over the place and my brother in law fell through.
    Yesterday I hooked up a USB adapter to my notebook DVD-ROM and made a power cable for it. Oops. It takes 5V and not 12V. Still works, thank goodness. I at least got the polarity correct.
  3. #13
    Aug 2006
    I have the case from Joe! Woot. Looks so great. I have a bit of drilling and tapping to do. Tomorrow I am going to head out and grab a few standoffs. I will take some pictures of the process.
    And the roads here in Seattle are driveable again.
    Here's what my car looked like when I got home from my trip to NYC the day before Christmas Eve.
  4. #14
    Jun 2008
    Camden / Australia
    great looking job so far
  5. #15
    Aug 2006
    Thanks.
    I have things together, but the image on my monitor is upside down and backwards now. I searched around for an answer, but only found one other thread that had a similar problem. I asked for help over on the LCD/Display forum in this thread.
    If anyone has any ideas, please let me know. Thx.
  6. #16
    Mar 2008
    Red face Driver
    Firstly check the actual screen isnt in upside down, im sure uve done it right but try checking nyway, i would then at this point usually say drivers, but its upsidedown at the post screen so doubt its drivers, mebe the bios is getting confused, check there for a setting that looks wrong, (BE CAREFULL IF YOURE UNEXPERIENCED WITH BIOS DONT FIDDLE WITH IT IF YOURE UNSURE, U SCREWED BIOS IS A BAD THING), or mebe some connections are wired incorrectly, I dunno if thats possible with these screens? Im not an expert on screens, im a computer technician not a scren guru (yet ).
    Good Luck, let me know how u get on!
    WraithJ
  7. #17
    Aug 2006
    It's not the BIOS, as the "NO SIGNAL" message is also upside down and backwards.
    I have hacked BIOSes before. This isn't that. The problem exists in the monitor. Between the input and the display itself. (Hooking up the computer into a different monitor works fine.)
  8. #18
    Mar 2008
    Wierd?
    Mebe the ribbon connection between monitor and the controller board is put in wrong?
    WraithJ
  9. #19
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Since I'm planning to install a touchscreen, this was an interesting problem. I Googled "touchscreen upside down" and found this post from Techguy Forums. It suggests that you press <Ctrl> and <Alt> and the <UP arrow> at the same time to flip the vertical orientation. Maybe it would work to press <Ctrl> and <Alt> and the <LEFT arrow> -- or <Ctrl> and <Alt> and the <RIGHT arrow> -- to fix the horizontal orientation. I haven't tried these.
    Then I Googled "touchscreen image upside backwards" and got a link to the Technology Questions forum, where one answer was to use Ultramon. You can try before you buy.
    When I Googled "touch screen upside backwards", one suggestion was to "have a look in your video cards control panel. It may have been set to rotate the display by a hotkey accidently."
    Another gave this more detailed advice:
    "Go to a blank spot on your desktop
    Right click
    go to "Properties"
    click on "settings"
    click on "Advanced"
    go to "graphics driver"
    click on "graphics properties"
    click on "rotation"
    Then rotate it by 180degrees. Thats all..."
    (I did this on my EeePC, and the setting is there.)
    And one last suggestion was to update the TS drivers.
    I hope one of them works for you . . .
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  10. #20
    Aug 2007
    Quote Originally Posted by rdholtz View Post
    Right click
    go to "Properties"
    click on "settings"
    click on "Advanced"
    click on "rotation"
    Most of these are used inside Windows to change the orientation. I am going with most likey due to Post is upside down that the screen has gotten placed in the housing upside down. I would check the orientation with a known working one of the same type. I know I have done this once and on most displays it is easy as the screen will fit either way. Just my 2 cents worth.
    2004 Sport Trac PC Project.
  1. Dash Cam Install
    By Punky in forum General MP3Car Discussion
    Last Post: 03-29-2008, 12:00 AM
  2. Replies: 2
    Last Post: 08-22-2007, 12:43 AM
  3. Jagputer Install and story log
    By JagPuter in forum Show off your project
    Last Post: 08-02-2006, 09:48 PM
  4. Punto Dash install?
    By porthos in forum Newbie
    Last Post: 02-25-2004, 07:22 PM
