Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 52
Thread: 2008 Sky In-Dash Install.
  1. #41
    Low Bitrate JackB's Avatar
    Aug 2006
    Kirkland, Washington, United States
    Ok. Car is back together, but the HD Radio isn't being found. Ugh. Not exactly sure what is wrong.
    Also, I think I might have some heat issues. A couple of times I've been driving along and the computer locks up. Not bad if I'm listening to Sirius, but if I am listening to an MP3 it is unbearable. Bad thing is it won't shut down, so it is stuck like that for 2 hours.
    Pictures of the back!
  2. #42
    Aug 2007
    Quote Originally Posted by JackB View Post
    Just a guess but I don't see a fan on your CPU or any other way to move air across the heat sink for it
    2004 Sport Trac PC Project.
  3. #43
    Aug 2006
    Hmm... I think there's one there. There was one there when I built it. I can hear it running when I turn on the machine. I'll have to take a look the next time I pull it out. That is a pain in the butt, let me tell you. That thing has NO room back there. I could use a shoehorn.
  4. #44
    Aug 2007
    Ok. Just hard to see in pictures then. Tight space would also cut down on air flow and might cause a overheating problem.
  5. #45
    Aug 2006
    Drove to Portland and back this weekend and didn't have any overheating (lockup) issues. That's a good thing.
  6. #46
    Oct 2008
    Hey there, awesome install!! Did you have blk02si make that case? I'll be doing a very similar install in my Mustang and ordering the chassis from him. Would you happen to have any additional pictures of the install that you didn't post up?
    Btw, a few co-workers of mine enjoy flipping my screen upside down, sideways etc. I thought they use alt+up/down/left/right. Maybe for future reference, a usb keyboard could solve the issue? I doubt it would be this simple though
  7. #47
    Aug 2006
    Yeah. Blk02si's case worked really well. I have a few more pictures, but I used the best ones here.
    I have no idea what your coworkers are doing to your machine. I use a wireless keyboard. Works perfectly.
    I got to show a friend Donkey Kong on the computer so he could play while I drove. That, in itself, is worth the install.
  8. #48
    Oct 2008
    N64 emulators! That would work PERFECT on a carPC!
    Thanks for the quick reply. Do you remember the height/width of the dash opening? I'm curious how that matches up to my vehicle.
  9. #49
    Jan 2009
    Thumbs up
    Is that a standard Mini-ITX mobo? Did you end up hacking up the car behind your case? You said earlier you had less than 6" so I'm curious how you ended up getting the case/itx board in there
  10. #50
    Aug 2006
    Yeah. I cut. I have pictures. They're on my phone. I'll up 'em later.
    So, if you look at the picture in post three, I cut out everything in the top three inches or so. Looking at the pictures in #41 you can see that the motherboard overhangs on just the top part, so it fits in nicely. It extends about a half an inch past the back plastic. Luckily there was a bit more space behind it or else the VGA connector and the like wouldn't have fitted.
    I also layed out the components in the case so that the montor cable would come out of the hole on the lower left side (Post #2 photo, again).
  1. Dash Cam Install
    By Punky in forum General MP3Car Discussion
    Last Post: 03-28-2008, 11:00 PM
  2. Replies: 2
    Last Post: 08-21-2007, 11:43 PM
  3. Jagputer Install and story log
    By JagPuter in forum Show off your project
    Last Post: 08-02-2006, 08:48 PM
  4. Punto Dash install?
    By porthos in forum Newbie
    Last Post: 02-25-2004, 06:22 PM
