Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 97 dsm gsx eclipse carputer LOTS O PICS & MODS! LOOK
    Apr 2005
    Alpine headunit
    Indash flip out. No name brand off ebay with panasonic screen. k90 look like or some crap. Paid $250 shipped last year.
    Both are mounted in the dash. Pics to follow on that after the console in back in (short shifter broke and had to take it all apart)
    Built a box for an 8" sub. And made the logo out of some wood and velcro'd it on.
    Box was too big and left no room for the computer stuff.
    So my cousin who is a carpenter helped me build my next box. Took about 1 hour.
    EDIT: the carpeting on the second box came out nowhere near as good as it did on the 1st box. I was a little disappointed, but whatever.
    Today I cut the hole and put in the speaker, Did some carpet on the box and a speaker terminal.
    The back lip portion is where I have the motherboard and hard drive mounted. I put them on a thin board. Peg board but without the holes.
    Then put a piece of foam under the board and didn't have any type of spacers. So I had some vacuum hose that I cut put under the board and used a 1 5/8th screw to secure the board to the box. I have no room for my power supply so I'm playing with it now. I should have it all mounted tomorrow (weather permitting) and will continue to update this thread when I do.
    Apr 2005
    Some pics of the box in the car. I still need to glue the carpet on the sides and part of the back.
    headunit and flip screen. Going to put in the console today.
    Motherboard and hard drive mounted
    Dblock with 2 fuses on the bottom left for both amps. Then a big fuse then a 140amp circuit breaker. Also I didn't know that in the cold weather the black tape will not stick as well, so I'm going to redo that with black zip ties to hold better. And look better.
    Apr 2005
    I got it working tonight, finally.
    Been sitting in the garage playing around and surfing the web.
    Still have a few bugs that need to be fixed.
    A big fricken mess that will get cleaned up hopefully this week:
    My camera sucks so here are 3 pics of the screen:
    Kind of hard to tell, but the front end software matches my alpine headunit.
    So when I turn on my headunit the pc kicks on. I can turn the pc off through the software or when the car turns off or I turn off the radio the pc is on a delay of like 10-15 seconds then it shuts down on it's own.
    w00t.
    Apr 2005
    Hmm, when I access the web from my car then go to my desktop there is an ip conflict. Anyone know what would cause this?
    May 2007
    strange make sure the names are not the same on the computers, do properties on my computer and change the computer name, if they are the same.
    Sep 2008
    He stated an IP conflict, not a name conflict. I'm guessing that other computer in your network was assigned the same IP. Are you using DHCP or Static IPs scheme?
    Apr 2005
    My desktop is dhcp for sure, the other one, I'm not 100% sure, I never changed anything. Just started with a fresh os install, so I'm assuming that windows defaults to dhcp, no?
    Apr 2005
    Got me some baller stri gauges. Water temp on the right and oil pressure on the left.
    Apr 2005
    Just got finished with putting this gauge in:
    I made the center bezel. Gooo me!!!
    Apr 2005
    Starting to paint the interior yesterday. Not too sure if I like it though. I only found gloss black so I started with that.
    Then I found some flat black so I did a light coat of flat black and 2 coats of clear.
    Found some flat black, so I did a light coat of flat black and 2 coats of clear. Not 100% dry yet, but here is what it looks like now.
    This is what she looks like now, but she is still drying. I'm going to do the rest of the back seat later as it's still in the car.
    Also put on a new crank pulley, new power steering belt, and evo3 oil filter housing. Now to go external cooler when I get money and have to hook up my oil pressure gauge. And still have to finish wiring up my wideband and find a new location for my turbo timer.
  1. Start of project log
    By Psychobiker in forum Fabrication
    Last Post: 07-22-2005, 06:13 AM
  2. Replies: 1
    Last Post: 07-14-2005, 04:30 PM
  3. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
  4. Project start for 1965 Mustang Fastback
    By 65_2plus2 in forum General MP3Car Discussion
    Last Post: 03-24-2005, 11:43 AM
  5. Replies: 4
    Last Post: 01-10-2005, 10:54 PM
