Results 1 to 6 of 6
Thread: 2005 Audi A4 B6 Euro Spec Avant carpc
    Newbie wasabi_rice's Avatar
    Oct 2008
    Greeting friends,
    I am a new member from Taiwan. I been doing some reading off mp3car forum in the past few weeks with the idea of implementing carpc into my own car. I still have much more to learn but I think I will give it a shot and hopefully don't break too much stuff. Before I go any further here is my car.
    Goods ordered and received.
    AMD 4850E 45W CPU
    1G DDR2800 Transcend SODIMM
    Silverstone NT07-AM2 1U CPU cooler
    J&W MINEX780G Mini ITX board
    Polk Audio Signature Reference Series components
    Polk Audio SR6500 speakers
    Polk Audio PA500.4 4-Channel Amplifier (Bi-Amp)
    Polk Audio SR124-DVC Subwoofer
    Polk Audio PA1200.1 Class D Monoblock Amplifier
    Dynamat Extreme 36' Bulk Pack x 2
    Dynamat Dynaxorb Speaker Pak
    Goods ordered and yet to be received
    Hippohifi USB DAC with all the options loaded
    Stuff yet to be ordered
    Power - Opus 320
    LCD - Transflective touch panel LCD (sign... says they don't ship stuff to Taiwan, lovely). I may do this one instead.
    Winmate R08L100-OFM2TR/R08L110-OFM2TR transflective LCD with AR coating.
    8.4" 1024x768 native resolution screen. 171.264 (H) x 128.448 (V) active area....Yummy~
    Anyway, this would be my first carpc project. Wish me luck! I know I will need all the help I can get so comments or suggestions are more than welcome ^^
    Oct 2008
    Time for upate... been busy with work and all...
    I have received the fully loaded Bloat from Hippohifi. Let's open it up and see what it is all about.
    The legendary small Package with big sound
    Small scratch on the casing... I don't think it will pass ISO9001 anytime soon
    Let's get naked
    Burr Brown PCM1794...needless to say this is the good stuff
    After firing up Bloat and hooking it up to my old YAMAHA DSP-1000. I am happy to report it worked fine so far. Further testing is needed in term of sound quality improvement.
    My motherboard, CPU, RAM, worked fine too. It's time to find the right solid-state drive for it. I am thinking of the new Intel X25-M 80GB SSD. We will see, for now I will just use an old 120GB HD I have laying around. My ideal boot time is 11sec or under...
    I will also start dynamat work this weekend. 40+lbs of isolation material should help to keep some noises down ^^ hopefully~
    Oct 2008
    Removing the door
    Ok, lets remove the front driver side door panel... hopefully nothing breaks
    last time the panel stays in one piece
    Ok here is the starting point, there is no going back
    Remove the four screws here
    Two more screws underneath here
    Last one at the bottom of the door panel
    Ta da!
    speaker removed
    Oh crap, it's pretty dirty inside and sucks for me because I don't have any cleaning agent on hand before dynamat extreme is to be installed.
    To be continued...
    Oct 2008
    SR6500 6 3/4 inch Speaker
    Got to work on the project a bit today. According to Crutchfield and other online vendors, SR6500 does not fit B6 Audi A4.
    Here is the information about the speaker
    Well, I bought a pair against their recommendation and set out to modify the factory fitting to make this work (going for OEM look). Anyway, we will let the pictures do the talk.
    Cut off the paper speaker cone
    Proceed to cut off the supporting points indicated in blue
    Here is the result
    Next, the tweeters....
    Oct 2008
    In continuation of the OEM look, things will stay behind the factory tweeter grill so no hint of modified speakers are given out.
    Factory housing
    Audi OEM tweeter removed
    SR6500 tweeter prior to installation
    Test fit and to my surprise, a direct fit! I added a double side tape to secure it further..and finito ^^
    Newbie CPUB's Avatar
    Barcelona, Spain
    Hi wasabi_rice, greetz from Barcelona, Spain! Very interesting what you have done so far, specially for A4 B7 owners!
    Any progress with your install? Any pictures of the acoustic insulation?
    "Computers in the future may weigh no more than 1.5 tons."
    (Popular Mechanics, forecasting the relentless march of science, 1949)
  1. 2003 2004 2005 Honda Accord CarPC
    By Adam2312 in forum Newbie
    Last Post: 02-09-2009, 09:25 PM
  2. 2005 G35 Coupe Pentium M CarPC
    By Caelric in forum Show off your project
    Last Post: 02-09-2009, 08:12 PM
  3. Audi A4 OEM XM module interface Questions
    By atekind in forum General Hardware Discussion
    Last Post: 02-14-2007, 08:51 AM
  4. Replies: 21
    Last Post: 01-27-2005, 05:37 PM
  5. Audi A6 custom install carpc with fingerprint recognition
    By ejdeleon in forum Show off your project
    Last Post: 07-07-2004, 03:25 PM
